Question about Toshiba 50HP66 50 in. Plasma Television
Digital audio output menu adjustments 50HP66
In the audio menu, cannot select the digit output feature. need to change from PCM to Dolby Digital
tvservice306
  • 458 Answers
SOURCE: Got audio and text, but no picture
try setup" cc " off:
Posted on Sep 13, 2009
Testimonial: "My tv is a Toshiba 37 inch Regza LCD. I have been through the set up options and cannot find 'cc' off. Can you elaborate please."
dave1645
  • 834 Answers
SOURCE: if i am using outdoor antenna do i need digital
if your still reciving a picture then your all set...you might want to run channel scan again there have been alot of new chennels added over the air
Posted on Sep 18, 2009
  • 1039 Answers
SOURCE: I have just got a Toshiba 37AV502R flat screen tv.
Is this sub a Bose. The only reason you would see a VGA type connector on a sub is if it is dedicated to somthing else such as Bose 3-2-1 system. This is not a standard VGA input and can only be connected the the dedicated head unit. I need more info on the sub. Brand and model. Ther should be an analog audio input on the sub. This will be sufficient.
Posted on Oct 31, 2009
  • 30 Answers
SOURCE: can not get my digital optic output to work
there will be an option under sound menu to activate tos link
Posted on Jan 03, 2010
SOURCE: i bought a TOSHIBA 32KV500B tv. At the Initial
I had this problem and searched the internet for hours looking for an answer and was given the initial same reply as this and it does not work. To solve this problem all you simply need to do is press source button on the controller followed by pressing the DTV/USB option. All your digital channels will come back to you and you will find the menu setup options you are looking for!!!
Posted on Jul 23, 2011
I have a Sharp Aquos LC-60LE640X TV and I am trying to connect a Samsung HW-H751 Soundbar to it. I have hooked up the optical cable, adaptor and sub woofer, I have tested the Bluetooth function throug
If you are connecting the soundbar to your TV with the digital audio cable, make sure to select "D IN" using the source button on the soundbar. Bluetooth (BT) is a separate source from another device. (phone, etc.) The TV will need to be set to use the digital audio output and probably PCM format. (?) The subwoofer is preconfigured at the factory to mate up with your soundbar. (See below instructions - your soundbar includes the amplifier:)
Digital audio output setting:
After connecting an amplifier with digital audio input and
external speakers as shown, you should set an audio
output format compatible with the programme you are
watching or the device connected.
Go to "HOME" > "TV Menu" > "Setup" > "Option" >
"Terminal setting" > "Digital audio output" > select
"PCM" or "Bitstream".
NOTE
• When set to "Bitstream", Dolby Digital is output when the Dolby
Digital or Dolby Digital Plus audio formats are received. When
set to "PCM", PCM is output no matter what audio formats are
received.
• When set to "Bitstream", HE-AAC audio formats can be output
as Dolby Digital.
Jan 24, 2015 | Sharp Aquos Televison & Video
Hello, I recently bought an Onkyo HT-S9300 home theater system. I am trying to get it to work with my DVD player using optical cable for the sound, since the DVD player does not have HDMI output, but I...
In your DVD player audio setup change the digital output to bitstream. You have not mentioned which DVD player you are using.
Some players it will be given
Digital Out - Off/ On select On
Dolby Digital - Dolby / PCM select Dolby
DTS - On/Off select ON
Jun 19, 2011 | Audio Players & Recorders
I have a Sharp Aquos with a optical output, i conected it to the tv optical input of the panasonic sc ptx7 but it doesnt have audio via optical,on the contrary via rca works perfectly.
hi,
check the following on ur tv
1. Press MENU to display the MENU screen,
and then press c/d to select "Digital
Setup".
2. Press a/b to select "Audio Setup", and then
press ENTER.
3. Press a/b to select "PCM" or "Dolby
Digital", and then press ENTER.
4. Press MENU to exit.
PCM The optical output terminal output studio signal in PCM form. If your digital audio system does not support Dolby Digital, select "PCM".
Dolby Digital
The optical output terminal outputs audio signal in Dolby Digital form. it reproduces sound from surround program of digital.
also check the input assignment of ur dvd palyer's tv input. if it is selected as analog then change it to digital.
ok
Dec 20, 2010 | Panasonic SC-PTX7 Home Theater System With...
Low volume on LG HDTV
I encountered the same thing using the HDMI interface on my new TWC cable box (Motorola DCX-3200). After a little bit of research, I finally fixed it by changing the digital audio mode in the cable box using this procedure:
1. Be sure the TV is on and connected to the cable box.
2. Using the cable box remote turn power OFF.
3. Immediately press the MENU key on the remote. The USER SETTINGS menu should appear on the TV screen.
4. Select the ADDITIONAL HDMI SETTINGS >>> menu item.
5. The ADDITIONAL HDMI SETTINGS menu will appear.
6. Scroll to the AUDIO OUTPUT item and select this.
7. Change the setting from AUTO to L-PCM.
8. Return to the main page
9. Using the remote, cycle power OFF.
10. When the cable box is turned on again, you should be good to go.
I realize these instructions are specific to the DCX-3200, but there may be a similar setup option available in your cable box as well.
The problem here is that the cable box is by default configured to use Dolby Digital audio, which requires an additional 10dB of headroom to deal with the boosted LFE channel. If the cable operator hasn't taken pains to set the system up correctly (and most haven't, apparently), the digital audio level sent on the HDMI interface will be approximately 11dB down from normal analog line levels on the HDTV channels. Changing to straight linear PCM sets the TV receiver audio level on the HDTV channels to match the levels on the non-HD channels.
The only problem with this fix is that if you intend to feed a Home Theater receiver that uses Dolby Digital processing with the cable box output you will lose the Dolby encoding feature and be forced into straight 2-channel stereo. For a simple installation like mine where I'm just feeding the TV, this fix works fine. If you have a more complex setup that takes advantage of Dolby Digital features (when it's available in program material), you may have to live with the problem.
For a technical reference on why this happens, see http://www.megahz.com/specimages/Dolby/LM100%20Cable%20App%20Note%2011-05.pdf
Hope this is useful.
May 19, 2009 | LG 37LG30 37 in. LCD HDTV
No dolby digical in DVD mode.
PCM mode will not output dobly digital, use the digital cable connection, not RCA cables, set DVD audio output menu to Dolby digital or DTS. On DVD software menu setup select audio then Dolby Digital 5.1 or Dolby Surround.
Jan 25, 2009 | Yamaha HTR-5960 Receiver
Panasonic SC-PT660 digital in doesn't work
Select to suit the type of audio from the OPTICAL IN terminal on the main unit.
1 While in “D-IN” mode
Press and hold [—SETUP] to select “MAIN/SAP”, “DRC” or
“PCM FIX”.
2 While the selected mode is displayed
Press [up, down] to make the setting.
MAIN/SAP mode (Only works with Dolby Dual Mono)
MAIN, SAP§, MAIN+SAP§ (stereo audio)
§ “SAP” = Secondary Audio Program
Dynamic Range Compression
DRC ON: Adjust for clarity even when the volume is low by compressing
the range of the lowest sound level and the highest sound level.
Convenient for late night viewing. (Only works with Dolby
Digital)
DRC OFF
PCM FIX mode
PCM ON: Select when receiving only PCM signals.
PCM OFF: Select when receiving Dolby Digital and PCM signals.
[Note]
Audio that is input through the OPTICAL IN terminal cannot be output
through the HDMI terminal.
Nov 29, 2008 | Panasonic Home Theater System System
PCM 2.0
I had the same problem with my 321 system. The fix is in the cable box settings. You want to change the Digital Out on the cable box..my choices were HDMI....Dolby Digital..and None. Choose Dolby Digital and it will show up on your Bose 321 display. I also have my cable box connected to my bose system via optical digital cable...and a digital coaxel cable from my dvr to my bose. Change that output setting on my cable box took care of the PCM 2.0 problem for me.
Dec 19, 2007 | Audio Players & Recorders
Source always PCM, can't get Dolby-D
PCM is standard when using HDMI cables, you are passing an already decoded audio signal to the receiver and it outputs the sound and does nothing more. The reciever calls this PCM, your PS3, when pressing select should show that it is decoding the dolby digital HD. There is no quality difference in the two. PCM is the same because it is un compressed audio. So when using HDMI, no matter the signal that the movie or music is playing, wether it be dolby or DTS, you will see PCM when using HDMI.
Nov 24, 2007 | Onkyo TX-SR605 Receiver
Problem with Dolby Digital mode
If it is a new DVD that may be a problem, as signal changes may be frustrating this old machine... but it is likely the cabling from the DVD player to the reciever. Are you on the right channels/settings? is the optical cable and digital cable recieving digital output from your DVD player? Try changing those settings and you should be in good shape Thanks! good luck!
Jul 22, 2007 | Yamaha RX-V3300 Receiver
Hook up your Xbox to a Dolby Digital Decoder
Xbox® is the first and only game console to support in-game Dolby® Digital 5.1 surround sound. This lets you experience all the game sounds from your home theater system in full 5.1 surround. Before you get started, make sure you've got the following: A digital audio output. A free optical digital input on your receiver. An optical digital audio cable. Digital Audio Output Your Xbox didn't come standard with a digital audio output, but you're gonna need one for this to work, so hightail it to the store for the Advanced AV Pack or High Definition AV Pack, both of which have digital audio outputs. Microsoft makes both of them. You can also buy third-party AV cables for Xbox?but make sure they have a digital audio output. Free Optical Digital Input For this slammin' sound system to work properly, you need at least one free optical digital input on your receiver. Ready to Hook It Up? Let's Go! Connect the digital audio output to your Xbox. Connect one end of the optical digital audio cable to the digital audio output on your Xbox and the other end to the optical digital input on your receiver. Turn on your Xbox with no disc in the disc drive. In the Xbox Dashboard, select Settings. Select Audio. You will see an Audio Mode screen that shows Dolby Digital and DTS status. Select Dolby Digital. You will see the question "Does your stereo system support Dolby Digital Audio?" Select Yes. You will see Dolby Digital Enabled in the audio screen. Your Xbox is now ready for Dolby Digital gameplay. Insert a game disc and play!
Nov 20, 2005 | Microsoft Xbox Console
Toshiba 50HP66 50 in. Plasma Television Logo
82 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
