Question about Whirlpool Duet GHW9150P Front Load Washer
Whirlpool duet sport...on but door in lock and can't get it to un
Door is stuck in lock position (light on) but can't get it to go off what do i do
  • 5,911 Answers
The first thing to try is to unplug the washer for AT LEAST 30 minutes in an attempt to reset the Central Control Unit (CCU). Sometimes, this is all that is required to correct momentary glitches with the unit.
If this does not correct the problem for you, the following link will explain how to MANUALLY release the door:
http://www.fixya.com/support/r622155-kenmore_elite_whirlpool_duet_door_jammed
If the control panel itself is showing "Locked", press and hold the "End of Cycle Signal" button for 3 seconds to clear. The instructions are printed directly below the button on the front panel. This is a built in child safety feature that prevents small children from inadvertently locking a plymate inside the washer and manipulating the controls.
If you have questions, please let me know. I hope this helps you.
Posted on Jan 27, 2009
Why would a whirlpool duet sport model number WFW8300SW05 starts fine stops during cycle. No error codes door locked red light on water in machine.
you have a plugged or partial plugged drain pump for sure. maybe there is a 20 stuck in it this time! easy to find just follow the drain hose back and you will find your pump.
also could be the cycle your using has a bad area in timing cct. check a different cycle like the delicate cycle and that will confirm pump or cycle
Jun 10, 2014 | Washing Machines
Whirlpool Duet Sport won't work past the wash cycle. It's full of water and will not drain.
check the pump filter it could be blocked or the drain hose try blowing down the drain hose to see if its clear you should hear a bubbling sound if not its blocked
Nov 27, 2011 | Whirlpool Duet Sport HT WFW8400TE Washer
I have a Whirlpool Duet Sport (model #WFW8400TW03) that shuts down when I press start. There are no error codes and the last cycle ran with no issues. The door is shut and seems secure. I can find nothing...
I had the same problem. My control lock was on without the status light on. To unlock the controls I Selected and held END OF CYCLE SIGNAL button for at least 3 seconds. The lock/unlock control status light never indicated the locked position, yet my washer now works. NOTE: Select and hold END OF CYCLE SIGNAL button for 3 seconds to toggle between lock and unlock.
May 18, 2010 | Whirlpool Duet Sport HT WFW8400TE Washer
My Whirlpool duet washer lights flash/beep
probably your door then, look at the door itself, at the latch is it broken? should form a complete square hole with four sides. if broken some part is probably inside lock asm. if complete, look at lock and determine if its in the lock position with door open, a arm will be up preventing the latch from going in. replace as necessary. Old duets (red lights) use standard lock asm same as GE and samsung. New duets (green lights) use whirlpool/new maytag unique asm. New locks come in two interchageable models, German (made in china) and Mexican, Mexican model is more troublesome, get german.
If lights flash during a cycle or other time, its giving a code, note the F code displayed
Jul 19, 2009 | Whirlpool Washing Machines
Whirlpool duet washer door is open. I can't close it because the latch is stuck in the "locked" position.
The first thing to try is to hold the cancel button for 15 seconds. The more labor intensive solution is this: Remove the panel beneath the door (2 or 3 screws). Reach up, there is a little "ring" beneath the door lock. Pull this down, it releases the mechanism.
May 03, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet Sport Washer Does Not Work, Door Lock is stuck
have you checked the belt to see if it came off or maybe broke off,if its not the belt then maybe the motor whent bad or needs reset,that just some of the possibilitys you might want to check,some motors have a reset butten on thim
Mar 01, 2009 | Whirlpool Duet GHW9150P Front Load Washer
The door on my Whirlpool duet sport won't close / lock ..
its best if you call whirlpool to set up service call. tampering with your washer could void the warranty
Dec 16, 2008 | Whirlpool GHW9400 Duet Washer
Control locked
Try the following site for full information on unlocking Dryer -------
http://www.freepatentsonline.com/4908957.html
Aug 28, 2008 | Whirlpool Duet Sport 6.7 Cu. Ft. Gas Dryer
Electronic control panel stuck on Whirlpool Duet Sport Washer
it looks like the panel switch is brooken . if you take the panel off and see if the switch.it may get stuck.
Feb 16, 2008 | Washing Machines
Whirlpool Duet GHW9150P Front Load Washer Logo
80 people viewed this question
Dan Webster
Dan Webster
Sal De
