Question about Haier HTQ21JAAWW Top Freezer Refrigerator
Haier fridge won't start after unplugged
Just cleaned and defrosted the fridge .... Now it won't start back up after I unplugged it
2 Suggested Answers
SOURCE: What's the coldest setting on a Haier mini fridge?
Hello, 7 should be the coldest setting
Posted on Jun 03, 2011
How do i defrost haier hnde03vsbj fridge?
Leave it off for 24 hours. Clean out the water and start it up again.
Aug 07, 2014 | Haier Compact Small Refrigerator 1.7 Cu.ft...
Haier HSW02C runs ALL the time
Yes your thermostat is shorted. It's just not shutting the unit off ever. A thermostat is something you can touch as a user, so no it's not that hard to get to for replacement. Also have the unit unplugged while learning how to repair your appliance.
Apr 27, 2013 | Haier Refrigerators
MY HAIER 1.7 FRIDGE FREEZES ONLY
my trf 285 intergrated fridge freezer has same problem fridge is freezing our food have been informed that a valvue is stuck open the solution
offered was defrost and leave for 2 days i did that it did not work the valvue is not replaceable hope this is some help
Jan 21, 2013 | Haier Refrigerators
Fridge not getting cold.....still
Hello Nick,
Don't let your frustrations get the best of you...
WE can do this...!!
Defrost consists of only three (3) parts...
- Control board (or timer, not in your case:
(see below)).. A common problem.
- Defrost heater element (to melt the "FROST"
(seldom fails)
- DEFROST THERMOSTAT
(to keep the temp DOWN)
The EASIEST but most expensive part is the
DEFROST control board.
Take lots of pictures before removing any wires.
Main Electronic Control Board
Mar 07, 2017 | GE Profile PDS22MHR Bottom Freezer...
I have an Amana (ABB2524DES) bottom freezer fridge. The fridge is not cooling but the freezer seems fine. I just took the back cover off and the fan is working. I cleaned everything and put it back...
Its defrost problem, the freezer should cool, then freeze, then defrost cycle should start. In your case freezer is cooling, then freezing, but its not defrosting. That's why fridge section is not cooling.-------
Click this link below and follow the troubleshooting:----
http://technoanswers.blogspot.com/2011/06/refrigerator-is-not-cooling-properly.html
This will help.Thanks.Helpmech/.
Oct 30, 2011 | Amana ABB2524DE Bottom Freezer...
My Haier model HBF05EBSS-01 will not cool below 50 degrees F.
DEFROST PROBLEM
The evaporator coil behind the cover on the back wall inside the freezer will ice up under normal conditions. Every 8 to 10 hours for around 20 minutes the defrost timer (or in most newer models the electronic adaptive defrost control) will turn the defrost heater on to melt the built up ice. There is a defrost thermostat which prevents the heater from overheating the freezer by breaking the heater circuit when the temp reaches close to 32 degrees F. The entire cooling system shuts off during the defrost cycle and starts back when the timer advances through the cycle.
If this ice is not melted it will continue to build up until the air can't flow over the coil to circulate the cold air through the freezer and into the fridge. The temperature change in the fridge is usually noticed first followed by the freezer.
If the defrost thermostat is bad, it can prevent the heater from coming on OR it won't turn the heater off when it gets too warm. It is clamped to the evaporator coil at the top to sense the temp. If it appears to be misshapen it is bad.
With an ohm meter it should show continuity when cold and none when warm.
You can also bypass(disconnect the two wires plugged into it and twist them together) the thermostat to see if the heater comes on then. If it does then you know the thermostat is bad and needs replaced.
The defrost heater is located on the evaporator. It is in a tube which is at the bottom and can also go up the sides of the evaporator. On some types you can see a burnt spot if it's bad. With an ohm meter it should show continuity from end to end when disconnected from the wiring in the freezer. You can also test the wiring for voltage when it's in the defrost mode.
If you have a defrost timer you can test it. It can be located under the fridge behind the kick panel on the front. Some are in the fridge with the controls at the top. You can turn the defrost timer till it clicks and everything shuts down. The heater should now come on. If it does, replace the timer because that means the timer is not running. If it doesn't, check the heater and defrost thermostat. Turn the timer again till everything starts back up to end the defrost cycle.
If you have an adaptive defrost control instead of a timer, replace it if the heater and thermostat test good. It is located in the fridge with the controls in some models and on the back in others.
Aug 24, 2011 | Haier SS Half Kegerator
Refrigerator not cooling at all. slowling died over a period of a few days. light still works though.
DEFROST PROBLEM
Aug 11, 2011 | Haier HRE10WNAWW Refrigerator
Fridge won't cool below 60, freezer won't go above 20
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
Aug 08, 2011 | Refrigerators
Haier Model HNSB02, Serial # 1005006483--Not keeping within 36-46 degree temp inside. Adjusted dial on rear of model-is higher number colder temp?
I'm Leo
Yes higher numbers are colder
First I would check the fan in the freezer. Listen to see if it is running
It moves air to the ref from the freezer
Then check to see if freezer control is turned WARMER, which makes the Ref. colder
Also this might be a common Defrost problem, Ice
is not being melted by the defrost system.The fan can't blow through the coils into the fridge.
Take out back panel of freezer to check for ice buildup. The coils should be clean.
There are three components to a defrost system- a heater,heater thermostat, and a timer unless you have a defrost electronic card.
Its best handled by a Technician but you could possibly do it by taking your model number to the nearest appliance parts store and asking for the parts. They are mostly located in freezer ,behind back panel on freezer coils.except the card which is usually located in ref The parts store will have info
Also check fan undernearh Ref in the rear
Clean condenser coils underneath
.I'm including my article on Refrigerator Repair for your help and convenience.;
Please click or copy and paste into browser for Article
http://www.fixya.com/support/r5816737-fix_refrigerator_psychologically
Thanks for using fixya
Leo Ponder
imufo2
Please VOTE FOR ME IF THIS WAS HELPFUL
Jul 27, 2011 | Haier Refrigerators
My Haier Mini Fridge comes on but keeps nothing cold. I defrosted in August and it worked for awhile and now it defrosted on its own and no longer gets cold.
This could be a bad defrost timer. See if the compressor is working. If it isn`t or only works sometimes. The defrost timer could be bad. When the frig goes into the defrost cycle, turns off the compressor. It may failing to turn the compressor back on after the defrost cycle. Since it stopped defrosting at one point and started again, the defrost timer may be bad. Let me know if this was any help or if I can help any farther.
Nov 12, 2008 | Haier Refrigerators
Haier HTQ21JAAWW Top Freezer Refrigerator Logo
19 people viewed this question
Top Haier Refrigerators Experts
John Tripp
John Tripp
geob91
Vernon Taylor
Are you a Haier Refrigerator Expert? Answer questions, earn points and help others
