Question about Numark ttUSB Turntable
What is the "gain" knob for on the TTUSB turntable?
Ringing when recording into mac
This sound like it could be somekind of feedback hum, or earthing problem. Check all the connections.
Mar 14, 2014 | Numark ttUSB Turntable
Need better sound quality from ion ttusb
Have you tried a magnetic cartridge pre-amp?
Mar 12, 2013 | ION Audio Vinyl Recording Turntable
Volume is too low even with Gain turned to maximum. Also talking during recording gets picked up on the recording.
Your computer sound controls govern input volume and the use of a microphone. If you have a mic, find the control and turn it OFF.
Mar 04, 2011 | ION Audio TTUSB 10 Vinyl Recording USB...
Im new with the use of the record player since im tired of MP3's. i bought a Numark TTusb turntable connected everything, but the sound is low. i have to crank the volume to the max, and only get low...
A turntable use a magnetic cartridge and its output is only 5 to 10 millivolts.A moving coil cartridge is even lower,.2 to .5 millivolts(thats 1/2000 of a volt)in contrast, a mp3 puts out a 300 to 900 mv signal..so does a CD player. Your turntable does not have enough signal.You need to get an amplifier that has a phono input. Years ago,radio shack used to sell phono preamps that could plug into a tape or cd input.The other option is to buy a used mixer that has a phono input.The mixer output can drive the cd input easily,as the max output from a mixer is 1.5 volts to 2 volts.
Dec 30, 2010 | Numark ttUSB Turntable
I need to remove platter on ttusb ion turntable to fix belt... it has slipped off... thanks in advance for your help
I do not know the particulars of your turntable, but in most units, you take off the rubber pad on the platter, and that will give you access to the metal dish, which has holes to gain access to the belt pulley. Slip off the belt, and then you will be able to pull up the metal dish. After you replace the belt, reverse the procedure. Just make sure that the belt is close to the pulley before you insert back the metal dish.
Mar 14, 2010 | ION Audio TTUSB10 Turntable
Tonearm Weight, Good Replacement Stylus, Gain level
Most good turntables will track with weights between 1.25 and 1.5 grams. Any more than that and you are putting alot of pressure on the needle. Experiment a bit and make sure that the needle tracks well and that the sound is good. The less weight you use, the longer the needle will last and the less wear on the record.
Dan
Aug 11, 2009 | Numark ttUSB Turntable
HOW TOTRANSFER FROM CASSETE DECK VIA ION USB TURNTABLE
I'm thinking this is 100% impossible. There is absolutely no way you can get a cassette tape to play on a turntable.
Apr 07, 2009 | ION Audio Vinyl Recording Turntable
Not hearing songs I transfered to my i tunes from my Numark TTUSB
Open Preferences, Sound, your input should be  USB Audio Codec (turntable).. make sure your output is NOT USB Audio Codec, rather, headphones (for external speakers plugged in there)... thats how i have mine set up...
Jan 07, 2009 | Numark ttUSB Turntable
Numark ttUSB Turntable Logo
52 people viewed this question
Top Numark Audio Players & Recorders Experts
 Grubhead
Grubhead
Colin Stickland
Colin Stickland
Are you a Numark Audio Player and Recorder Expert? Answer questions, earn points and help others
