Question about Audiovox Audio Players & Recorders
I need a manual for a Audiovox AMP-760 graphic equalizer booster
7 band, 1987
tech48
  • 624 Answers
SOURCE: i have a 1987 model
First connect all sources like tuner, cassette player, Cd player into the proper RCA inputs of the control amp, then connect the output of the control amp into the input of the equalizer. Then connect the output of the equalizer into the input of the amplifier. This is how to get the best performance and proper outputs to all the right equipment. The speaker outputs of the amplifier would then go to the speakers.
Let me know if you need more help from me by addressing your post to me, or if you wish to communicate with another expert you can address your post to them I.E. @tech48 or @whoever
Thanks and good luck,
Dave
Posted on Sep 27, 2008
SOURCE: Optimus 7 band equalizer model # 12-1969
I need to know what the wire are coming out the back of the optimus seven band stereo frequency equalizer/booster
Posted on Nov 27, 2008
  • 28 Answers
SOURCE: Graphic Equalizer installation in a 1991 Mercedes-Benz 420-SEL
this unit that you have if you are a do it your selfer i dont recommend you try to do you self not on a mercedes
Posted on Dec 04, 2008
  • 7 Answers
SOURCE: Hi I would like to know how to wire up a kam keq
Either run the main ouptut for your amp to the input of the eq and output of the eq to the main input of your amp OR use one of your tape monitors on your amp. Record on your amp goes to eq input and play on your amp goes to eq output. Hope this helps you.
Posted on Jul 30, 2009
  • 128 Answers
SOURCE: I have a Yamaha HTR-5890 receiver and I am trying
must have the tape monitor to work the regular tape loop does not physically go back into the receivers processor.
only other solution is if the receiver has PRE out and ins use the PRE out to the EQ then back into the PRE in.
if you have the OUT but no in then the solution would be to go out of the EQ and into an external amp.
In my experience "young adults" like using EQ's to boast bass output.
If that's your goal a POWERED subwoofer is what you need.(check out polk audio direct on ebay)
Your unit is a 7.1 surround receiver the reason that it doesn't have the capability for an EQ is that it messes up the surround sound processor.
If the sound is not what you are looking for the issue more than likely is with the speakers. post a messege with what you want to achieve and I'll try to point you in the right direction.
Posted on Dec 29, 2009
How to hook up a 7 band pioneer equalizer great 470 to a Kenwood kr-v6030 receiver
Connecting an Equalizer to a Receiver Before beginning, purchase RCA cables. In order to run the signal from a stereo receiver to the graphic equalizer and then on to the amplifier, two sets of RCA cables are needed. These are basic cables used to connect auxiliary components like record players and CD players. The length of the RCA cables should be about the same length as the distance between the receiver and equalizer.
1. Connect Graphic the Equalizer to the Receiver
The first step in this setup is to connect the graphic equalizer (EQ) to the receiver. Most receivers will have preamp-in and preamp-out connections. Some have tape monitor connections. It's preferable to connect the EQ to the preamp-in or preamp-out because the tape monitor won't allow for connection to the amplifier as well.
2. Connect the RCA Cables
The first set of RCA cables should connect the receiver and equalizer. Connect one pair to the preamp output channels and the other end to the left and right input channels on the EQ. These are on the back side of the equalizer. Usually, the colors will correspond to the RCA plugs. That means connect the red plug to the red jack and the white plug to the white jack. Then connect the second pair of RCA cables between the receiver and the amp. Match the colors in the same way.
3. Connect the Amp to the Receiver
Now the amp can be connected to the receiver via RCA cables in the amp inputs on the receiver. This will create a loop from the receiver through the EQ and amp and back to the receiver so that all three units are connected.
4. Test Graphic Equalizer
Turn on the receiver, amp and equalizer. Once they are powered up, try controlling the sound with the equalizer knobs. They should fine tune the music according to your preferences. It's easy to change the frequency response or tone of the music with the equalizer knobs.
May 09, 2016 | Pioneer Audio Players & Recorders
Need wiring diagram for alpine graphics equalizer
Hi there
Use the 'Google' search engine and type in support.alpine-usa.com/products. You will be able to download a pdf manual on your model.
Apr 13, 2014 | 1993 Ford Probe
I need data sheet or user manual for my pioneer graphic equaliser
If is a parametric equalizer is zero watts. ,pionner should have a front, rear and subwoofer connections. If i remenber correctly, a single rca going to your stereo and the rest from eq to amp or amps. Hope this helps ,hope you get WIRED.
May 15, 2013 | Pioneer EQ-6500 9-Band Car Equalizer
I need a wiring diagram for the pyramid 10 band graphic equalizer. Where can I find this diagram?
Click on MANUAL DOWNLOAD
LOOK PAGE 4 INTO THE PDF FILE!!!!
http://www.pyramidcaraudio.com/sku/903G/10-Band-Half-Din-Power-Booster-Graphic-Equalizer-Amplifier-200-Watts#
Oct 10, 2010 | Pyramid 903G 10-Band Car Equalizer
I need a wire diagram for equalizer 903g
Jan 29, 2010 | Pyramid 903G 10-Band Car Equalizer
I wanna equalizer a jensen 760 but i can`t can you tell me how can i do?
Hello, if you want to put an equalizer on an amp then I would suggest you get a preamp style equalizer, non powered of course, take the rca output whichever one you want to use and conect it to the input on the equalizer. Then take the output from the equalizer and hook it up to the input on your amp. That's it. Most equalizers also have sub outputs, make sure you hook the correct output from the equalizer up to your amp. Also most have 3 outputs depending on the type you have. If you need more help just let me know, good luck
Aug 14, 2009 | Audiovox Jensen Power 760 Car Audio...
Jul 07, 2008 | Car Audio & Video
241 people viewed this question
Top Audiovox Audio Players & Recorders Experts
John
John
Computer Links
Are you an Audiovox Audio Player and Recorder Expert? Answer questions, earn points and help others
