Question about Dayton Electric Heater
In my prevost bus i have an dayton heater model 2E442 that need an fan
  • 56 Answers
SOURCE: I need a fan blade for a dayton in wall heater model 2E441
You should be able to google the manufacture and look for a contact us area where you can get a hold of them and order it unless the part is obsolete. They could have a universal replacement.
Posted on Feb 16, 2009
clyde2j2
  • 137 Answers
SOURCE: Dayton Furnace - Pilot Light Goes Out but Fan keeps running?
Pilot lighted furnaces have a thermocouple made from disasimilar metals that when heated create electricity to actuate a relay that alows the gas to flow to the furnace.
When the thermocouple gets coated with carbon from the pilot lights constant burning it acts as an insulator and keeps the thermocouple from getting enough heat to generate electricity, a very good safety factor.
What you have to do is locate the thermocouple it should be located over the pilot light, you will see a gray substance around the thermocouple it will be hard like cement, take a knife and scrape away as much of the gray material as possible then sand the themocouple with a medium sandpaper until it shines, use one of you wifes emery boards, this should solve your problem.
Posted on Feb 24, 2009
farfield
  • 462 Answers
SOURCE: ned a fan moter for dayton model 3vu36a heater
consult with WW GRANGER. They have Dayton as a line and will be able to tell you whats available from model number. They also have a web site with phone number to their stores. try it w dot com.
Posted on Mar 04, 2009
roniecon
  • 6826 Answers
SOURCE: Can the Dayton model 3e368e be converted to use
If you know a dealer or repair company,they can order orifices to change out in the unit.
Posted on Oct 17, 2009
SOURCE: Dayton Model 1VNX5 Kerosene clicks like crazy but won't light
I have the same heater with the same problem. I took the top cover off, removed the ignitor and bent the probes slightly closer. Use two needle nose to prevent breakage of the holder. It has been working fine since.
Posted on Jan 31, 2010
Need fan motor for model 2E440
Try Grainger
dayton 2e440 heater Questions & Answers - Fixya
www.fixya.com > Forum > Tags
... a Dayton Model 2YU40 electric heater Need manual for Dayton. ... looking for a replacement fan and fan motor for a Dayton model 2E454B electric wall heater.
Dayton rheostat fan motor Heaters Questions & Answers ...
www.fixya.com > Forum > Tags > rheostat fan motor > Heaters
Dayton heaters rheostat fan motor related questions and answers. ... UP BUT FAN WONT KICK ON Could be one of several problems dependant on the model you have.... The motors are noisy in 2 Dayton 2e440 heaters. I ... I'm looking for a replacement fan and fan motor for a Dayton model 2E454B electric wall heater.
DAYTON Electric Wall Heater, Recessed or Surface ...
www.grainger.com/.../DAYTON-Electric-Wall-Heater-3...
W. W. GraingerShop DAYTON Electric Wall Heater, Recessed or Surface, Voltage 208/240, Watts ...Item # 3UG56; Mfr. Model # 3UG56; UNSPSC # 40101814; Catalog Page # 4277; Shipping Weight 20.65 lbs. ... Additional features include a built-in thermal cutout andfan delay switch for added safety ... Need Help Finding Repair Parts?
Jan 09, 2016 | Dayton Electric Heater
Electric Heaters and Accessories - Grainger
www.grainger.com/.../electric-heaters-and.../heaters/.../N...
W. W. GraingerCount on Grainger to supply high-quality electric heaters and accessories for ...Electric Wall Mount Heaters ... Electric Space Heater,Fan Forced,120V, ... SearchQ&A ... This fuse is used on driers heater elements, I'm unable to locate these in .... in Ask and Answer are not intended to replace or supplement any professional, ...
DAYTON Electric Space Heater,Fan Forced,120V, - Portable ...
www.grainger.com/.../DAYTON-Electric-Space-Heater-...
W. W. GraingerShop DAYTON Electric Space Heater,Fan Forced,120V, (3VU33) at Grainger. ... Item # 3VU33; Mfr. Model # 3VU33; NSN # ... Country of Origin China Country of Origin is subject to change. ... Alternate Search Terms ... I need a replacement fan motor .... Where can I find parts for Dayton fan forced wall heater mod.5ZK54D.
Dayton Industrial Fan: Amazon.com
Dec 21, 2015 | Dayton Heating & Cooling
Trying to find a replacement fan motor for a dayton electric garage heater moodel number 3e547 its around 12 years old
Go to grainger supply.com then go to dayton heaters with your model number and part number if you can find it,along with description of parts you need. I have been dealing with them for years and they are the main distributor for dayton furnaces.
They carry a large selection of parts and generally ship within two days. Hope this helps you. Thank you.
Jan 27, 2011 | Dayton Electric Heater
Have 30,000 btu Dayton heater m#3e3665 when reaches temp. fan
Hi blow heater out with air line flame sensor could be dirty check out pressure switch jump this out see if it lights
Feb 09, 2010 | Dayton (3E379) Heater
Dayton heater Model 2E400. Does the fan draw the air in and than blow the heated air out of the botton of the unit? Does fan turn CCW or CC.
yes, you have the direction of flow correct. The rotation of the fan will be marked on the motor of the fan
Jan 07, 2010 | Dayton Electric Heater
My dayton NG heater fan will not shut off properly
Sounds like a bad fan switch. The switch is located on the heat exchanger and is 110 volt bi-metal switch. Follow the wires from the blower going back to the heatexchanger. Graingers can get you a new switch if you give them your model number. www.grainger.com.
Dec 12, 2009 | Dayton Heating & Cooling
Why does a pilot light go out,but the fan keeps running?
some heaters use a timer to bring fan on as opposed to some which use temp
Feb 24, 2009 | Dayton (4LX41) Heater
Feb 14, 2009 | Dayton Electric Heater
Ned a fan moter for dayton model 3vu36a heater
Jan 10, 2009 | Dayton Electric Heater
I have a Dayton gas heater Model 3E225
Does the main blower fan kick on? Also, if the heater is vented outside via a flue pipe, there may be a small (about 3 or 4 inches in diameter) vent fan that kicks on to ensure the exhaust fumes are evacuated through the flue pipe. If there's a problem with that fan, the burner won't light either.
Nov 20, 2008 | Dayton (3E379) Heater
Dayton Electric Heater Logo
51 people viewed this question
Top Dayton Heating & Cooling Experts
paulcarew
Mack Baxter
Dan Webster
Dan Webster
Are you a Dayton Heating and Cooling Expert? Answer questions, earn points and help others
