Question about Radio Shack Pro-82 Scanner
Scanner not picking up channels
Channels are in but not talking
I have a pro-528triple trunking with 1000 channels.brand radioshack.serial no;74009508.fcc id07a07.can i fix my scanner to pick up scured channeles are modify it to pick up cell phone conversations i can...
Sorry, but the answers to your questions are no and no. Modern scanners are what they are, and they cannot be modified to monitor any secure (encrypted), digital, or cell phone communications. There is no magic fix to convert an analog scanner to digital. If you want to listen in to digital communications you'll need to purchase a digital-capable scanner, but that will still leave you without cell phone coverage or the ability to listen in to whatever secure transmissions you're referring to.
Bill B.
Listening in since the 60's
Jan 22, 2011 | Uniden BC60XLT-1 Handheld Scanner
How do i unlock my two way so i can scan and pick channels
The scan function on an XTN is not to be a scanner, but to scan between channels you have programmed into the radio. The scan feature is only available on the 2600 series. You can manually go to each channel and look for or listen for channel activity. Start with channel 1, when someone else is talking, there is a "busy" indication on the LCD on the radio. You can listen in by pressing the Monitor button. If you are using the factory defaults, you may hear someone without pressing the Monitor button.
Jan 21, 2011 | Motorola XTN UHF Two-Way Radio Series
L/o on the screen only picking up 1 chanel
Do you have frequencies programmed into the other channels? Use the MANUAL key to advance through the channels. If each shows a frequency of 000.0000, you need to program the scanner. It will automatically show LOCKOUT for each unprogrammed (000.0000) channel.
Bill B
May 10, 2010 | Uniden BC60XLT Handheld Scanner
Uniden 30 ch scanner i have locked out all channels.
Each channel with the zeroes means that it is a blank - with nothing programmed into it. Going to any one of them and programming a frequency will get rid of the zeroes and switch off the lockout. It's picking up weather, so it's working. Sounds like you just need to find and program active frequencies for your area, and the place to find them is:
www.RadioReference.com
If you need it, you can download and print the manual for the BC60XLT-1 here:
http://www.uniden.com/pdf/BC60XLT-1om.pdf
Bill B
Apr 08, 2010 | Uniden BC60XLT-1 Handheld Scanner
Pro96 PROBLEM
http://www.police-scanner.info/police-scanner-frequencies.htm you may need to put in the new freq. # a few months ago most went to new freq. #
Jun 14, 2009 | Radio Shack Pro-96 Scanner
V-scan channels missing
Sounds like all that is happening is that the channels are locked out, you need to go through manually and unlock them. I have the same scanner and that is what I needed to do.
Feb 12, 2009 | Radio Shack Pro-96 Scanner
Uniden Bearcat BC60XLT 10 Channel 10 Band Radio Scanner with L/O on every channel #
http://www.uniden.com/pdf/BC860XLTom.pdf
Here is the link for your scanner manual. In it you will find everything you need to change the lock out and also to inpout channels and what not
Feb 10, 2009 | Computers & Internet
I have a radio shack pro 96 digital trucking scanner.the other day we finally put up my outside antenna for it.it worked fine all through xmas and new years.the other day turned it on and it would not pick...
The very part of your scanner that makes it a scanner is inop. YOU can find it but IT won't scan. Back to radio shack for warranty before they change their mind.
Jan 09, 2009 | Computers & Internet
Radio Shack Pro-82 Scanner Logo
Top Radio Shack Radio Communications Experts
John
John
Greg Cann
Greg Cann
Jason
Are you a Radio Shack Radio Communication Expert? Answer questions, earn points and help others
