Question about Magellan SporTrak Pro GPS Receiver
The retaining screw of the battery compartment is defective.
It feels like the above retaining screw was driven too tightly and causes the nut to spin in the socket. It sounds like the ribbing in the nut has worn out the receiving socket. It is my son's GPS receiver which he used when he was deployed in Iraq. Where can this be repaired?
  • alouis_99 Jan 28, 2009
    I tried to unlock the battery compartment, but unfortunately, the screw comes out without opening the compartment. I need to know how can I reach it as it will be very difficult to send it from Egypt to the US to get it fixed .
    Kindly reach me on: alouis_99@yahoo.com if you have any solutions.
I used a Dremel too with a small drill bit to drill it out. Got it out, but now am wondering where to get a replacement screw...
Posted on Jul 15, 2009
How to disassemble a yaesu ft 250 radio
Ok, but be careful! You may have unscrewed a battery contact already. Remove: antenna, knobs, rubber gasket under knobs, two screws at bottom of battery compartment. Back to top of radio, there are two brass retaining "nuts" with 2 small slots. One on the On/Off and 1 on the channel control. They must be unscrewed. I use an extremely small flathead screwdriver and insert it into one slot and turn counter clockwise. There is a tool and I modified a slip ring pliers for it, but the small screwdriver works 90% of the time. In the field, I use the screwdriver. Slide the housing up off the board. Now, unscrew all the small screws holding the board to the aluminum back. Count them, keep them safe and be certain to reinstall all of them. Now you will see the negative battery contact that may be the problem (loose) and the positive contacts stays put. Put the radio board back into the housing, push it up and I put the battery screws in loosely, then I install the brass nuts and "snug" them. This assures alignment of all the parts. (battery, speaker, antenna, PTT, etc) Let me know if you need more info. patience is key in removing the nuts and reinstall them to "snug", not too tight. Best of luck!
Jun 18, 2016 | Yaesu Ft-250r Vhf 136-174 Mhz Portable...
I need an advice on how to replace the heater coil on my 1990 honda accord
( heater core) disconnect the cable from negative battery terminal, from engine compartment disconnect the temperature control cable from the temperature blend door and the mounting bracket from the top of the heater case. Disconnect wires from blower motor resistor and the blower motor. Drain the coolant from the radiator into some type of container. Disconnect the heater hoses from the heater core tubes on the engine side of the firewall. Now working in the passenger compartment, remove the nuts retaining the left end of the heater case and the right end of the plenum to the dash panel. Working in the engine compartment, remove the screw retaining the top center of the heater case to the dash panel. Remove the screws retaining the right end of the heater case to the dash panel and remove the heater case assembly from the car. Remove the screws, nuts and bolts retaining the heater housing plate to the heater case, then remove the heater housing plate. If so equipped, remove the screws attaching the heater core frame to the heater case and remove the frame. Remove the heater core and seal from the heater case.
Dec 25, 2011 | Cars & Trucks
Replacing the heater core i need to see where the screws are in the black box
Check this procedure for 1993 Ford Taurus 3.0L FI 6cyl REMOVAL & INSTALLATION
(see Figures 1 and 2)
Be sure to consult the laws in your area before beginning any procedure which requires servicing the air conditioning system. In some states, it is illegal to perform repairs involving refrigerant unless the work is done by a certified technician.
CAUTION When draining the coolant, keep in mind that cats and dogs are attracted by the ethylene glycol antifreeze, and are quite likely to drink any that is left in an uncovered container or in puddles on the ground. This will prove fatal in sufficient quantity. Always drain the coolant into a sealable container. Coolant should be reused unless it is contaminated or several years old.
When removing the instrument panel, it may be beneficial to have a friend or assistant help you.
Without Air Conditioning
  1. Disconnect the negative battery cable.
  2. Remove the instrument panel on 1986-89 vehicles as follows:
    1. Remove the four screws retaining the steering column opening cover, then remove the cover.
    2. Remove the sound insulator under the glove compartment by removing the two push nuts securing the insulator to the studs on the climate control case.
    3. Remove the steering column trim shrouds, then tag and disengage all electrical connections from the steering column switches.
    4. Remove the four screws at the steering column bracket to remove the steering column.
    5. Remove the screws retaining the lower left and radio finish panels, then remove the panels by snapping them out.
    6. Remove the cluster opening finish panel retaining screws. On Taurus remove the jam nut behind the headlight switch and the screw behind the clock or clock cover. Remove the finish panel by rocking the upper edge toward the driver.
    7. Disconnect the speedometer cable by reaching up under the instrument panel and pressing on the flat surface of the plastic connector. The panel can be removed with the cluster installed.
    8. Release the glove compartment assembly by depressing the side of the glove compartment bin and swinging the door/bin down.
    9. Using the steering column, cluster and glove compartment openings and by reaching under the instrument panel, tag and disengage all electrical connections, vacuum hoses, heater control cables and the radio antenna cable.
    10. Tag and disengage all underhood electrical connectors of the main wire loom. Disengage the rubber grommet from the dash panel and push the wire and connectors into the instrument panel area.
    11. Remove the right and left speaker opening covers by snapping them out.
    12. Remove the two lower instrument panel-to-cowl side retaining screws from the right and left side. Remove the instrument panel brace retaining screw from under the radio area. On Sable, remove the defroster grille by snapping it out.
    13. Remove the three instrument panel upper retaining screws, then remove the instrument panel.
  1. Remove the instrument panel on 1990-95 vehicles as follows:
    1. Position the front wheels in the straight-ahead position.
    2. Disconnect the positive battery cable.
    3. Remove the ignition lock cylinder and, if equipped, remove the tilt lever.
    4. Remove the steering column trim shrouds. Tag and disengage all electrical connections from the steering column switches.
    5. Remove the four bolts and opening cover, and the two bolts and reinforcement from under the steering column.
    6. Disengage the insulator retainer and remove the insulator. Remove the four nuts and reinforcement from under the steering column.
Do not rotate the steering column shaft.
    1. Remove the four nuts retaining the steering column to the instrument panel, disconnect the shift indicator cable and lower the column on the front seat. Install the lock cylinder to make sure the steering column shaft does not turn.
    2. Remove bolt at the steering column opening attaching the instrument panel to the brace. Remove instrument panel brace retaining bolt from under the radio area.
    3. Remove the sound insulator under the glove compartment by removing the two push nuts that secure the insulator to the studs on the climate control case.
    4. Disconnect the wires of the main wire loom in the engine compartment. Disengage the rubber grommet from the dash panel, then feed the wiring through the hole in the dash panel into the passenger compartment.
    5. Remove the right and left cowl side trim panels. Disconnect the wires from the instrument panel at the right and left cowl sides.
    6. Remove screw each from the left and right side retaining the instrument panel. Pull up to unsnap the right and left speaker opening covers and remove.
    7. Release the glove compartment assembly by depressing the side of the glove compartment bin and swinging the door/bin down.
    8. Using the steering column and glove compartment openings and by reaching under the instrument panel, tag and disengage all electrical connections, vacuum hoses, heater control cables, speedometer cable and radio antenna cable.
    9. Close the glove compartment door, support the panel and remove the three screws attaching the top of the instrument panel to the cowl top and disconnect any remaining wires. Remove the panel from the vehicle.
  1. Drain the coolant from the radiator.
  2. Disconnect and plug the heater hoses at the heater core. Plug the heater core tubes.
  3. Disconnect the vacuum supply hose from the inline vacuum check valve in the engine compartment. Remove the screw holding the instrument panel shake brace to the heater case and remove the shake brace.
  4. Remove the floor register and rear floor ducts from the bottom of the heater case. Remove the three nuts attaching the heater case to the dash panel in the engine compartment.
  5. Remove the two screws attaching the brackets to the cowl top panel. Pull the heater case assembly away from the dash panel and remove from the vehicle.
  6. Remove the vacuum source line from the heater core tube seal and remove the seal from the heater core tubes.
  7. Remove the four heater core access cover attaching screws and remove the access cover from the heater case. Lift the heater core and seals from the heater case.
To install:
  1. Transfer the three foam core seals to the new heater core. Install the heater core and seals into the heater case.
  2. Position the heater case access cover on the case, then install the four retaining screws.
  3. Install the seal on the heater core tubes, then install the vacuum source line through the seal.
  4. Position the heater case assembly to the dash panel and cowl top panel at the air inlet opening. Install the two screws to attach the support brackets to the cowl top panel.
  5. Install the three nuts in the engine compartment to attach the heater case to the dash panel. Install the floor register and rear floor ducts on the bottom of the heater case.
  6. Install the instrument panel shake brace and screw to the heater case.
  7. Install the instrument panel by reversing the removal procedure.
  8. Connect the heater hoses to the heater core. Connect the black vacuum supply hose to the vacuum check valve in the engine compartment.
  9. Fill the radiator and bleed the cooling system.
  10. Connect the negative battery cable and check the system for proper operation.
continue...
Feb 08, 2011 | 1993 Ford Taurus
1990 taurus steps to replacing heater core
Heater Core REMOVAL & INSTALLATION NOTE: Be sure to consult the laws in your area before beginning any procedure which requires servicing the air conditioning system. In some states, it is illegal to perform repairs involving refrigerant unless the work is done by a certified technician. CAUTION
When draining the coolant, keep in mind that cats and dogs are attracted by the ethylene glycol antifreeze, and are quite likely to drink any that is left in an uncovered container or in puddles on the ground. This will prove fatal in sufficient quantity. Always drain the coolant into a sealable container. Coolant should be reused unless it is contaminated or several years old. NOTE: When removing the instrument panel, it may be beneficial to have a friend or assistant help you. Without Air Conditioning
  3. Remove the instrument panel on 1990-95 vehicles as follows:
    6. Disengage the insulator retainer and remove the insulator. Remove the four nuts and reinforcement from under the steering column. NOTE: Do not rotate the steering column shaft.
    7. Remove the four nuts retaining the steering column to the instrument panel, disconnect the shift indicator cable and lower the column on the front seat. Install the lock cylinder to make sure the steering column shaft does not turn.
    8. Remove bolt at the steering column opening attaching the instrument panel to the brace. Remove instrument panel brace retaining bolt from under the radio area.
    9. Remove the sound insulator under the glove compartment by removing the two push nuts that secure the insulator to the studs on the climate control case.
    10. Disconnect the wires of the main wire loom in the engine compartment. Disengage the rubber grommet from the dash panel, then feed the wiring through the hole in the dash panel into the passenger compartment.
    11. Remove the right and left cowl side trim panels. Disconnect the wires from the instrument panel at the right and left cowl sides.
    12. Remove screw each from the left and right side retaining the instrument panel. Pull up to unsnap the right and left speaker opening covers and remove.
    13. Release the glove compartment assembly by depressing the side of the glove compartment bin and swinging the door/bin down.
    14. Using the steering column and glove compartment openings and by reaching under the instrument panel, tag and disengage all electrical connections, vacuum hoses, heater control cables, speedometer cable and radio antenna cable.
    15. Close the glove compartment door, support the panel and remove the three screws attaching the top of the instrument panel to the cowl top and disconnect any remaining wires. Remove the panel from the vehicle.
  4. Drain the coolant from the radiator.
  5. Disconnect and plug the heater hoses at the heater core. Plug the heater core tubes.
  6. Disconnect the vacuum supply hose from the inline vacuum check valve in the engine compartment. Remove the screw holding the instrument panel shake brace to the heater case and remove the shake brace.
  7. Remove the floor register and rear floor ducts from the bottom of the heater case. Remove the three nuts attaching the heater case to the dash panel in the engine compartment.
  8. Remove the two screws attaching the brackets to the cowl top panel. Pull the heater case assembly away from the dash panel and remove from the vehicle.
  9. Remove the vacuum source line from the heater core tube seal and remove the seal from the heater core tubes.
  10. Remove the four heater core access cover attaching screws and remove the access cover from the heater case. Lift the heater core and seals from the heater case. To install:
  11. Transfer the three foam core seals to the new heater core. Install the heater core and seals into the heater case.
  12. Position the heater case access cover on the case, then install the four retaining screws.
  13. Install the seal on the heater core tubes, then install the vacuum source line through the seal.
  14. Position the heater case assembly to the dash panel and cowl top panel at the air inlet opening. Install the two screws to attach the support brackets to the cowl top panel.
  15. Install the three nuts in the engine compartment to attach the heater case to the dash panel. Install the floor register and rear floor ducts on the bottom of the heater case.
  16. Install the instrument panel shake brace and screw to the heater case.
  17. Install the instrument panel by reversing the removal procedure.
  18. Connect the heater hoses to the heater core. Connect the black vacuum supply hose to the vacuum check valve in the engine compartment.
  19. Fill the radiator and bleed the cooling system.
  20. Connect the negative battery cable and check the system for proper operation. Fig. 1: Location of the vacuum source line 86876016.gif
    Fig. 2: Heater core cover location 86876017.gif
Jan 30, 2011 | 1990 Ford Taurus
Where is the heater core located
Dec 19, 2010 | 1987 Ford Taurus
Where is the heater core in a gmc van
Welcome to FIxYa.com
1. Disconnect the battery cable.
2. Remove coolant recovery tank and lay aside.
3. Place a clean pan under the vehicle and then disconnect the heater core inlet and
outlet hoses at the heater connections. Quickly plug the heater hoses and support
them in a raised position. Allow the coolant in the heater core to drain into the pan
on the floor.
4. Remove heater distributor duct to distributor case attaching screws and distributor
duct to engine cover screw and remove duct.
5. Remove engine housing cover.
6. Remove instrument panel attaching screws: above, at windshield, all lower screws
and tight lower LP. Support bracket at door pillar and engine housing.
7. Lower steering column, and raise and support tight side of LP.
8. Remove defroster duct to distributor case attaching distributor to heater case.
9. Disconnect temperature door cable and fold cable back for access.
10. Remove three (3) nuts at engine compartment side of distributor case and one (1)
screw on passenger side.
11. Remove the heater case and core as an assembly. Tilt the case assembly rearward at
the top while lifting up until the core tubes clear the dash openings.
12. Remove the core retaining strap screws and remove the core.
13. To install a new core. Reverse Steps l-10 above. Be sure core to case and case to
dash panel sealer is intact before assembling unit.
Thank you for using FixYa.com
Regards, Lee Davidian
Nov 06, 2010 | 1984 GMC VanDura
How hard to replace starter on 3.4 liter 1997 chevy lumina sedan?
Here are the instructions on how to replace your starter.
WARNING Remember that the positive battery cable to the starter motor is electrically "hot" all the time. You must open the circuit by disconnecting the negative battery cable before servicing the starter motor.
  2. Raise and safely support the vehicle.
  3. Remove the front lower air deflector panel by locating the deflector retainers. These are push-in retainers and should be carefully pried loose. Remove the ambient temperature sensor, if equipped.
  4. Remove the two torque converter covers. They are retained by small screws.
  5. Remove the starter solenoid "BAT" terminal nut (the large one) and disconnect the battery positive cable from the starter motor. Remove the S terminal nut and disconnect the solenoid wire.
  6. Remove the starter motor mounting bolts. Use care. The starter is relatively heavy. Do not allow it to fall. Take note of any thin metal shims between the starter and engine block. They may be required at installation.
To install:
  1. Verify the correct starter motor has been obtained. Position the starter motor, including any shims found at removal, to the engine block and install the mounting bolts finger-tight until seated. Torque the bolts to 32 ft. lbs. (43 Nm).
  2. Position the wires to the starter. Install the nuts finger-tight, then tighten the starter solenoid "BAT" (heavy cable) nut to 84 inch lbs. Tighten the starter solenoid S terminal nut to just 20 inch lbs. (2.5 Nm).
  3. Install the torque converter covers and tighten the torque converter cover screws to 89 inch lbs. (10 Nm).
  4. Install the front lower air deflector panel by pressing in the plastic retainers.
  5. Lower the vehicle.
  6. Connect the battery negative cable. Start the engine to verify correct operation.
please do not hesitate to ask me further questions about your vehicle.
please do not forget to rate and comment about your experience today with fixya.
Dec 27, 2009 | 1997 Chevrolet Lumina
Heater core replacement
The instrument panel and steering column must be removed to remove the heater assembly. Two people are required to remove the assembly from the vehicle.
Disconnect negative battery cable. Disconnect positive battery cable and wait one minute for air bag diagnostic monitor to deplete the backup power supply.
Loosen main wiring connector bolt in the engine compartment at the left side of dash panel and separate connectors.
Remove radio antenna stanchion and disconnect cable from base of the radio antenna stanchion.
Remove both the right hand and left hand windshield side garnish mouldings.
Do not remove safety belt retaining bolts in next step.
Remove the screws retaining both the right and left front door scuff plates and remove the front door opening weather-strips from body flanges.
Remove the steering column cover by removing the three screws along the bottom and pull on the cover to unsnap the three clips across the top of the instrument panel steering column cover.
Remove the ignition switch lock cylinder.
Remove the four screws retaining the steering column shrouds together and remove the steering column shrouds.
Install the ignition switch lock cylinder to prevent the steering wheel from turning.
Disconnect the wiring connectors at the turn signal and windshield wiper switch.
Remove the one screw and A/C evaporator register duct from under the steering column tube.
Disconnect the wiring connectors at the bottom of the steering column tube.
Remove the pinch bolt attaching the steering column tube to the steering column lower yoke and slightly spread the joint with a screwdriver.
While supporting the steering column tube, remove the four steering column tube retaining nuts.
Remove the interlock cable retaining screws and shift actuator cable fitting.
Carefully remove the steering column tube from the vehicle.
Loosen the main wiring connector bolt at the left side of the steering column opening and separate the connectors.
Disconnect the stoplight switch wiring connector. On the manual transmission, disconnect the clutch pedal position switch wiring connector.
Pull back the floor carpet as required on the left and right sides of the vehicle and disconnect the window regulator safety relay switch wiring, and the powertrain control module from the main wiring.
Open the glove compartment to the stop, unsnap the hydraulic lift from the right side.
Remove the three screws at the bottom retaining the glove compartment door hinge and glove compartment to the instrument panel.
Remove the glove compartment.
Reach through the glove compartment opening and disconnect the wiring and vacuum hoses/connector from the heater-A/C evaporator housing.
Disconnect the wiring connector from the speed control amplifier and bracket assembly.
Remove floor console panel:
Open the console panel glove compartment door to access screws to console finish panel.
Remove the two screws, and lift the rear of the console finish panel to unsnap retainers.
Reach under the console finish panel and disconnect wires to fog lamp and ride control switches (if equipped) and cigar lighter socket and retainer.
Lift the rear of the console finish panel and slide rearward to release the two front locating tabs, remove console finish panel.
With the console panel door open, remove the console glove compartment mat.
Remove the center screw from the console (rear of shifter) bin, then lift the bin from the console panel. Disconnect the luggage compartment door release switch and fuel filler door lock switch (if equipped).
Remove the two screws from the bottom of the console panel bin to floor pan.
Remove the two cups and screws. Remove the floor console panel.
Remove the two screws retaining the front of the floor console panel to the instrument panel. Disconnect the remaining wires (main jumper wire) and main wiring, then lift the console panel from the vehicle.Protect the instrument panel surface during next step.
Using a putty knife or similar tool, insert under the left or right corner of the instrument panel upper finish panel and pry up on the instrument panel upper finish panel to release one snap clip.
Unsnap the remaining four clips pulling up by hand, working toward the opposite side of the vehicle.
Remove the two nuts retaining the left side of the instrument panel to the cowl side.
Remove the two nuts and one bolt retaining the instrument panel to the console bracket.
Remove the nut attaching the right side of the instrument panel to cowl side.
The following steps require two people
Nov 16, 2009 | 1996 Ford Thunderbird LX
Hi, How do I replace the tail light bulbs in my '97 Crown Victoria? Thanks
Sedans
  1. Remove the screw(s) and wing nut retainers at the rear of the luggage compartment and push the trim away from the back of the light.
  2. Remove the wing nuts retaining the light assembly to the vehicle and the retaining nut from either side of the luggage compartment and pull the light body assembly from the vehicle.
  3. Turn the bulb socket(s) counterclockwise to the stop and remove the socket(s) from the light assembly. Remove the bulb(s) from the socket(s).
  4. Installation is the reverse of the removal procedure.
Push the trim away from the back of the light—1992-98 Crown Victoria
The rear tailamp assembly is held by various fasteners
Remove the wing nuts retaining the light assembly to the lower back panel—1992-98 Crown Victoria
Remove the nut retaining the light assembly from the side of the luggage compartment
Pull the light assembly away from the vehicle—1992-98 Crown Victoria
Oct 12, 2009 | 1997 Ford Crown Victoria
Dash
  2. Remove the ashtray.
  3. Unfasten the accessory trim plate screws, then remove the accessory trim plate.
  4. Remove the glove box door strap, then remove the glove box hinge screws.
  5. Remove the glove box door frame.
  6. Loosen the ashtray support screws, then remove the ashtray support.
  7. Remove the glove box.
  8. Unfasten the radio bracket bushing nut, then remove the radio.
  9. Disconnect the speaker grille screws, then remove the speaker grilles.
  10. Loosen the speaker retainers, then remove the front radio speakers.
  11. Unfasten the sound insulation panel screws, then remove the sound insulation panels.
  12. Loosen the steering column filler screws, then remove the steering column filler.
  13. Disconnect the hood release cable.
  14. Disconnect the shift indicator cable from the column bowl.
  15. Disconnect the steering column support nuts, then lower the steering column. For details regarding this procedure, please refer to of this guide.
  16. Unfasten the switch plate trim screw, then remove the switch trim plate.
  17. Disengage the electrical wiring harness from the rear defogger and the light switches.
  18. Disconnect the heater and A/C control.
  19. Disconnect the cluster housing bezel mounting nuts, then remove the bezel.
  20. Remove the instrument cluster from the vehicle. Disconnect and allow to hang:
  21. The speedometer instrument panel electrical connector and the Vehicle Speed Sensor connector
  22. The courtesy lamps and the cruise control module
  23. The horn relay, multi-function alarm and the flasher assembly
  24. If necessary, remove the applicable computer control module.
  25. Remove the instrument panel-to-cowl mounts:
    1. Unfasten the screws from under the panel.
    2. Remove the instrument panel support.
    3. Unfasten the screws in the defroster outlets.
    4. Remove the ductwork, dash plugs, wire looms, and heater cables attached to the panel.
  26. Disengage any electrical connections/wires routed through the instrument panel, then remove the instrument panel from the vehicle.
To install:
  1. Install the instrument panel assembly to the cowl, carefully routing and connecting the electrical wires and cables.
  2. Connect the instrument panel-to-cowl mounts:
    1. Connect the ductwork, dash plugs, wire looms, and heater cables to the instrument panel.
    2. Secure the screws in the defroster outlets.
    3. Install the instrument panel support, then fasten the screws (located under the panel).
  3. Install the computer control module, if removed.
  4. Install the instrument cluster. Reconnect and mount:
  5. The speedometer and Vehicle Speed Sensor electrical connectors
  6. The flasher assembly, multi-function alarm, and horn relay
  7. The cruise control module and the courtesy lamps
  8. Install the cluster housing bezel using the mounting nuts. Tighten the nuts to 12 inch lbs. (1.4 Nm).
  9. Install the heater and A/C control.
  10. Engage the rear defogger and light switch electrical harness.
  11. Install the switch trim plate using the retaining screw. Tighten the screw to 12 inch lbs. (1.4 Nm).
  12. Raise the steering column to the mounting bracket, then install the steering column support nuts.
  13. Install the shift indicator column to the column bowl, making sure that the indicator is aligned.
  14. Connect the hood release cable.
  15. Install the steering column filler panel using the retaining screws. Tighten the screws to 14 inch lbs. (1.6 Nm).
  16. Install the sound insulation panels using the retaining screws. Tighten the screws to 14 inch lbs. (1.6 Nm).
  17. Install the front radio speakers and speaker retainers, then connect the speaker grilles using the retaining screws. Tighten the screws to 12 inch lbs. (1.4 Nm).
  18. Install the radio and tighten the fastener to 12 inch lbs. (1.4 Nm).
  19. Install the glove compartment, then install the ashtray support using the retaining screws. Tighten the screws to 12 inch lbs. (1.4 Nm).
  20. Install the glove compartment door frame, door and door hinge screws. Tighten the screws to 12 inch lbs. (1.4 Nm).
  21. Install the glove compartment door strap.
  22. Install the accessory trim plate using the retaining screws. Tighten the screws to 12 inch lbs. (1.4 Nm).
  23. Install the ashtray, then connect the negative battery cable.
Oct 02, 2008 | 1989 Chevrolet S-10 Blazer
Magellan SporTrak Pro GPS Receiver Logo
94 people viewed this question
Top Magellan GPS Experts
Will Halftowaite
Are you a Magellan GPS Expert? Answer questions, earn points and help others
