Question about Bang and Olufsen Beosound 4000 Shelf System
How can I remove central cd clamper and control panel assembly in order to clean guides
Glass doors are not opening.
  • 122 Answers
Remove glass doors and glossy black panels eight screws will remove the central section disconnect clamper top l/h corner from mech.a new cam lock wheel is often required it sits on top of main cam wheel
Posted on Jul 02, 2014
Why are there brown/white streaks inside oven door glass after using self cleaner 1 time?
Thank you for your post, friend!
From my understanding after you used the self-clean feature on your Frigidaire range you now have brown and white streaks on the indoor glass. Typically streaks can be removed by cleaning the interior glass. Normally it is recommended to have a professional clean the inside glass but a consumer can do it as well. Use caution when following the steps some pieces can have sharp edges. You will need to have a Phillips head screwdriver or small quad bit driver.
A. Refer to owners guide for instructions on how to remove oven door.
B. With door in broil stop position lift door assembly off hinges.
C. Lay door on table, position so that handle hangs freely over edge of table
D. Remove 2 screws and washers that secure handle to lining assembly.
E. Remove 8 screws that attach textured steel door wrapper trim to lining assembly 3 at top, 3 at bottom, 1 on each side
F. Lift door lining up and out of wrapper trim assembly.
G. Lay lining assembly on table with wool shield/inner part of lining facing up.
H. Remove 2 glass clamps via 2 screws per clamp. These clamps attach innermost clear glass to wool shield.
I. Lift out center clear glass from wool shield, this glass just lays onto the wool shield and is held in place by the glass/ clamps in item H.
J. Clean each glass with appropriate cleaner.
K. One glass that remains in door lining assembly can at this time be cleaned without further disassembly the lining assembly.
L. Reassemble in reverse order.
Hopefully this is helpful. -Matt
Aug 23, 2014 | Frigidaire 30" Self-Cleaning Freestanding...
Frigidaire oven door glass clean inside
Good Morning Suzi - Generally, qualified technicians often perform complicated part replacement such as this, however this may or may not be specifically for your model. Below are generic instructions that I found on how to take your oven door apart to remove any stains that may be caught down in the door vents.
Tools needed: Phillips head screwdriver or small quad bit driver.
A. Open Door remove 2 screws and washers on door lining at door hinge area.
B. Refer to owners guide with door in broil stop position lift door assembly off hinges.
J. Clean each glass with appropriate cleaner, Windex, bon ami, fantastic, etc
I hope this information helps to some degree.
May 24, 2013 | Frigidaire 27 in. Electric Double...
How do you put door back onto Electrolux wall oven......Been trying for hours, no success!
Hello paulascor549 - I completely understand that you took the oven door apart to clean it, therefore you must have took the following steps to do so. According from my research you would have to reassemble in reverse order. If you have already tried to do so and it proves to be ineffective, contact a professional to move forward accurately.
Door Removal and Cleaning of Interior Glass
B. Refer to owners guide? With door in broil stop position lift door assembly off hinges.
Nov 24, 2012 | Electrolux 30" Built-In Single Electric...
Machine light turns on, cycle light blinks, door is closed but the door lock light doesn't come on and washer won't start. Code shows f dl?
The door lock and switch assembly has failed. You may actually hear it click several times before the code appears. If not, it may not be receiving power or signal from the central control unit to activate.
Disconnect power to the washer to avoid electric shock.
Remove the three screws from the rear of the top panel attaching it to the cabinet then slide the panel rearward, and then lift it off the cabinet.
Disconnect the third and the fourth from right, facing the front of the washer, wiring harness connectors from the central control unit. Clean the connector terminals thoroughly then reseat it several times to ensure a good connection between them. Do the same with the connector second from the top on the left side of the central control unit.
After ensuring that the connectors are properly connected, slide the top panel back in place, and then secure it the three attaching screws.
The next thing to do is visually check the door lock and switch assembly for physical damage.
Remove the wire and spring assembly that holds the door gasket to the lip of the door opening. Use a pair of needle-nose pliers to stretch the retaining spring then remove it together with the wire.
Gently peel the part of the door gasket near the door lock/latch assembly off the lip of the right side of the door opening. Remove enough of the door gasket to access the door lock/latch assembly behind the front panel.
Remove the three screws securing the door lock/latch assembly to the front panel and slightly lift it then pull it back off the front panel.
Pull the door lock/latch assembly out of the washer and disconnect the wiring harness. Clean the terminals and reseat it several times.
To replace the door lock and switch assembly (part #8182634); connect the wires properly then secure the assembly into position behind the front panel with the three securing screws.
Put the eased part of the door gasket back in place over the lip of the door opening.
Check that the door gasket is properly seated before securing it with the retaining wire and spring around the lip of the door opening and the door gasket.
Mar 13, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Bang & Olufsen BeoSound 2000 door doesn't open (disconnected)
Push the door to the left this normally engages the door to the mech.it is designed to detach if the door is jammed or too stiff to move.Cleaning of the guide rail and door carrier is usually the cure.this can only be done properly be removing the central cd clamper and control panel assy.
Dec 31, 2009 | Bang and Olufsen Audio Players & Recorders
My cd changer is say disc error and it wont close all the way in and there is no cd inside of because i took it out
If the door will not close or go to home posistion then one or two things has happened, 1. the Unit is out of timing squence and needs to be retimed, this happens when someone pulls on the door while it is opening just one gear tooth out of sequence will cause malfunctioning. 2. The elevator or clamper is not open so the tray can not slide between the spindle motor and the clamper assembly, this usually comes from either a bad or weak belt on the load assembly or worn gear on the elevator or clamper assembly. Open the unit and close the door to check function the disc, should slide between these parts to play, if the door is not closing then you will see why or what is not working or blocking the tray.
Dec 15, 2009 | LG LHT764 Theater System
Glass door will not open and cd player will not rise to place cd in position
Glass door and cd clamper operated by same motor belt and mechanism,remove l/h sp. grille (2 screws) and this mech is easily visible.
Nov 27, 2009 | Bang and Olufsen Beosound 2000 Shelf...
How do I remove and install a rear passenger side window (manual) in a 1997 Saturn SL1?The window was smashed, and I need to replace it. Thank you so much for your time and help!
Saturn Coupes/Sedans/Wagons 1991-1998 Repair Guide
Door Glass and Regulator - REMOVAL & INSTALLATION
(see Figures 1, 2, 3 and 4)
  1. Remove the outer door panel assembly. Refer to the sub-procedure under Door Locks, earlier in this section.
  2. For rear doors, loosen the bottom fastener of the rear door stationary window assembly, in order to provide clearance, then apply tape to the lower half of the outboard exposed portion of the stationary window channel. The tape must be applied in order to prevent damage to the paint surface.
  3. Lower the door glass, then use SA9148B, or an equivalent tool, to remove the glass nuts. Push the glass upward and rotate slightly, then remove the glass from the vehicle.
  4. If the regulator is also to be removed, proceed as follows:
    1. Remove the inner door trim panel. Refer to the procedure earlier in this section.
    2. If applicable, unplug the wiring harness from the power regulator.
    3. Except for the rear door, remove the regulator cam bolts.
    4. Drill out the regulator rivets and remove the regulator from the vehicle.
To install:
  1. If removed, install the regulator to the door assembly:
    1. Position the regulator to the door and secure using rivets.
    2. Except for the rear door, install the cam bolts.
    3. If applicable, connect the wiring harness to the regulator.
    4. Install the inner door trim panel to the vehicle.
  2. Install the door glass into the door and over the regulator studs.
  3. Install the glass nuts using tool SA9148B, or equivalent.
  4. Check the door glass for proper operation and alignment.
  5. If necessary, adjust the glass alignment. For rear doors, fore/aft adjustments are made after loosening the B bolts, while in/out adjustments are made when the A bolts are loosened.
  6. Except for the rear doors, glass which is not running parallel to the door header may be adjusted after loosening the inner panel cam attachment bolts and adjusting the cam. If the glass is floating in the opening, lower the glass 3 / 4 downward, loosen the front guide fasteners, push the glass rearward to seat it in the rear channel, then bring the front glass guide back to the front edge of the glass. Apply a light finger pressure on the guide and tighten the fasteners.
  7. Once the glass has been properly adjusted and is operating smoothly, install the outer door panel assembly.
Fig. 1: Remove the glass nuts using a suitable tool-front door shown
Fig. 2: Exploded view of the regulator mounting-except rear door
Fig. 3: Exploded view of the rear door regulator mounting
Fig. 4: Adjustments of rear door glass are made after loosening the A or B bolts
I hope help with this (remember rated this help) Good luck.
Oct 16, 2009 | 1997 Saturn SL
How do you replace a drivers side window on a 1992 Saturn
See Figures 1, 2, 3 and 4
To install:
PICTURES ON NEXT POST!
Oct 13, 2009 | 2000 Saturn Ls 4dr Sedan
I got a response regarding the regulator however I cannot see it - where do i find a free diagram of the inside of the door where the motor is
  1. Remove the door trim panel and watershield.
  2. Remove the inside door belt weatherstrip and glass stabilizer.
  3. Remove the door glass.
  4. Remove the 2 nuts attaching the equalizer bracket.
  5. Remove the rivets attaching the regulator base plate to the door.
  6. Remove the regulator and glass bracket as an assembly from the door and transfer to a workbench.
  7. Carefully bend the tab flat in order to remove the air slides from the glass bracket C-channel.
  8. Install new regulator arm plastic guides into the C-channel and bend the tab back 90°. If the tab is broken or cracked, replace the glass bracket assembly. Make sure the rubber bumper is installed properly on the new glass bracket, if applicable. CAUTION
    If the regulator counterbalance spring is to be removed, make sure the regulator arms are in a fixed position prior to removal. This will prevent possible injury when the C-spring unwinds. To install:
  9. Assemble the glass bracket and regulator assembly.
  10. Install the assembly in the door. Set the regulator base plate to the door using the base plate locator tab as a guide.
  11. Attach the regulator to the door using new rivets. 1⁄4 in.–20 x 1⁄2 in. bolts and nuts may be used in place of the rivets to attach the regulator.
  12. Install the equalizer bracket, door belt weatherstrip and glass stabilizer.
  13. Install the glass and check for smooth operation before installing the door trim panel.
03b3db6.gif Posting a diffent one also because I don't know what your first original post was.
May 17, 2009 | 1993 Ford Explorer Limited
128 people viewed this question
Top Bang and Olufsen Audio Players & Recorders Experts
 Grubhead
Grubhead
Iluvintage
Level 1 Expert
Are you a Bang and Olufsen Audio Player and Recorder Expert? Answer questions, earn points and help others
