Question about Microsoft Standard Wireless Optical Mouse
My arrow on monitor froze all troubleshooting says mouse OK
My mouse stopped moving the arrow on the monitor. I restarted and reinstalled the software. I unplugged and reconnected the mouse. I did all the checking and all comes back that the mouse is OK. Batteries OK.
But the mouse remains set as if it is stuck on a piece of cheese......
what is the problem?
  • cablejew Feb 17, 2009
    I did all of this a few weeks ago by myself and somehow it started working, but I don't know what did it.
    President:
  • 8,637 Answers
Normal 0 Turn the mouse over and find the small rest/connect button on the bottom of the mouse and press it. This should connect the mouse to the receiver and work properly. If not, try pressing the receiver button and then press the button on the mouse. This should be done whenever you change batteries or glitch.
Hope this helps you. Bud
Posted on Feb 17, 2009
My acer 15.6inch the cursor is frozen wont move
Which mouse are you using? Is it the integrated mouse or the USB mouse?
If you are using the USB mouse, then try checking if it's plugged in correctly.
If it's your integrated mouse, then restart the computer and when it's up. Try moving your mouse. Restarting it usually does the trick.
If restarting it won't fix the problem, then restart and boot to safe mode. While restarting, tap F8 until you see the options to boot to safe mode. Highlight safe mode by using the arrow keys and hit enter. When you are in safe mode, try moving your mouse. Works or not - update the mouse driver. You can use RadarSync. If no go, then you might need to do a system restore. If worse comes worst, do a complete operating system reinstallation.
I hope this helps!
David
Mar 25, 2013 | Computers & Internet
Computer froze and can not move the mouse arrow. I did try to restart as well but arrow will not move
Does the keyboard work?
Try putting the mouse in another USB port, or even better try another mouse. You might need to let it "install" the mouse first, this can take a minute or so when you boot up, so all you need to do is turn the PC on with the new mouse plugged in and leave it for a while, then try to use it again.
If the keyboard isn't working either, then it sounds like the Operating System is a bit broken! contact me and i'll try to help you fix it.
Aug 30, 2011 | Computers & Internet
Arrow does not move on screen with remote mouse
you might have to uninstall the mouse and its drivers then restart your computer then reinstall the mouse and its drivers
click start control panel mouse you should see 4 tabs buttons,pointers,pointer options and hardware under hardware you can troubleshoot also you can select properties under driver you will have the options update driver,rollback driver or uninstall and under hardware you can troubleshoot
in xp
click start right click on my computer select properties device manager control scroll to mice and pointing devices you might see a yellow question mark? right update driver in
make sure the battery is good (has full charge)also you might test the usb device for the mouse is inserted correctly into the usb port (if applicable)
Windows 7
hope this helps
don
Feb 20, 2011 | Logitech Cordless Mouse
Wireless mouse will not move the arrow pointer,even after replacing the batteries
you might have to uninstall the mouse then restart your computer then reinstall the mouse and its drivers
make sure the lead from the mouse has a secure seating and the lead is not bad/faulty
((if applicable))
click start control panel mouse you should see 4 tabs buttons,pointers,pointer options and hardware make sure you have the correct mouse selected also under hardware you can troubleshoot also you can select properties under driver you will have options to update driver,rollback driver or uninstall and under hardware you can troubleshoot
in xp
hope this helps
Feb 05, 2011 | Computers & Internet
How can I unlock my mouse pad I can't move the arrow and there's a lock picture showing
click start control panel mouse you should see 4 tabs buttons,pointers,pointer options and hardware under hardware you will have the options to troubleshoot also select properties under driver you will have options to update driver,rollback driver or uninstall and under hardware you can troubleshoot
you might have to uninstall the drivers restart your computer then reinstall the drivers
in xp
Jan 19, 2011 | Gateway Computers & Internet
Logitech mouse stopped working when using my right hand on the mousepad. Will work with my left hand on mousepad or anywhere else. Also will work with right hand if I move the mouse pad to another area. ...
click start control panel mouse you should see 4 tabs buttons,pointers,pointer options and hardware under hardware you can troubleshoot also you can select properties under driver you will have options to update driver,rollback driver or uninstall and under hardware you can troubleshoot
in xp
hope this helps
Jan 17, 2011 | Computers & Internet
Reinstalled XP after putting in new HD. Delay issues
Is the HDD same as the previous one? I mean the specs. These laptops are very HW specific while desktops are free of any such problems. Moreover, Did you reboot the laptop before and after reinstalling the mouse drivers? please follow the procedure in the link below:
Installing Devices on PCs and Laptops
May 16, 2010 | Toshiba Satellite A75-S226 Notebook
Dell wireless mouse cursor froze in middle of screen.
Hi, my cursor had frozen on my screen after my grand daughter pressing something. After trying everything I decided to take it to a local computer shop, it was fixed in seconds. He held the arrow tab(below the caps lock tab) and then pressed F9 it worked!!
Hope this will fix your problem
Jul 27, 2009 | Logitech 3-Button Cordless Optical Scroll...
No mouse pointer
disconnect the mouse and reconnect it ....if restart the compuetr and keep tapping F8 and soon as it restarts ...........
select the safe mode wby using ur up and down arrow keys.....
then check if the mouse is moven if the mouse moves then the mouse is ok if not chage the mouse replace of mouse is required....if the mouse works on the safe mode go to control panel and set the mouse propities to default..
Apr 11, 2008 | Computers & Internet
Mouse cursor moving by itself
In windows xp go into start menu, then into control panel then click on appearance and themes, then move your mouse over to mouse pointers click on it , uncheck "enhance pointer precision, and click apply, that will stop the mouse from acting crazy, this will work with dell mouse pointers and most.
Dec 28, 2007 | Compaq EVO N600C (Refurbished) 14.1" LCD...
Microsoft Standard Wireless Optical Mouse Logo
173 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
