Question about Garden
Ariens 960160027 parts list
Mower deck will not hold position. Pin is in but wobbles allowing the deck to drop when hitting a bump
mickey813
  • 472 Answers
SOURCE: We have a Weatern Auto Wizard Riding Lawnmower.
19c5756.gifHOPE THIS HELPS LET ME KNOW
Posted on Nov 19, 2009
  • 11 Answers
SOURCE: Parts for Ariens Model Number FM626E
you need to get the model number from the mower body and verify that it is correct the age should not matter some hardware stores work primarily on ariens mowers hope this helps
Posted on Apr 03, 2009
SOURCE: john deere 111 mower deck. Lift is in stuck in highest position
Looked up detailed isometric diagram w/ parts denoted on John Deere website. FixYa website was a litele misleading. I did not realize that accessing a question posted "for free" would cost me something to get the answer. It's kind of like askin a neighbor as a neighbor to give you a hand and then he sends a bill.
Thanks but no thanks
Posted on Jun 26, 2009
  • 218 Answers
SOURCE: can someone please help lookingh for belt routing
Hey John..my name is Keith..and you can go to an online lawn mower parts site..and they will have a pic of the deck and they way the belt is routed...one of the sites is www.outdoordistributers.com ...i hope this will help
Posted on Jul 08, 2009
mowerman1857
  • 389 Answers
SOURCE: Need a drawing on how to install belts on 48
Go here https://jdparts.deere.com/servlet/com.deere.u90.jdparts.view.publicservlets.HomeUnsigned
Sign up and you can access all available information on your tractor
Posted on Sep 15, 2009
Have an Ariens Max Zoom 60, when engage the mowing deck the engine loads up and RPM's drops way down" Have tightened and loosened belt, what else can I Try?
Something in the mower blade drive is binding up. That puts a drag on the engine and causes the slow down in RPM.
Jun 16, 2017 | Ariens Garden
How to replace deck belt on ariens model 960160027 lawn vtractor
Please go to the Ariens website and download a manual for your mower.
Jun 29, 2014 | Ariens 42 in 17.5 HP 6-speed Riding Lawn...
John deere 855-70 manual
On ALL Deere riding lawn mowers, 1st, position the deck under the tractor. Depending on the belt drive: either PTO (the yellow button on the dash panel), or tension engaged-(a lever on the right side of the operator\'s seat), you loop the drive belt from the front of the deck to the pulley, always in the lower front area of the tractor\'s engine. If it has "beltguards" too close to the pulley, you must loosen the retaining bolt for the guard, it will allow the belt to squeeze by and onto the pulley. Then, 2nd but don\'t forget to retighten after slipping the belt on, push the "Deck heighth" lever fwd to drop the deck "hangars" at the rear of the deck into position to "pin" the eyelets with the supplied pins, washers and keepers: usually a cotter pin or a lynchpin that inserts thru a hole on the smooth bolt-pin. The easy part\'s over, but don\'t panic. 3rd, lift the front of the deck onto a block, allowing a heighth to apply the "adjusting rod" into the front of the mower chassis. Screw the retaining nut onto the threaded (long bolt) and remove the block. You\'re done. Next, and very important, RAISE & LOWER the deck, engage the belt tension, (here you may have to clear the area and start the engine to engage the PTO drive, if it\'s electronically controlled belt-drive), this assures nothing is "misaligned" or improperly positioned. Now, if the machine is on a flat surface, lower the deck to a point just above the ground and measure the distance in four (4) corners of the deck and record the ht. Make the adjustments to LEVEL the deck. Now you\'re ready to start the engine from the operator\'s seat, slightly increase the engine from idle to 1/4 throttle speed so that engaging the drive belt won\'t kill the engine. Ensure the belts run smoothly, the blades turn, and the engine doesn\'t "bog". Lower the deck to a desired cutting ht., now MOW the grass!
Jan 28, 2014 | Garden
I need to know the belt size and part number for the 915037 1844 ariens zeroturn
Hi and welcome to FixYa, I am Kelly.
http://partsradar.arinet.com/scripts/EmpartISAPI.dll?MF&app=ariens&lang=EN&TF=Empartweb&loginID=ariensc&loginpwd=consumer
Make sure pop-ups are enabled... (No ads on site)
Enter this model number:
915037-000101
Then on the side of the page choose: (Scroll) Mower Deck, Belt Idlers and Blades
There are 5 belts listed! There is nothing that relates to a mower or deck serial number either.
You have to know the model numbr of the deck (see item 1 same link to cross ref your belt size)
035
Belt PN: 07241700 V belt (037) = 44 inch deck model 51519000 & 5159100
039
041 / 313
Belt PN: 07242900 V belt (501) = 44 inch Deck Model 51510400
Thanks for choosing FixYa.
Kelly
Sep 10, 2011 | Garden
When I engage the deck to start cutting a loud noise begins and the tractor does not work. I previously hit a tree root with it's blades engaged. Can you please help? Thanks Danny
Sounds to me like you bent a spindle. Turn the mower off and get under it and see if you can spin the blades. The blades whould spin and not be wobbly. If either one of the blades are wobbly then you'll need to replace the spindle.
Also check to make the blade belt hasn't come off or is not destroyed.
Aug 01, 2011 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
Mower deck clutch cable removal (model 917.28722). Detail provided in manual does not seem to match product. Need to remove this in order to remove deck and replace belt. Belt has squealed since new.
You should not need to remove the deck or the clutch cable just to change the belt.
  • ensure mower clutch lever is in the off position
  • lift the front of the tractor approx 24 or more inches.
  • lower the mower deck as far as it will go
  • locate & remove the cotter pin from the right (discharge) side mower lift arm where it attaches to the rear of the mower
  • release the lift arm from the mower deck to allow it to drop (it will hang from the other 3 points)
You should now have plenty of clearance to change the belt. Remove the belt from the engine pulley first and replace the new belt on the engine pulley last that will make it easier to change the belt.
If this is helpful please vote yes, Thank You!!
Aug 28, 2010 | Craftsman 42 in. Precision Cut Plus 24hp...
Ariens 34 zoom blade binds at mid-height blade
Sounds like the mower deck is lower on one side. I am having the same problem with my older tractor mower.
Jul 24, 2010 | Ariens 34 In. Zoom Series Riding Mower
Have a 2006 145 automatic riding mower. Belt keeps
idler or adjustment pulley bearings worn allowing belt to ''run off''as it wobbles.stays on.check spring tension of idler.
Sep 20, 2009 | Garden
Garden Logo
268 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
