Question about 3M Transparency Thermofax Tattoo Stencil Maker Thermal Copier
Thermofax copier 45cg doesnt make stencil - 3M Transparency Thermofax Tattoo Stencil Maker Thermal Copier
Tip
Painting patterns using stencils
Painting a pattern on your wall can be very difficult if you want all the shapes to be the same size and level. But just like when you were little and had letter or shape stencils to help you draw perfect drawings, you can make stencils yourself for what ever it is that you want to paint on the wall.
Using a sheet of cardboard or a contact sheet draw and cut out the shape that you want to paint. If you want to make a pattern that goes all the way around the room then you should make two or three stencils so you can level them.
To use the stencils first prepare the wall you want to paint, you want to paint the base color before you use the stencil because painting around your design can be very challenging. When the wall is dry take your stencil and using painters tape, tape the stencil to the wall so it doesn't move. Making sure that you don't over load the paintbrush paint inside the stencil trying to be careful around the edges. When you finish filling the stencil carefully lift it off, make sure that there isn't any paint on the underside of the stencil because if there is and its wet it will leave unwanted marks on the wall.
Repeat the process of taping, painting and lifting until you have finished painting your pattern on the wall. When you are finished step back and enjoy your handiwork.
on Oct 24, 2013 | Crafts & Hobbies
Gestetner 6123 paper jaming feeding section copy printer
nrg 6123 copy printer after make stencil line on copy soulition
Jun 15, 2012 | Gestetner - AO40 Wide Format Copier Copier
Duplo dp21 s2 master set miss
Behind the cutter unit is A black sponge roller, turn it manually by hand, you will find A small piece of master/stencil there. Remove it and reload the master/stencil roll.
Aug 15, 2011 | Duplo DP22L Black and White Copier
3M model 45CG Thermofax Machine how to change bulb?
On either side of the drive table are single wires that go to each end of the lamp. Remove one screw on each side of the snap-in levers. Turn red handle on left side of unit as you are looking at it. Lift up each lever (screws you just removed) carefully. You can slide the entire unit out from under the clear plastic, then you will be able to see the lamp. It is a long halogen lamp. Do not touch the lamp with your fingers!! The oil on your skin will cause that area to overheat, boil, and blow. Disconnect wires on each side. Loosen bracket screws (2 on each side). Lift lamp out of heatsink tray by porcelain ends and slide out. Replace in reverse order. REMEMBER: DON'T TOUCH LAMP WITH FINGERS. USE GLOVES OR HANDLE BY PORCELAIN ENDS. GOOD LUCK!!
Apr 05, 2009 | Office Equipment & Supplies
Thermofax machine repair
Not really sure what you are asking? Is it a thermofax that is making noise that you use to make transparency with. Or is it transparency making? I never worked on a transparency maker in 20 years of office machine repair... What is it? Is a old machine? If it is that old it may be time to replace it....
Mar 30, 2009 | Office Equipment & Supplies
I have a 3m thermofax 45cg every paper run through is completely
I am a major seller of these machines in ebay. The machine may need a new potentiometer. Build a carrier. Put two pieces of transparency plastic sheets together with a piece of tape and use this to carry your stencils. This will reduce the heat of the lamp. Rouben (rouben@ektalc.com).
Mar 23, 2009 | Office Equipment & Supplies
3M Transparency Thermofax Tattoo Stencil Maker Thermal Copier Logo
Top 3M Office Equipment & Supplies Experts
jasbo
jasbo
Are you a 3M Office Equipment and Supply Expert? Answer questions, earn points and help others
