Question about Pioneer DEH-P3000 CD Player
Reconnecting Deh - P3000
I tried to connect this deck into my automobile, and had some problems. Everything powers up and display comes on, even accepts, plays, and ejects cd's. I have no sound out put from the speaker wires in the harness. The radio searches and tracks stations but again no sound at all? Checked all fuses and they are good, all wire connections are good just no sound out put from the wires. Is there an easy fix????? Thank you for your time
  • Robert Tracy Jul 18, 2007
    It plays cd"s according to display but no sound out of wires.
    Scholar:
  • 98 Answers
HI. search pioneer no sound on this board. i have already walked another guy through this... if everythng works but no sound is outputted.. 99 times out of 100 the audio output ic "chip" is bad. Its a common failure for pioneer cd players as well as others. The part is about $20 if you know where to look... if you decide to repair this yourself you will need to be very skilled with solder and desoldering braid... let me know
Posted on Sep 08, 2007
SOURCE:
No power to DEH-P3000 pioneer car radio
sometimes the connectors on the faceplate get dirty, use a pencil eraser to carefully clean those connections
Mar 23, 2013 | Pioneer DEH-P3000 CD Player
Where can i hook my ipod to this stereo? the specs say it has ipod connectivity.
it could be one of 3 spots on your deck
1 bottom right look for a rca head phone jack
2 top right look for a usb connector
3 back of deck look for rca leads
Mar 23, 2011 | Pioneer DEH-P3000 CD Player
European Wiring harness not compatible with US bought Stereo
This is not as straightforward as you may think.
You can certainly buy a generic adapter harness which will plug into the European DIN harness and then provide you with the bare wire tails to patch into. You may even find one which plugs directly into the rear of your head unit without the need for patching.
But you'll find that your head unit still won't work properly as the US uses a different FM channel range to Europe (US frequencies are odd, e.g.102.7, Euro frequencies are even e.g.102.8). The channel spacing is also different.
The radio itself cannot be converted, but you may be able to buy an external converter. It won't be cheap, and the head unit display will still always show the wrong frequencies. Channel changing may have to be done directly on the adapter and not on the head unit as I don't think that the DEH-P3000 has any way to communicate a request for a channel change to any external device and this also means that radio channel presetting may be impractical/impossible.
Considering that the DEH-P3000 is an obsolete unit and nothing special to begin with you can buy a brand new Euro-spec head unit of equivalent quality for less than the cost of adapting your unit and it will work correctly without any awkward Heath Robinson adaptations.
Sell your Pioneer back to the USA where it belongs or bin it as it's useless over here.
Jan 24, 2010 | Pioneer DEH-P3000 CD Player
Pioneer deh-p3000 when i turn the key off and back on the stereo's doesnt remember anything
did you wire the radio yourself? it sounds like you have the yellow wire connected to a switched power source. the yellow wire needs to go to a power source which is always hot, or constant, whether the key is on or not.
Oct 29, 2009 | Pioneer DEH-P3000 CD Player
Need wiring diagrams from a 1994 chevy s10 to a pioneer deh-p3000
its not a big problem try another speaker from the right side. if not work. check fuse and the wire. just follow the wire where its connected. if no fuse found. the problem is in the amplifier IC. change it if speaker from right side is not burned yet. thanks.
Jun 07, 2009 | Pioneer DEH-P3000 CD Player
NO POWER TO MY DECK
Hello clarky909,
On your Alero, the 12V constant wire is ORANGE and should connect to the YELLOW wire coming from the DEH-2300 wiring harness. 12V switched on your Alero is YELLOW and should be connected to RED coming from the DEH-2300.
Hope this helps.
Jun 01, 2009 | Pioneer DEH-2300 CD Player
No rear output
yea your ic in the deck is going so i suggest you buy one which is cheaper than buying a new deck
Sep 15, 2008 | Pioneer DEH-P5800MP CD Player
Ipod cable will not work with the DEH-P3000
Hi, On a slightly different model and only if you would venture to try: with the iPod via cable plugged to the iP-Bus port and the unit powered off but the powersupply on - 1. press and hold for a couple of seconds the Function button (FUNC) or till the clock starts to flash; 2. the arrow keys (left/right) will move you through the different menu settings; 3. the arrow keys (up/down) will move you through the different selection for each setting; 4. look for source, external, AUX, iPod or whatever will be displayed which may refer to an external input; 5. soon as you have enabled/set the AUX, press and hold the FUNC button while turning the unit on. This will save the current setup. Hope this also work for your DEH-P3000. Good luck and kind regards.
Sep 23, 2007 | Pioneer DEH-P3000 CD Player
I have a pioneer DEH-P3000
Hi nhmteam. I have the solution for you: 1. With your DEH-P3000 turned off, press your FUNCtion button. It's a tiny button towards the upper right of the faceplate. Hold it down until you "ALARM OFF" or "ALARM ON" on the display. Release the button. 2. Press the FUNCtion button again and you should see another feature. I don't remember how many features you need to cycle through, but keep releasing and pressing the FUNCtion button until you see "M-CD ON" on the display. If you miss it just keep going and eventually it will come back. 3. On the right side of your faceplate there is a button with 4 arrows. You will need to push the up or down arrow until the display reads "M-CD OFF". If your display already reads "M-CD OFF", kip to the next step. 4. Press and release the FUNCtion button again and you should see "AUX OFF" on the display. Again press the up or down arrow until the display reads "AUX ON". 5. Now, turn on your unit, then press the INPUT button until the display reads "AUX". You are now ready to use your iPod in the way you always did. Keep these instructions for the future since I believe every time you disconnect the unit from the battery the unit will reset itself and disable your iPod cord. Best regards - TomR
Aug 30, 2007 | Pioneer DEH-P3000 CD Player
Pioneer DEH-P3000 CD Player Logo
119 people viewed this question
Top Pioneer Car Audio & Video Experts
Marvin
Marvin
xxxxxx xxx
Are you a Pioneer Car Audio and Video Expert? Answer questions, earn points and help others
