Question about Microsoft Windows XP Professional
No audio drive
Prosseser 1.73ghzh rem 512 hard disk 80gb
    Scholar:
  • 65 Answers
What is the model of your desktop / laptop?
Posted on Feb 09, 2013
How to upgrade ST380011A 80GB seagate hard disk to 500GB
First you check your Hard Disk connectivity type SATA or IDE. Then purchase same type of connectivity Hard Disk as your wish. Seagate Desktop internal Hard Disk Available in market (160 GB, 250 GB, 320 GB, 500 GB, 750 GB, 1 TB, 1.5 TB, 2 TB, 3 TB).
Nov 20, 2012 | Seagate Barracuda 7200.7 ST380011A 80 GB...
I have a Fujitsu 80gb Sata hard Drive (2.5) which I have an adapter to use as a external Harddrive. However my computer and others only recognise it as a 14 gb drive. How do I get the full 80gb?
It seems this is caused by setting jumpers on your hard disk. Checkand return it to the correct position. Normally, your disk should be inthe position of Master or Slave.
Jan 16, 2011 | Fujitsu 50PK 80GB SATA 5400RPM 2.5 IN...
When i am installing os it is getting struck & giving error like os(xp, 98,vista,2008) can not format drive or bad formated partition .it is 80gb ata HDD
Any "small" disk-drive, such as your 80GB disk-drive is "out-of-warranty".
If you are going to install an Operating System, spend $50 to buy a new disk-drive,
probably faster (7200 RPM versus 5400 RPM) and bigger (320GB versus 80GB)
than your "antique" disk-drive.
Dec 10, 2010 | Western Digital Computers & Internet
I have 2 questions:- 1. I have a hard disk of 80GB capacity.I want to augment my storage capacity with an additional Hard Disk of 500GB in the second slot of my CPU.Will my motherboard support that.My...
The motherboard has 2 memory slots with each slot allowing up to 1GB modules of DDR PC2700, DDR PC3200, DDR2 PC2-5300 with a maximum of 1GB per slot. Do not mix RAM speeds.
As for hard drives, the board has the capacity of:
PATA (Parallel) - 2 x ATA100 4 Dev. Max
SATA 1.5 Gb/s - 2
I would assume that the 500GB drive you have is a SATA drive. and the 80GB as PATA. If that is the case, then the two drives would be on different controllers and would work in the system. Typically, it is recommended that the SATA drives is the main hard drive holding your OS.
As always, you would need an open bay in your computer case as well as adequate power to the PWS to complete the installation.
Nov 19, 2010 | ASUS P5VDC-X Motherboard
Can i make my 80GB hard drive to 100GB? 80GB 7200rpm SATA SAMSUNG
This is not possible, 80Gb is 80Gb and 100gb is 100gb, but I am afraid, even if you like to replace, you'll not be able to get 100gb since it's no a standard Hard disk capacity. If you are trying to upgrade, then you can find 120gb, 160gb, 250gb, 320gb etc... Good luck. Thanks for using FixYa.
Jun 06, 2010 | Samsung 80GB INTERNAL 3.5- IN SATA HDD...
Disc Error on Goodmans ghd8015f2.(Freeview HD Digital Recorder)
Yes, you can install another 80GB Hard Disk Drive.
The copper plates can be fitted to the new hard drive.
You can format it FAT or NTFS.
Nov 25, 2009 | Computers & Internet
HItachi deskstar Hard disk 80gb 7200 rpm
check the power cord of your hard disk. It should be tight not loose, if not solve then change the power cord.
Nov 25, 2009 | Hitachi Deskstar 7K80 Hard Disk 80GB,...
I have Intel 810e PIII 1 GHz 512 Mb Ram 20 GB HDD. OS Win ME I want to add secondary HDD. Which one should I preferr 80GB / 120GB / 160GB. and will install new OS say Win XP or linux in Secondary Hdd....
160gb - but ensure the bios is up to date and check the motherboard manual as that will or should explain about maximum capacity of hard drives but am sure it should be fine.
If it is not and does not detect all of it you can partition the partitions into smaller amounts ie 80 gb partitions each ?
May 19, 2009 | ASUS Intel 810E Chipset CUWE-RM...
Planning to buy a hard disk
look on the board... if it has sata connectors .... use them as they seem to have a better data rate. i'm uncertain if you can still buy new 80 gb drives now... but your sources might be different then mine.
Mar 21, 2009 | ASUS P4S533-MX MB, DDR+SDR/ VGA/ Audio/...
Harddrive problems
Was this 80GB cloned (copied) from an old 30GB disk?
Open Computer Management window doing this:
Start button - settings - control panel - administrative tools - computer management.
In the window that open, on the left hand side pane, expand Storage and click Disk Management. On the left hand side window, lower pane you should see a list of disks. See Disk 0,Basic <disk size>, Online. Do you see the 80GB as disk size? To the right you would see a series of boxes. Probably you see (C:) 30GB NTFS Healthy (system). Do you see to the right of it a box with 50GB (unknown partition)?
If so, you do have a 80GB disk, but only 30GB is a recognized partition by Windows. You can still use the the unknown partition. Post back here if you need instructions.
Dec 31, 2007 | Excelstor Technology J880 Hard Drive
Microsoft Windows XP Professional Logo
18 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
