Question about Home Security
How do you reprogram lift master 1/3 h.p. model 1250lm
Trying to change code for garage opener with out having to replace unit
SOURCE: Lift-Master garage door opener Model 1045-6 1/3 hp
There is a thermal cut out in the motor, usually the motor must cool before the opener will operate again. If the opener only operates 3 times it must be heating up too quickly.
First you opener is only made to do your job for you, which is opening and closing the door. If the door does not operate properly manually the opener will not operate properly.
When the door is disconnected from the opener it should lift easilly, it should basically stay at whatever point you let go of it (midway and fully open) and it should close without slamming down. It does not matter what size the door is!!! If it does not something is wrong with your springs and the door can be VERY DANGEROUS!!
With that being said it sounds more like a static lock-up possibly a loose ground or even a circuit problem in the home.
Bryan
Posted on Jun 28, 2008
  • 3197 Answers
SOURCE: trying to reprogram garage door opener
It's on the rear of the motor unit. Just below where all those white wires go. You will have to remove the light lens first.
Posted on Feb 13, 2010
  • 16 Answers
SOURCE: chain gear is stripped//garage door opener //lift master 1/3 hp
I made a webpage that includes the instructions that come with the gear kit. How to replace the gears, reset the travel settings, lots of pictures, part lists and numbers.
http://tinyurl.com/gearfix
Posted on Mar 29, 2010
  • 3197 Answers
SOURCE: Chamberlain Lift Master Pro Formula 1 only makes click sound
Is the door stuck in the open position? If so the trolley is probably jammed against the bolt just in front of the motor unit. Loosen the chain enough to free the trolley and then run the opener until the door is closed. While the door is closed locate the 'up limit' on the side of the motor unit and turn this control 2 complete turns in the opposite direction of the arrow printed on the cover. Tighten the chain.
Posted on Apr 05, 2010
  • 3197 Answers
SOURCE: remote code for a merlin power lift
I think you will have better luck checking around the Australian forums for help with this door opener.
Posted on Apr 14, 2010
I have a neighbor that can open my garage door with their remote. Can I change my code to open the garage door
Yes.
How to do it depends on make and model.
Get that information from the Garage door opener (this should be on a sticker on the outside of the unit; most likely on top so you'll need a ladder) and you can go on line to the manufacturer site and find the information on resetting the codes.
You will reset it on the Opener first; then you have to "retrain" your remotes and keypad to work with that new code. If this unit has been in place for a few years, it's a good time to replace your remote batteries also.
Jun 17, 2016 | Building Materials
Previpus owner didnt supply 4 digit cide to sears garage door opener keypad
Simply call a local garage door service center and take your keypad into them and they will be happy to show you how you can do it. It usually involves having to push a button up on the back of the garage door closing unit so the device can pick up what is a "rolling code" instruction and the unit will work just fine for you. Just remove it and be sure to know the model number of the opener too before you go.
Dec 20, 2013 | Building Materials
How to change the code on Craftsman 139 53879 garage door opener?
The model number you give is for a remote unit. You cannot change the code on this. What are you trying to do? There may be other possibilities.
Sep 03, 2011 | Sears Craftsman LiftMaster Chamberlain...
I have a SecuraLift Garage door open. The door will not open with the remote or on hte wall device and the status light is flashing... Can I fix this or do I have to call for the door to be serviced? AND...
Many of these devices use a code that changes each time the door is opened and closed. This feature is used to keep potential bad people from learning your operational code and entering your garage. You may have a communication problem whereby the Garage Opener needs to be reset. You may try to change the settings. If you have dip switches on the main unit in the garage, change the dip switches to another setting and write down the numbers in the order that you have the set them, Then go to the remotes, hand held and hardware placed on the outside door, and change the settings on these devices to MATCH up with the inside unit. This is a good time to REPLACE the batteries also.
Feb 20, 2018 | Chamberlain Powerdrive PD422D 1/2 HP...
Garage door will only close with keypad code it will not open
UNPLUG THE UNIT AND WAIT 5 MIN.
WHEN YOU PLUG IT BACK IN CLAER ALL CODES BY HOLDING DOWN THE PROGRAM BUTTON FOR 20 SECONDS.
NOW TRY TO PROGRAM EACH REMOTE AND KEYPAD - IF THERE IS STILL A PROBLEM CHANGE THE BATTERIES AND REPEAT THIS PROCEDURE.
I HOPE THIS HELPS
Mar 31, 2009 | Sears Craftsman LiftMaster Chamberlain...
Outdoor keypad frequently doesnt work
IF REPLACING THE BATTERY DOESN'T DO IT YOU WILL NEED TO REPLACE THE KEYPAD.
NOTE: (IF YOU HAVE A ROLLING CODE SYSTEM) YOU WILL NEED TO REPROGRAM THE UNIT AFTER YOU CHANGE THE BATTERY.
HOPE THIS IS HELPFULL
Jan 19, 2009 | Sears Craftsman LiftMaster Chamberlain...
I have a non-functioning keypad for my Liftmaster garage door. It's 8 years old. In the past changing the battery has remedied the problem. This time I changed the battery twice with no success. The light...
First of all, did you try recoding unit by hitting LEARN BUTTON on motor. Try that. If n/g, try a new code with a number you did not use. Example, if old code was 5834, try 2222. If it works, one of the numer from you old code is worn out. Try new code or buy new pad.
Jan 14, 2009 | Sears Craftsman LiftMaster Chamberlain...
Keypad garage door opener will not operate
what keypad are you using with new opener? Frequency has changed. can't use old one. you probably never needed to change things; just needed to follow proper coding procedures.
Dec 16, 2008 | Sears Craftsman LiftMaster Chamberlain...
Home Security Logo
123 people viewed this question
Top Home Security Experts
Lawrence Oravetz
Are you a Home Security Expert? Answer questions, earn points and help others
