Question about Electrolux 24 in. EDW5505EPS Stainless Steel Built-in Dishwasher
Fix for Electrolux dishwasher error 3
Model #EIDW6405HT0 error 3 comes on. I did this when the unit was one year old. I washed by hand for a year then tied it and it worked now its back to error code 3. Any fix?
SOURCE: Electrolux DX302 Dishwasher power button wont stay on
I rang Electrolux and have ordered a new switch....
Posted on Jan 14, 2009
SOURCE: electrolux esl 6251 built in dishwasher 2 years old
PROGRAM WONT RESPOND MACHINE NOT STARTING
Posted on Apr 11, 2009
tattootech2
  • 72 Answers
SOURCE: EWDW6505GS0 Model Electrolux dishwasher 10 months
Dishwasher likely has leaked into drip pan underneath. Unfortunately, you need to remove dishwasher and flip onto back and remove 3 phillips screws that hold drip pan in place. Install "leak kit" to correct leak problem with this model of dishwasher. Part number is 154769101
Posted on Apr 07, 2010
tattootech2
  • 72 Answers
SOURCE: Electrolux 6505GSO dishwasher. Says
  • 530 Answers
SOURCE: I have a Firdgedaire Electrolux model GLD4355RFB1
what is the code?
Posted on May 17, 2010
Model EIDW6305GSI error code 03 comes on after about an hour after cycle starts could anybody tell me why this happens thanks
Good Morning steven hutchings, thanks for your inquiry!
I understand that your Electrolux dishwasher is displaying an error code 03. Normally, error code 03 means an issue with the wash motor, wash motor hall sensor, or control panel. I would suggest performing a reset on your dishwasher that could help clear any false error codes. You can reset your dishwasher by flipping the household circuit breaker in the off position for ten minutes. If you continue to have an issue with your dishwasher displaying an error code 03, I would recommend having a professional technician come out and properly diagnosis your dishwasher. This will help to avoid any unnecessary part purchases. Hope this is helpful. -Matt
Dec 04, 2014 | Electrolux Dishwashers
Electrolux EWDW6505GS error 01
Good Afternoon Friend,
I see that your Electrolux dishwasher, model# EWDW6505GS, is having trouble with an error 01. I suggest resetting your dishwasher. You will do this by either unplugging it or shutting the power off at your homes circuit breaker for 20-30 minutes. When the power is restored, run a wash. If your dishwasher is still experiencing an error 01, I suggest contacting your local authorized technician. Hope this is helpful.
-Best Regards-
WP
Apr 20, 2014 | Electrolux EWDW6505GS Fully Integrated...
Electrolux front loader E50 error
Hello Friend, thank you for your post!
I see you are receiving an error code E50 on your Electrolux dishwasher. Is it possible that the code is missing characters? Could it possibly be an E50? May I please have your model number? The serial tag, which lists your model number, is typically located on the right side as you open the door. With this information I can further address the issue at hand. In the meantime, I suggest resetting your dishwasher. You can do this by flipping the household circuit breaker off for roughly ten minutes. If resetting the power does not correct the issue, could you please inform me of the new error code or if your dishwasher continues to display E50. Thank you - Z.
Apr 12, 2014 | Zanussi ZWF1640 Front Load Washer
Repairman didn't reset my error 3 code
Good Morning Suzanne, this is AP with Electrolux.
Thank you for submitting your question concerning your Electrolux dishwasher, EWDW6505GS. Typically an error 03 code indicates that there is a communication failure with the wash motor or wash motor hall sensor. Some tips for troubleshooting include checking for suds in the tub and check for syphoning or no fill conditions. If the error code persists, it would be advisable to have your authorized technician check the wiring between the main control board and motor since either part could need replacing. Hope this helps.
Mar 04, 2014 | Electrolux EWDW6505GS Fully Integrated...
Error code 01 keeps coming up and will not let dishwasher complete its cycle. My dishwasher no. is ewdw6505gso and it is only 3 years old. I have 2 other appliances that are Electrolux. Please help.
Mine was only a few months old when error 01 arrived - it is a leak. The Electrolux dishwashers have a leak detector at the bottom inside the plastic pan, that when water appears it sets off the code and you cannot restart the dishwasher until you dry the pan out (tip the unit forward and water will come out) but it will keep on doing it unless you repair it - mine was covered under warranty and they replaced a lot of parts at the bottom. Not even a year later it leaked again, but not as bad. I took it apart and removed a fabric pad that sits in the bottom of the pan, it does not go off that much any more since the water evaporates before it does any damage. I think this feature is completely useless - I would rather see a wet spot on the floor than not be able to do dishes... If you got 3 years you are doing well. I will just replace my appliances as they die and never buy Electrolux ever again! PS if a refrigerator is one of your other units, be aware that their main boards can fail and are very expensive to replace. You will know it is blown when your food freezes in the lower compartment and your lights come on instantly instead of glowing up slowly.
Nov 15, 2013 | Electrolux Dishwashers
I have a electrolux dishwasher. Non of the buttons will function and the display is stuck on clean.
Hello louisewith4 - I understand none of the buttons functions on the dishwasher, however try unplugging the unit or flipping the household breaker off. Wait approximately ten minutes and I suggest touching each button individually on keypad, does the display change or will it start? If not, I would recommend contacting a professional because the unit may possibly have a defective keypad.
Nov 15, 2012 | Electrolux 24 in. EDW5505EPS Stainless...
Ewdw6505gso electrolux. error 1. have turned off
the water will have leaked into the drip pan underneath, which is installed to protect your floors. Unfortunately, only way to get at it is to pull out dishwasher and remove 3 phillips screws that hold it on. In order to repair leaks, Electrolux came out with a "leak kit", which is part number 154769101. Comes with all parts that they had leak issues with
Mar 14, 2010 | Electrolux EWDW6505GS Fully Integrated...
Electrolux 24 in. EDW5505EPS Stainless Steel Built-in Dishwasher Logo
52 people viewed this question
Top Electrolux Dishwashers Experts
Mike
Starnley Johnwells
Starnley Johnwells
Are you an Electrolux Dishwasher Expert? Answer questions, earn points and help others
