Question about Canon PIXMA MX300 All-in-One Printer
Can't get the ink cartridges to stay to replace them
Wan't to replace old ink cartridges and put new ones in but they won't remain to the left to take them out always goes over to right side again. How do you have it stop to left to remove them?
    Scholar:
  • 51 Answers
When you open the cover, wait for your printer to display "Cover is open"
When it says this, it usually should have move the cartridge all the way to the left.
  • Maybe turn it off,and back on again and wait for it to initialize and do all of it's "turning on functions".
Then when it's done, and you hear no more movement, try opening the cover and putting the support arm up to hold it open as usual.
Wait for it to do both, and you're good to go.
* It should do both automatically when you open the cover, just wait for it.
If it does neither, then this means that the button or action switch that happens (operation that tells the printer that it's cover is open.) is somehow malfunctioning, or broken.
Hopefully what I said to-do above solves the problem.
Posted on Jan 27, 2009
How to install ink cartridges
Posted on Jun 16, 2010
When fax comes through paper is blank. I've tried 2 different cartridges
Replace the print cartridge
When you notice that the print becomes light or ink low or when install new ink
cartridge appears in the display, replace the print cartridge. The part number for
replacement cartridges is HP 701.
1. Take out a cartridge from its packaging and carefully remove the tape covering the
printhead.
Hold the cartridge by the colored top or black areas only. Do not touch the copper
area.
2. Press the Access Cartridge button on the control panel.
The cartridge carrier moves to the install position.
1 Access Cartridge
CARE AND
MAINTENANCE
CARE AND
MAINTENANCE
CARE AND
MAINTENANCE
CARE AND
MAINTENANCE
CARE AND
MAINTENANCE
CARE AND
MAINTENANCE
CARE AND
MAINTENANCE
Care and maintenance 45
3. Open the control panel and cartridge compartment cover (it will click and remain
open).
4. Push the cartridge down and remove it.
5. To load the cartridge insert the cartridge as shown below. When the cartridge is
pushed to the back of the cartridge carrier, push the top of the cartridge until it clicks
into place.
If the cartridge moves loosely in the carrier, it has not clicked into place. Repeat this
step.
1 Control panel
2 Cartridge compartment
cover
46 Care and maintenance
Clear jammed documents and paper
6. Close the cartridge compartment cover and control panel.
7. Press Start/Enter.
8. Press 1 for new cartridge, or 2 for the old one.
• When you put in a new cartridge, you must choose 1:New
• When you put in a used cartridge, choose 2:Used. This helps you to check the
correct amount of ink you have left.
TIP: If you mix up several used cartridges, it is not possible to check the correct amount
of remaining ink. Once you have put in a new cartridge, use it until it is completely
exhausted.
Nov 11, 2011 | HP 640 Inkjet Fax Machine
After changing the black ink cartridge, printer won't work - I have an 6A00 error - no lights are on where the 5 ink cartridges are - help!!
cartridge is not compatible, try putting old one and if work replace the new one.
if still not work then sensor or card is corrupted have to repair/replace them.
please check and post again here.
vote me if found helpfull.
Aug 01, 2011 | Canon PIXMA MP600 all-In-One InkJet...
The printer keep asking for ink replacement. the cartridge ink is half full. how can i use the remaining ink if the printer wants to replace a new ink. plz help
You take on the cartridge and you get the cartridge into the printer to put a mid-trough, where they see the chicken trough of ink cartridges.In the middle of the cartridge put tape and the printer see the cartridge full and you can use the remaining ink.If i have been useful please give me a vote :).Thanks
Apr 13, 2011 | Brother MFC 240C All-In-One InkJet Printer
I have replaced black ink cartridge 73N message on screen says Error i press ok to proceed message goes back saying replace ink cartridge?
The main problem in using the latest Epson printers, is the ink replacements. Ink cartridges like 73N has its own ink reseter (the little chip in front of the cartridge). Once you replaced the ink without using the right procedures, for example you have a 10% remaining ink level on one of the cartridge, and you replaced it without using the setup menu and selecting the replace ink cartridge, even though the cartridge is new, the printer will read the replaced cartridge as a 10% ink level cartridge. When the remaining 10%, drops to 0%, your cartridge will read as an empty cartridge. The chip on the cartridge is registered as an empty cartridge.
-try to replace the ink reseter or try to clean the cartridge chip then put back the ink.
Mar 23, 2011 | Epson Stylus TX400 Series
HOW DO I CHNGE THE CARTIDGE.?
When you notice that the print becomes light or ink low or when install new ink cartridge appears in the display, replace the print cartridge. The part number for replacement cartridges is HP 20.
1. Take out a cartridge from its packaging and carefully remove the tape covering the printhead.
Hold the cartridge by the colored top or black areas only. Do not touch the copper area.
3. Open the control panel and cartridge compartment cover (it will click and remain open).
4. Pull the cartridge toward you and remove it.
3 To load the cartridge insert the cartridge as shown below. When the cartridge is pushed to the back of the cartridge carrier, push the top of the cartridge until it clicks into place.
If the cartridge moves loosely in the carrier, it has not clicked into place. Repeat this step.
5. Close the cartridge compartment cover and control panel.
6. Press Start/Enter.
7. Press 1 for new cartridge, or 2 for the old one.
• When you put in a used cartridge, choose 2:Used. This helps you to check the correct amount of ink you have left.
TIP: If you mix up several used cartridges, it is not possible to check the correct amount of remaining ink. Once you have put in a new cartridge, use it until it is completely exhausted.
Dec 22, 2010 | HP 1040 Plain Paper Inkjet Fax
I replaced an ink cartridge because the printer stopped working and showed a message that the old cartridge is empty. However after putting the new one in but the printer still refuses to work and shows...
maybe the cartridge is wrong, release it and clean the electrical contacts, put them again one by one, if notting happen, try this
Solution As the printer operates, it moves ink from the ink cartridges into a printhead reservoir. The printer does not deliver a message when an ink cartridge goes empty, because it still has ink in the reservoir. The printer continues printing until the ink level in the reservoir falls to a first trigger point - then a message appears advising the printer owner to Replace Cartridges Soon . At this point, other cartridges that are empty but have not reached the trigger point are also mentioned in the message, to save trips to the retailer. After the first trigger point, the printer can continue printing until ink levels in the reservoir reach a second trigger point. At the second trigger point there is only enough ink left to perform vital servicing tasks, and a new message appears, saying Ink Cartridges Empty . The options offered depend on the usable inks remaining. If no options are offered, the cartridges indicated must be replaced before printing can continue. The Ink Cartridges Empty options are described in the table below: Ink colors out Option Print mode possible All Cancel None Black
AND
Cyan, Magenta, or Yellow (any or all) Black only Continue with other colors Cyan/Magenta/Yellow mode (composite black)
Text and photo quality will differ from those printed when all colors are available Light Cyan or Light Magenta (either or both) Cyan, Magenta, or Yellow (any or all)
(Black still available) Print with black ink only Grayscale
Apr 07, 2010 | HP Photosmart 3210 Printer
Indicator light remains lit even though it is a full cartridge
It seems there are "new" chips & "old" chips in these ink cartridges for the HP 1200 inkjet printer. I have a cartridge with a "new" chip in and it is working fine. The printer doesn't read the "old" chips. Something to watch for when using refilled ink cartridges.
Apr 17, 2009 | HP Office Equipment & Supplies
Printer cannot find new black cartridge. Left cartridge missing.
The electronics are bad on your compatible and your printer can't recognize it's there. Return this cartridge and get your money back. The next cartridge you buy, ask if the electronics have been tested to be functional. I recommend refils from Cartridge World or Office Depot.
Apr 05, 2009 | Lexmark X4530 InkJet Printer
Cartridge not detected
This problem seems to be caused by the gray horseshoe-shaped sensor behind the cartridges. I tried cleaning them with a cotton swab, and found that the "No Cartridge" message turned off when the swab was in the sensor.
So if you put something (like a tiny piece of cotton) in the cavity about halfway up the cartridge (so that it takes up space in the sensor when you replace the cartridge), you can trick the sensor into thinking the cartridge is there.
If it doesnt work the first time, try rearranging the cotton (or whatever you put) or putting more in.
Feb 08, 2008 | Brother MultiFunction Center MFC-440CN...
Canon PIXMA MX300 All-in-One Printer Logo
120 people viewed this question
old marine
old marine
