Question about Eastern Tools And Equipment 1200 Watt Portable Generator #TG1200E
Ihave a etq in800i generator and am having problems starting my unit any advice
3 Suggested Answers
kel1guy2002
  • 3740 Answers
SOURCE: Regards to ETQ TG1200 Generator Generator
Hi and welcome to FixYa, I am Kelly
I read spce sheets for this generator and several of the spec sheets say it requires 0.16 L of oil. If generator has a low oil level sensor that will kill the spark if the oil level is low.
Here is a copy of the Owners manual:
http://theportablegenerators.org/manuals/ETQ/Generator-TG1200-manual.pdf
I went through the manual reading every detail about the generator and could find nothing about an low oil level sensor.
The wiring diagram on page 27 only shows the ignition switch, with a Brown wire to the ignition controller and then an orange wire to the high voltage coil in the circuit.
The parts diagram throws a wrench n the game as it mentions an ignitor... (item 2)
I see the switch, (item 4 page 24)
The magneto (Item 16 page 22)
The High voltage coil / set (Item 28 page 22) as the only 3 things in the circuit.
Disconnect the brown wire at the ignition controller and switch the run switch to ON. Check for a ground (none allowed)
Then check the Orange wire at the ignition controller to the high voltage set / coil. You may read resistance of the coil but is should NOT read ZERO ohms. IF you read ZERO you need to locate the short.
Inspect the wiring connections especially around the ignition controller. For a unit with 1 hr of run time it has to be something simple like a disconnected terminal unless rodents chewed on the wiring.
Thanks for choosing FixYa,
Kelly
Posted on Jun 04, 2011
marilynda581
SOURCE: I HAVE A ETQ 1200 GENERATOR I NEED ON THE
I found that the switch wires under the gas tanks are pretty loose in their plugs going to the magneta.. Check all of your wireing under the gas tank for connection..I just put mine the shop and they told me that would run on ether but not on gas.. johndogfuzz@gmail.com
Posted on Jul 09, 2012
Etq tg3000 portable generator is leaking gas from carburetor into air filter. Any suggestions
PDF]Manual - Northern Tool + Equipment
www.northerntool.com/images/.../166020.pd...
Northern Tool + EquipmentThe ETQ air-cooled gasoline generators are widely used when electrical power is scarce. Our generators provide a portable mobile solution in supplying power for field ... 5.5 Hours. Fuel Type. Premix 50 cups of Gasoline to one cup of 2 stroke oil ......Leaking carburetor, clogged fuel pipes, sticking valves, or other damage, ...
[PDF]Owner's Manual Model TG4000
Dec 08, 2015 | Electrical Supplies
Where can I find a service center in Pasadena, TX or Houston, TX????
YOU CAN FIND OUT ON THE YP (YELLOW PAGES) LOCALLY AND ON THE INTERNET YP.COM
Jun 17, 2015 | Northstar ETQ DG6LE Portable Generator...
ETQ generator DG4LE cut off value under tank broke and no fuel comes thru
syphon the gas out,tip it up so whats left will not come out of the hole for the shut off,unbolt the shut off and it should be part number,ETQ 17150,,,or whats on the pic
http://theportablegenerators.org/manuals/ETQ/Diesel-ETQ-Gen-178F.pdf
http://theportablegenerators.org/manuals/ETQ/Diesel-engine-DG4LE-DG6LE-manual.pdf
May 12, 2015 | Eastern Tools & Equipment ETQ DG4LE 4,900...
I have an ETQ 4000. New carb, new plug. Will only start with starter fluid then die.
You know you have ignition. It isn't getting correct fuel. CHeck fuel to carb. If confirmed fuel to carb, carb is not adjusted properly.
Jan 08, 2015 | ETQ 4000 Watt Generator
I have a etq 1200 generator that runs but doesnt have ac. what could be the problem?
Check that the GFI receptical is not tripped
Check that there are no blown fuses or tripped breakers
Verify that the engine is running at full RPM
If there is still no output, then either the field needs to be flashed (look on line to find a video on how to do this - YouTube), or the generator will need further diagnostics.
Sep 04, 2014 | Eastern Tools & Equipment ETQ Tg1200 1200...
Where is the muffler and exhaust on ETQ prtable generator?
The exhaust will be located on the output side of the cylinder manifold.
Sep 01, 2014 | Eastern Tools & Equipment ETQ Tg72k12 8250...
I have an ETQ TG60H12 6000 wt generator. It has .9 hrs because I only fire it about once a month. I've noticed a wet spot on my shed floor but was never able to determine the origin until I noticed a leak...
remove and let the tank dry out you can then get a product that you pour inside to cure the leak, cant remember the name of the product most bike shops would be able to get hold of it
Oct 23, 2013 | Northstar ETQ DG6LE Portable Generator...
Need Owners Manual for an ETQ 1800 w inverter/Generator
Northern tools has it here, even though it's a discontinued product:
http://www.northerntool.com/images/downloads/manuals/166520.pdf
Apr 11, 2013 | ETQ IN1800i Generator Digital Inverter...
The pdf for this generator is available at easterntools.com
Feb 07, 2010 | Eastern Tools And Equipment 1200 Watt...
Eastern Tools And Equipment 1200 Watt Portable Generator #TG1200E Logo
266 people viewed this question
Top Eastern Electrical Supplies Experts
Steve
Gene Haynes
Are you an Eastern Electrical Supply Expert? Answer questions, earn points and help others
