Question about Nordic Track Recumbent Exercise Cycle GX4.0
Gx4.0 console light just flickers and won't come on
Sometimes the car won't start and the dash lights and the radio lights flicker
Best place to start is the positive lead on the battery . Remove the lead and clean battery pole and terminal using sand paper until you have shiny syrfaces. Replace the lead and tighten the terminal . Check the battery for charge condition as what you describe indicates a flat battery
Feb 10, 2013 | Cars & Trucks
My 2004 Honda Pilot ran fine then a hour later won't start. At first thought battery so we charged up usig one of those chargers you plug in. Lights flicker, and clicking sounds but won't turn
Check batry terminals are secure & free from corosion, check security of earth strap to engine & main power wire on starter, if ok have the batry load tested to ensure it can perform under load as the starter needs a lot of current. Have you tried a jump start?
Sep 24, 2012 | 2004 Honda Pilot
Proscan 40LC45S screen flickers, red light flickers, won't turn on
check bad component parts at the power supply board as will as burnt parts.
Sep 07, 2012 | Proscan 40LC45S 40 in. LCD TV
Battery won't charge.. dash lights flicker
Hello, guys. You can try these OBD2 tools to find your car problem.
Sep 05, 2012 | 2000 Plymouth Voyager
LCD LE26R7 won't turn on after switching off
This is almost certainly a bad main board and it will almost certainly need to be replaced, not serviced.
I'd google for "LE26R7 main board" - check on eBay as well - but frankly if all you have to do is re-plug the TV in order to watch it I'd probably recommend sticking with that.
I predict there won't be a quick fix to this problem other than replacing the main board.
Don't kill the messenger :-)
bobby @ coppelltvrepair . com
Aug 25, 2012 | Samsung Televison & Video
2003 Landrover Freelander SE V6 == Service Engine Soon (not Check Engine) light has been infrequently flickering on/off for the past 8 weeks. While light is on, engine hesitates slightly.Vehicle would not...
If it won't start have a compression test done and see if one bank doesn't have compression . The intake cam is known for breaking at the front lobe
Nov 09, 2011 | 2002 Land Rover Freelander
Hi My PSP's orange ligth won't turn off just always lightning when turn on my psp it's lightning with green light
Hi khangal74,
If you dont have issues playing your usual psp games, you dont have to worry about the orange light. That is normal. It means that your PSP is saving the data to your memory stick. Also make sure that your WLan switch is turned off ( that also causes a blinking orange light ). However, if you are experiencing a flickering orange light and your screen remains black ( and you cannot play any games), it means that your PSP is having issues reading you memory card.
Do these:
Remove the memory card and turn your PSP on without the memory card (it should turn on with no problems) Now, slowly re-insert your Memory stick. (You may need to do this several times until your PSP recognizes your memory card) If this still does not work, your Memory stick is busted or may be infected with a virus and therefore needs to be replaced.
Wishing you with positive results. All the best to you.
Jul 23, 2011 | Sony PlayStation Portable (PSP) Console
Xbox 360 won't play new game - screen flickering on the 'press start' screen. plays cd's perfectly and was ok with games till put in new game from Morrisons.
old or new generation model? it might just need a good cleaning with one of those dvd cleaner cds you can buy. I have a game in general "home front" that sounds like my box is gonna blast off.
May 08, 2011 | Microsoft Xbox 360 Console
Nordic Track Recumbent Exercise Cycle GX4.0 Logo
55 people viewed this question
Top Nordic Track Exercise & Fitness Experts
Matt Olenzek
Matt Olenzek
Ross Metcalfe
Ross Metcalfe
 Atlanta Fitness
Atlanta Fitness
Level 1 Expert
Are you a Nordic Track Exercise and Fitnes Expert? Answer questions, earn points and help others
