Question about Lincoln Electric Ranger 305G K1726-4 Welder
305g runs but will not weld - Lincoln Electric Ranger 305G K1726-4 Welder
I have a Lincoln 305g welder with digital readout and the amperage reading is fluctuating wildly but doesn't affect amperage to stinger,do I simply need to replace the digital display
the digital display is just showing what is going on
the amperage is controlled by the voltage setting so the problem is most likely in the voltage regulator
take it in for a proper diagnosis and quote but guessing the fault is like throwing money away
May 15, 2017 | Lincoln Welding Tools
I have a Lincoln 305g with digital readout and the amperage readout is fluctuating wildly but is not effecting amperage to the stinger,is it possibly just the digital readout that needs replacing?
Most likely the coil that is sensing output at the lead terminals. Check it with a hand held Amprobe (digital) to see if out put is stable at the leads.
May 15, 2017 | Lincoln Cars & Trucks
Lincoln 305g kick out breaker with just 4.5 inch grinder
Have you tried another grinder, or a heater is a good test.
Could be a weak breaker. I use a 1500 watt heater to test outlets with.
Feb 10, 2015 | Lincoln Ranger 305g Welder Generator...
What can happen when welding on frame of chrysler truck 1500 with 5.9 engine.
Many electronics have power running to them all the time and are ground controlled, sounds like you blew an electronic component in one of the modules, ECM, BCM, etc... should also disconnect the negative cable while welding to prevent arc'ing back through the electronics.
Oct 17, 2014 | Dodge Ram 1500 Cars & Trucks
Can I run a millermatic 252 mig welder off of a ranger 305 g auxillary power outlet?
not sure what a ranger 305g is but a mig welder of that size would require an output of at least 10kva from a generator maybe more due to the start up current
Oct 27, 2013 | Welding Tools
Lincon 305g welding machine wont go on high idel
You may have this posted in the wrong product category. Please select another category appropriate to the problem and re-post the problem so the correct expert will see and respond to the question..
This is for car and truck problems related to Factory Installed Systems not add on aftermarket systems.
This post can't be removed or moved, please re-post the question in the correct product category. Thanks
Nov 01, 2012 | Cars & Trucks
Engine oil leaks out the gasket between cases how will i repair
Two options here:
1) The one i will suggest... send it to an authorized repair shop. Check with your local welding shop/store (Praxair has direct connection with the anywhere), they will ship it down to an authorized dealer.
2) If you are a mechanic or know how to change head gaskets, then take model and serial number of your engine (p.e.Kohler, onan or honda) and go to a autoparts shop and ask for the gasket, then just replace it.
Feb 06, 2011 | Lincoln Ranger 305g Welder Generator...
I have a 305g machine runs gen works i do not get any read out from the displays
If it is a digital, you need top replace it. They burn pretty easy with overloads.
Dec 24, 2010 | Lincoln Ranger 305g Welder Generator...
My pc control panel is out . I need a new one . Where can i get a new one.
At a welding supply store or business. The can order it or repair it for you. A place that sells welding gases.
Apr 24, 2010 | Lincoln Electric Ranger 305G K1726-4...
What size battery goes in a 305g?
Group 58 battery with 435 cold cranking amps. Page 3 in pdf manual.
Here is a pdf manual site for your welder...
http://content.lincolnelectric.com/pdfs/products/literature/e6117.pdf
Mar 05, 2010 | Lincoln Electric Ranger 305G K1726-4...
Lincoln Electric Ranger 305G K1726-4 Welder Logo
52 people viewed this question
Top Lincoln Welding Tools Experts
Steve
joe2639
Level 1 Expert
Are you a Lincoln Welding Tool Expert? Answer questions, earn points and help others
