Question about Hand Tools
Can I use this Ryobi Charger?
Can I use the Ryobi One + Chemistry Charger with my 18V Batter #130224007 ?
  • christimiche Jan 29, 2009
    Thanks do much!! My Brother Bought me the recharger for christmas knowing I lost the old one. But when I opened it up it didn't have the old battery listed. I didnt want to wreck the battery.
  • 3 Answers
If you're speaking of the new green lithium battery charger working with the older yellow and black batteries, yes you can. You can't use the OLD charger to charger the New lithium batteries.
Posted on Jan 28, 2009
Can I buy a battery charger for a ozito drill
yes
Search Results
Ozito Power X Change 18V Eco Battery Charger Tool ' Bunnings ...
https://www.bunnings.com.au > ... > Cordless Accessories > Batteries & Chargers The Ozito PXCG-120 18V Eco Charger can be used to charge any of the Power X Change battery packs and includes a charge indication. The Power X Change Eco Charger is a compact and portable design. Charge Time: 1.5Ah Battery - 2.0hours 2.0Ah Battery - 2.5hours 3.0Ah Battery - 4.0hours 4.0Ah Battery - 5.0hours
Batteries & Chargers available from Bunnings Warehouse
https://www.bunnings.com.au/our-range/tools/power-tools/.../batteries-chargers Compare. Ryobi One+ 14.4 - 18V Dual Chemistry Car Battery Charger. Ryobi One+ 14.4 - 18V Dual Chemistry Car Battery Charger. 79. Compare. Ryobi One+ 18V 1.5Ah Lithium+ Battery. Ryobi One+ 18V 1.5Ah Lithium+ Battery. 69. Compare. Bosch Blue 18V 3.0Ah Li-Ion Battery. Bosch Blue 18V 3.0Ah Li-Ion Battery. 119.‎Ozito Power X Change 18V ... · ‎Ozito Power X Change 18V Li ...
Dec 02, 2017 | Drills
I have a P115 Ryobi Intelliport charger , will it charge the new lithium 18 V battery?
Ryobi P115 is an 18V battery charger. However, Ryobi Manual did not mention the current rating of P115. if the current rating of Ryobi P115 is 50% higher than your 18V Lithium Battery it will charge. but if it's less than or equal, it will not.
Nov 29, 2017 | Ryobi Drills
Is there 2 type of battery chargers for ryobi one+ and lithium 18v one +
I just went through this with Porter Cable 18V but I can't say it is the same for Ryobi. On the PC, all 18V batteries are interchangable on the tools, but the charging needs are different. A dedicated NiCad charger can't shouldn't be used for liOn but the later chargers will work for either battery.
Ryobi offers an 18V upgrade:
RYOBI Tools
Jan 02, 2015 | Ryobi Drills
Ryobi 18v battery charger is not charging
If yellow and green light come on and stay on then your battery is bad if not get a new charger
Jul 22, 2014 | Ryobi 140237039 18V Ni-Cd Battery Charger
Will the P110 charger charge a lithium ion battery
No, the P110, 18V NiCad battery charger, will not charge a 18V lithium ion battery. You need one of the dual-chemistry chargers. If you have the Ryobi ONE+ batteries, you can get the P117 charger ($30) or a charger with an extra battery (P126) from a store like Home Depot. A 6 battery charger and a 12V in-car charger are also available.
I wish that I had better news for you.
(who has the Ryobi 12V drill and charger, a few of the 4V tools, and a number of the ONE+ 18V devices and chargers. The single chemistry battery charger is not used much any more.)
Nov 24, 2012 | Ryobi Two 18V Lithium-Ion Batteries +...
Can I charch my new ryobi batery lithium whith the old charch
NO THE OLD CHARGER FOR THE BLUE ONE+ TOOLS WILL ONLY CHARGE NICD BATTERIES. HOWEVER THE INTELLIPORT DUAL CHEMISTRY CHARGER WILL CHARGE BOTH NICD AND LION BATTERIES. ALL BATTERIES ARE COMPATIBLE WITH ALL ONE+ TOOLS
Mar 01, 2011 | Ryobi Two 18V Lithium-Ion Batteries +...
I bought 2 P103 lithium batteries and they will not take a charge from my one + (p110) charger. I was informed that these components are all interchangeable. Will the P103s work with the blue 18v ryobi...
That is true the One+ 18V Li-Ion battery packs will work in any One+ 18V Ryobi tool. However the Lithium ion batteries will not charge in the original P110 NiCd charger. You will need one of the the new series Ryobi One+ 18V "dual chemistry" chargers for that. The will charge both types of battery packs.
Feb 18, 2011 | Ryobi Two 18V Lithium-Ion Batteries +...
I have a ryobi 18V battery and the only charger I have is a ryobi 14.4V. Can I charge the 18V battery on that charger?
Hello, unless the charger specifies that it charges 18 volt, it will only charge a 14.4v properly. If the battery fits the charger physically, then the most you might get an 18v to charge at is 15 or 16 volts. Your battery life will be shorter and you might damage the charger. I hope this helps.
Jan 12, 2011 | Ryobi Garden
Can you charge ryobi lithium batteries in a regular ryobi charger?
NO! Never charge lithium batteries in a charger designed for nickle based batteries like the NiHi your old charger was meant for. Ryobi did design the new Lithium charger to be backwards compatible so you can charge your older 18V NiHi batteries in the Lithium 18V charger.
Also note, NEVER miss-match the voltage, for example, make sure you are not trying to charge 12V batteries in an 18V charger unless the manufacturer has specifically stated that the charger is capable of multiple voltages.
Dec 25, 2010 | Ryobi Two 18V Lithium-Ion Batteries +...
What is the replacement fuse for a Ryobi 18v charger?
The fuse in mine said 4 amp. I have also used. You can use a 4 amp or lower to replace the original one that blew.
Good Luck
Mar 07, 2009 | Ryobi Multi-Volt Battery Charger
Hand Tools Logo
148 people viewed this question
Top Hand Tools Experts
Don Numinen
Don Numinen
Ivan
Ivan
Level 1 Expert
Bill Boyd
Are you a Hand Tool Expert? Answer questions, earn points and help others
