Question about Vacuums
I just got a Kenmore canister vac model 27514 and there is no suctionin the hose.
  • 22 Answers
Is the bag full? if not it is clogged up
Posted on Feb 10, 2009
My vacuum just shut off while i was using it and will not start again
Wait 30 minutes and try again. Some vac's have thermal switches internally that have to cool off once overheated.
Gary
Feb 04, 2011 | Kenmore 27514 Bagged Canister Vacuum
Vac has no suction,hose clear and tried new bags
make sure lid is all the way down, detach hose from canister and drop penny through to make sure is clear..
Nov 27, 2009 | Kenmore 25512/ 25513 Progressive Canister...
I have a kenmore cannister vac - model 27514. Do I have to use hepa bags in it, or can I substitute another type, and which would that be?
You know, any bag made for the unit should give similar results. You can buy a cheaper bag and that number is 50558. You can get them at your local vac shop or you can let me know, I will send you some. The price per 3 pack is only 4.95. The canister vac is made in such a way that it doesn't have much leakage. It is quite efficient with or without hepa bag. If you or anyone in your family suffer from asthma, I would recommend the use of the hepa bags. tThanks, Rene(The Vacuum Doctor)
Nov 10, 2009 | Vacuums
I have a Kenmore Canister Vac. I need to replace
Try forcing a flathead screwdriver between the flange (tab) on the hose collar and the tab on the swivel assembly itself, taking care not to gouge the wires. Saw one solution where they used 2 screwdrivers simultaneously; couldn't do that, but did loosen one side at a time.
Sep 24, 2009 | Kenmore Vacuums
The beater of my kenmore vacuum won't turn on - the primary light goes on but none of the sensor lights go on.
Kenmore vacs generally have three male contacts at the machine end.Internally when the hoses swivels these contacts run on three brass rings which can also get dirty due to proximity to dirt. They can get dirty or dirt can fall into the corresponding female socket where the hose meets the vac. If you have just changed the bag inspect these connections near the intake port on the vac.
The working LED means you have a partial connection. Also try wiggling and twisting gently at the handle of the hose and where the wand connects to the hose and the power head elbow... you have 4 connections between vac and head
Sep 06, 2009 | Kenmore 22812 Bagged Canister Vacuum
Kenmore canister vac 25614
Have you checked and made sure that the hose is COMPLETELY clear and the bag is not full?
Feb 13, 2009 | Kenmore 25614 / 25615 Progressive Bagged...
Motor on the powermate keeps cutting in and out.
If your talking the motor on the beater bar, then chances are either when the beater bar was attached to the hose near where you hold it, it did not lock, and the connection is intermittent, or the cord has an internal break.
Jan 22, 2009 | Kenmore 22313 Bagged Canister Vacuum
Druabrand canister vac
I was looking for a Hose for the vac, and found one at good will store that will work. Others wanted more for the hose than the vac was worth.
Nov 05, 2008 | Kenmore 22612 Bagged Canister Vacuum
Model 116 hose clog?
http://geeksquad.fixya.com/ThreadView.aspx?prdid=109459&thid=699656
Posted by rfrazelle on Jun 23, 2008
My old canister model 116 followed with numbers 2839580 marked Kenmore 3.9 with power-mate, worked fine until the bag got overly full. I have changed the bag, cleaned the filter, and removed a nasty hair/fur/dust clog :-p from the lower metal tube of the power mate. It now has very weak suction and won't pick up anything. I suspect a clog in the grey plastic flexible tubing attached to the canister but cannot get it apart. Advice?
RJ
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. Kenmore 22313 Bagged Canister Vacuum. The best way to find a clog in an electric hose is to use a steel ball or a large marble to place inside the hose and to let it so threw as far as it can to determine where the hose clog is. Once you have determined where the hose clog is then you can use a small end of a broom handle of take an old wire coat hanger and place a hook on the end and try to pull the clog out of the electric hose – the electric hose is very expensive so try not to damage the hose in any way, shape or form. Or another way is that id you have another canister vacuum you can try to pull the clog apart by using two vacuums turned on and running. If you are successful then run the round marble or steel ball thru the hose again and the clog should be cleared.
http://www.sears.com/ Customer Service 1-800-4-MY-HOME 1-800-469-4663
Thanks, Don the Vac Man
Go Ahead. Use Us.
Jun 23, 2008 | Kenmore 22313 Bagged Canister Vacuum
Vacuums Logo
52 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
