Question about Labtec 961307-0914 Webcam
Labtec Webcam I have installed my Labtec Webcam with several attempts but to no avail. It installs it, the icon shows up, the album will show up, but everytime I try to use it it says its not connected. I have re-installed the cam with the repair wizard but it still does not work. I am using a USB port that supports the cam, so I don't understand what the problem is. Any help would be appreciated.
  • 5 more comments
  • desmoe Dec 12, 2007
    i have tried to install the solftware and it just says its not connected and to reinstall
  • my63 Dec 13, 2007
    i HAVE INSTALLED THE WEB CAM SOFTWARE AND THE ICON SHOWS UP ON MY SCREEN BUT WHEN I TRY TO USE IT IT TELLS ME TO RE-INSTALL THE SOFTWARE.
  • booty_meat May 10, 2008
    when i try 2 use my webcam it tells me its not pluged in
  • Anonymous May 10, 2008
    I need help to install my Labtec Webcam
  • Anonymous May 24, 2008
    i have installed webcam but it still does not work. but my computer is saying that it does not detect a webcam
  • Anonymous May 25, 2008
    I downloaded the driver to install my labtec personal Web cam to my pc but it says not connected
  • Anonymous Nov 09, 2008
    i need the driver or to know how to properly install the sriver for win vista business for emachine
    Genius:
  • 2,985 Answers
Check the software installation disk. Sometimes these give several programs to run the thing If you install both programs -as I did once- you will get conflicts or none running. Best thing to do is to remove the software and this time take it easy on the install button.
Posted on Jul 19, 2007
SOURCE:
My labtec webcam is not showing image after intallation
Uninstall the software and also disconnect the webcam from the PC. Now shut down the PC and restart. Check the program list to see if the webcam is uninstalled. Now connect to site and download the drivers of the webcam. Once installed connect the webcam as it will be detected as a new device and will install automatically.
now the Icon must appear for opening the webcam. if not there can be errors in the software or the webcam. Try with another PC to confirm.
May 28, 2011 | Labtec Webcam 1200
Driver for win 7
I think you will be unlucky on this one - check the support website <br /><br />http://www.labtec.com/index.cfm/service/listing/EUR/EN,crid=68,crid2=1764<br /><br />You can contact Labtech from here as well <br /><br />You could try running the webcam in Compatibility Mode <br /><br />If no driver is available try using the older OS software in Compatibility Mode<br />Right click on the webcam icon on your desktop or the webcam file from 'All Programs' - select 'Properties'<br />Select the 'Compatibility' tab<br />Select 'Compatibility Mode'<br />Use the dropbox to show the OS you have successfully used before<br />Click OK<br />Restart your computer <br /><br />
Aug 28, 2010 | Labtec Webcam Pro
I have a labtec 6.0.1 webcam which I want a driver for windows 7. I will not use DriverWhiz because I can buy a brand new webcam cheaper. paul Robinson
Try here
http://www.labtec.com/index.cfm/service/listing/EUR/EN,crid=68,crid2=1764 If no driver is available try using the older OS software in Compatibility Mode Right click on the webcam icon on your desktop or the webcam file from 'All Programs' - select 'Properties' Select the 'Compatibility' tab Select 'Compatibility Mode' Use the dropbox to show the OS Click OK Restart your computer
Jun 07, 2010 | Labtec 2200 webcam
There is no icon for me to show my cam
Yahoo Messenger 10
Actions > More Actions > 'View my webcam'
May 04, 2010 | Labtec 961307-0914 Webcam
Trying to install Labtec drivers for my labtec webcam for Windows 7. It worked perfectly fine with Windows XP and Windows Vista. I updated to 7 and nothing.
http://www.labtec.com/index.cfm/service/splash/AMR/EN,CRID=3
You may have to run it in Compatibility mode if Windows 7 webcam software is not available - I'm sure they can advise you
To navigate to CM on my logitech I rightclick the webcam shortcut icon on the desktop and click 'Properties' and then the 'Compatibility' tab.
Dec 22, 2009 | Labtec 961307-0914 Webcam
My labtec webcam will not show clear i just bought it new and i dont know how to set it to show better video and photo quality please help
Normal 0 How much memory is installed in your computer? The camera uses quite a bit of your memory to operate properly and would cause the poor video. Could be other
Issues, but worth checking.
Hope this helps. Bud
Jan 20, 2009 | Labtec Logitech 1200 Webcam
Lost installation cd for my labtec webcam,any free download sites
Here is the download page for your camera's drivers. A rule of thumb for me is to NEVER use included software/install disks when I buy hardware, you can find them on the manufacturer's website and when downloading you can more easily find different builds (for example, my printer only came with the disks to install the suite of applications, whereas the basic operational drivers were available online).
here is the download site for your webcam brand, just pick out your model, download, and install!
Jan 14, 2009 | Labtec Webcam Plus 0403
The file LV561AV.SYS on logitech USB Video camera Disk is needed
If you have driver/software CD of that webcam, then please try to reinstall it. It might work. If not then...
The same file is also available with Logitech Webcam
This is the site where you can download the Logitech drivers...
http://www.logitech.com/index.cfm/435/4266&cl=us,en?WT.ac=sc|downloads||dd
After downloading all the driver files... you can look for the file LV561AV.sys in it.
This is all I could find.
Please Rate if you find the above info of any use.
Dec 09, 2008 | Labtec 961307-0914 Webcam
LabTec webcam not installing?
can sumone help me plz my labtec webcam 6.0.1 wont work even thou i have the cd for it everytime i install the software i tkeeps tell me da appiction wont work to re intsall the soteware anyone no how da fic it
Nov 29, 2008 | Labtec 961307-0914 Webcam
Lost cd to install labtec cam
i lost my cd how do i fix this???
Nov 02, 2007 | Labtec Webcam Plus 0403
Labtec 961307-0914 Webcam Logo
78 people viewed this question
Top Labtec Computers & Internet Experts
Ekse
Steve Allison
Steve Allison
Are you a Labtec Computer and Internet Expert? Answer questions, earn points and help others
