Question about Western Digital WD Passport 250GB Portable Drive 250 GB Hard Drive
Files pending back up on wd passport - Western Digital WD Passport 250GB Portable Drive 250 GB Hard Drive
SOURCE: WD Passport
i need the instalation
Posted on Oct 05, 2008
SOURCE: WD Passport Essential 160gb with PowerBook G4
The problem is that your powerbook G4 does not provide enough power to your 160gb passport HD. This does not happens to the new Macs with intel inside.
There are several ways to fix it:
1) Go to West Digital Website and buy a "Power Buster Cable USB" (that connect your 2 USB ports to your passport HD in order to provide more power). I think that it costs 10$. This is the link: http://www.wdc.com/en/products/accessories.asp?ProdID=170
2) The other solution is easier. If you have an external USB hard drive with two USB ports, or a DVD/CD burner with two usb ports, you can pug your passport in one of the ports while the other HD or DVD/CD burner is connected to you PowerBook. You will be able to see and use your q60gb Passport HD.
Posted on Oct 25, 2008
kim_cu
  • 70 Answers
SOURCE: can't load a 13 gig avi file onto wd drive with 90 gigs free
Typically this is because there aren't large enough fragments to load. Run defrag several times and try again. You might also run the cleanup program and remove any temporary files, temporary internet files and anything in your waste basket before you run defrag.
Please let me know how this turns out.
Posted on Nov 23, 2008
SOURCE: WD Passport will not accept transferred files anymore.
usb
not recognize
Posted on Dec 07, 2008
  • 916 Answers
SOURCE: WD passport 320GB Can I use it as storage, not backup?
You can use it as storage if you would like. You can also delete files once they are put on the passport. When it is connected to the computer open my computer and it will be listed there. You can use it as storage by copying files into this way rather than syncing it. Syncing it could cause you to lose files.
Posted on Apr 29, 2009
Hi , I just copied my hard drives to my new Passport Essentials SE using the WD Smartware software, I do not like I have to manually switch between my two internal hard drives to back up so I would like to...
As far as I remember WD just copies the software into the PassPort drives and you don't have to install anything you can just run the software from the drive. If that is still the case then first take a backup of that software (basically copy that software folder to some place in your internal drives) then format the drive (make sure you select NTFS as the file system for the drive when formatting).
Formatting will erase all the files in the drive so make sure you have backup of you personal files also.
Formatting also resets the drive back to factory setting (if you want the WD software back then just copy it from the backup to the PassPort drive).
Sep 06, 2011 | Western Digital WD Passport 250GB Portable...
Tip
Western Digitial Passport Sync Software
WARNING: Do not think that theyourWD Passport, using the WD Sync software, is a backup drive; it is NOT !
As per the documentation with this device:
"synchronization software is intended to synchronize the data from a computer to the drive (WD Passport) and SHOULD NOT be used as backup software. To use this software properly, we advise that you do not wipe or
erase the data from the internal hard drive (computer) and resynchronize, as this will cause the data that WD Sync stored to the Passport to be deleted."
This is why you are hearing so many people saying that they are deleting the WD Sync software, reformatting, and using the WC Passport as a true backup drive where you can actually see the files that you are backing up, rather
than a bunch of unrecognizable sync files that likely don't have all the files that you thought you "backed up".
on Jan 18, 2009 | Western Digital Passport WDXML800UE...
Hi I recently installed nero backit up on my laptop. At the time my WD passport was plugged in and Nero asked if I wanted to use the WD as back up, I said yes to this.When I plugged in my WD passport laet...
First stop using the drive. If you do use it Windows may overwrite your data with any new files you create.
To recover your data you can try a program like Recuva. http://www.piriform.com/recuva
If that does not work you will need data recovery help. This guy does it remotely over the internet and works off of donations. http://FreeDataRecovery.us
Jul 14, 2011 | Western Digital WD Passport 250GB Portable...
I forgot my password how can I open WD passport?
This one way for unlocking your WD passport but assume you will lost your data
Download wdsmartwareupdate here : http://www.wdc.com/wdproducts/wdsmartwareupdate/
Download instructions :
1- Locate you WD disk entry, click on Windows or Mac according to your operating system.
2 - Click on Download now link at the bottom and download the soft.
Unlock instructions :
1- extract the zip file you've downloaded en run the.exe.
2- select Continue to update and accept Licence Agreement.
3 - Next select Update Firmware
4- Check the check box "I understand ......" under Warning section, a button "drive erasure" will appear.
5- Click on drive erasur button
6- Wait until the end of the process and quit
7- Unplug/turn off the passport and plug it back in. Your WD passport is unlocked
Dec 16, 2009 | Western Digital Passport WDXML800UE...
I don't know how to check the files on my WD passport. I'm looking just for pictures and itunes. Can you tell me how this is done?
you plug the drive into a usb port.... if it doesn't automatically pop up to allow you to access the drive... go to my computer (or computer on vista) and go in there... it should appear as another drive. double click and you are in the drive.
Robert
Jan 16, 2009 | Western Digital Passport WDXML800UE...
My passport "removes" my files!
Recover western digital passport "sync-data"
You need to have the WD Sync program on your computer; you can get it from your WD Passport, or, over the Internet. Once you have the software on your computer, you can synchronize. WARNING: Do not think that theyourWD Passport, using the WD Sync software, is a
Dec 24, 2008 | Western Digital Passport WDXML800UE...
Oct 21, 2008 | Western Digital Passport WDXML800UE...
Can I use my passport essential 2.0 to backup my work computer as well as my home computer?
You can use your WD Passport to sychronize data on multiple computers, you just need to set up the other computer name (e.g. "Work computer")using the software.
Aug 03, 2008 | Western Digital Passport WDXML800UE...
Western Digital WD Passport 250GB Portable Drive 250 GB Hard Drive Logo
443 people viewed this question
Top Western Digital Computers & Internet Experts
Arora Singh
Arora Singh
Alun Cox
Marcin
Are you a Western Digital Computer and Internet Expert? Answer questions, earn points and help others
