Question about Whirlpool LER4634J Electric Dryer
Dryer shts down during load
Model : ler7646dqo serial : mf 0553308 Dryer seemed to be working then it would try to shut down then it would competely turn off. If I waited and turned it back on it would do it again. I took half the load out and it ran. Does that mean motor is going bad.
Have not solved problem but after messing with it more I think that the hi limit themostat may be the problem. It seems like if I let the dryer cool down then try it again it seems to work fine for awhile. Does this sound like something that may cause it to shut down. The load problem didn't seem to a factor for I reloaded it with the original load weight. I have not replaced part yet going to try few more loads soon.
Posted on Jan 27, 2009
I have a Massey Ferguson tractor serial number 9A89879 I would like to know what model it is and what year it is
I cant give you an exact date but it is from the early 70s. That is when they were yellow. My educated guess on this is 1973. If you go to a Massey Ferguson dealer with your numbers they will gladly tell you what year it is exactly.
Jan 27, 2016 | Toys
Masterlink shut down during a CD playback and won't power up at all. No lights, no sound, nothing.
You need a competent tech to look at the possibility that the power supply has failed - seems the most likely explanation
Apr 04, 2014 | Alesis MasterLink ML-9600
Trying to find out what year a Massey ferguson tractor is the serial # is 9 A 108154
1971 and appears to be one of these models. Massey Ferguson Model MF-135, MF-150, MF-165, MF-175 and MF-180
Mar 06, 2014 | John Deere Tractor 1020, 1520, 1530,...
I have a frigidaire affinity dryer serial #xd72014132. It runs for a minute or so and then shuts off and displays e68. The buttons do not seem to be stuck and work properly. Any idea what is wrong with it?
I have a frigidaire affinity dryer serial #xd72014132. It runs for a minute or so and then shuts off and displays pauze. The buttons do not seem to be stuck and work properly. Any idea what is wrong with it?
Sep 20, 2013 | Frigidaire Dryers
My whirlpool dryer (model LER7646DQO) has been making noises when starting up for about a month. The last load I did I removed dry clothes and put a couple of damp items back in, pushed the start button,...
this could be one of two things the heating element that heats the air has broken or the noise you heard was the bushes on the motor going and then they burnt out.
either the heater elements need replacement or most likely the motor needs new bushes or replacing all toghether.
this will need a qualifed engineer to resolve. considering the age of the machine if it is many years old it might be cheaper to replace the machine for a new one. ask your engineer how much it will cost to repair before he starts the work and decide the best action.
I hope this was helpful.
Dec 12, 2010 | Whirlpool LEQ8000JQ Electric Dryer
My whirlpool dryer (model LER7646DQO) wont start when the button is pushed; additionally the timer does not continue to run when the dry with the dryrt off
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Sep 20, 2010 | Whirlpool LEQ8000JQ Electric Dryer
When I push the start button on my dryer it says it is on, but it is not spinning
If the dryer seems to be getting hot and otherwise working (just not spinning), try this test -
Turn off.
With the door open, try rotating the drum by hand.
If it spins easily, and you cannot hear any connection to the drive motor, then it is very likely just the drive belt that needs replacing.
Order a spare for your specific model, and a reasonably competent DIY'er should be able to fit it.
If you are unlucky, and the motor is spinning - just not working, then replace the brushes on the motor as a first atempt at a fix. These are available online, but you will need to quote model numbers.
Again, a competent DIY fix.
If the motor is OK (after testing), then the control board may have a defective (burnt) component that needs replacement - usually by swapping the board with a good one. This repair is for experienced technicians or skilled trades.
Thank you for using Fixya.
Feb 07, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Frigidaire Model FSE446RHS shuts off mid cycle
Hi, If the motor is shutting down mid cycle and can not be restarted untill cooled, the motor will need changed. It is shutting off on a safety overload. These motors cost about $145.00
Please let me know if I can assirt you further.
Vic
Jun 01, 2009 | Dryers
Whirlpool LER4634J Electric Dryer Logo
95 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
