Question about HP LaserJet 4050 Printer
Keeps "jambing" - won't fully pick up the paper and move forward
It "picks up" the paper but does not feed the paper and then I get a paper jamb error message - although there is no paper in there.
  • 32 Answers
I work on these on a daily basis, the standard tray you are using is "Tray 2", which is the drawer tray on the bottom of the printer. If you open the front flap of the printer you will see a place where you can rest paper, This is known as "Tray 1". Remove Tray 2 and Try printing from Tray 1, (you may have to go through your menu items and make Tray 1 your default tray) If the printer is printing fine from tray 1 then the problem is one of two things.
1. Your rollers are worn
-you'll see one in the middle of the drawer tray when you pull it out
-the other one is located in the tray housing, remove tray 2 from the printer and slide your hand along the roof of the tray housing, you will be able to see/feel another roller.
Replacing both these rollers does the job 90% of the time.
2. The other thing that causes this problem is that the lifting mechanism in tray 2 is broken. This is usually not the case, and it is recommended that you replace the rollers before trying another repair.
Rollers should feel spongy and rough, they become hard and smooth the more they get wore down, until they are no longer able to catch and pull paper.
Posted on Jan 26, 2009
    Genius:
  • 2,120 Answers
Pull the paper cassette completely.
swap the gray roller in the cassette with the one up inside the printer
pinch blue tab to remove and make sure rollers snap in
  • 37 Answers
Most likely the rollers that pick up the paper need to be replaced. If you open the drawer that you are using there will be a roller in the tray itself and inside the machine where the tray just was there will be another on the "roof" of the tray hole. The easiest thing to do is to remove clean and switch their positions. This can get you up and running but you will probably want to replace them soon.
Part number RF5-1885-000CN
Hope this helps.
Paper is not feed
When the paper does not feed straight, dirty or stickyrollers can cause it to jamb or crinkle, also failure to remove all traces ofpaper from a previous paper jamb will cause further paper jambs.
Check for tiny pieces of at the edges of the rollers, and remove these piecesof paper.The rollers may be dirty or sticky and causes the paper tonot feed straight.
Try cleaning the rollers with methylated spirits.
Nov 28, 2011 | HP Office Equipment & Supplies
I cant get the paper to feed without jaming is ther a way to adjust the feed
Nov 03, 2011 | Canon Pixma iP2600 Photo InkJet Printer
My canon pixma mx320 won't feed paper properly it seems to grab one side of paper and feeds it crooked then stops
Check for tiny pieces of at the edges of the rollers, and remove these piecesof paper. The rollers may be dirty or sticky and causes the paper tonot feed straight.
Jul 26, 2011 | Canon PIXMA MX320 Color USB InkJet Printer
My hp officejet pro k8600 won't print straight.
Jul 20, 2011 | HP OfficeJet Pro K8600 Printer
I am using Canon Pixma MP145. Paper gets jammed every time i want to print. Paper gets pulled in only from right side and it gets jammed, but printer does't show any error. I have to pull the paper...
Jul 14, 2011 | Office Equipment & Supplies
Paper jams after printing a few copys. Shows error 19
Jun 17, 2011 | Office Equipment & Supplies
Printer keeps saying that i have a paper jamb and will not pick up paper to print
locate the feed roller. I should be above the paper. Clean the feed roller with water on a cloth. no chemicals. Thank you, Steven 818-888-0006
Dec 01, 2010 | Samsung SCX-4725FN All-In-One Laser...
I keep getting paper jambs or sometimes it won't grab the paper, or grabs 3 or 4 sheets and then jambs
Try cleaning the pickup roller with a little alcohol. Also try some fresh paper. Paper can pick up moisture and tend to stick together. Seperate your paper with a fannig motion before inserting.
Dec 13, 2009 | HP Officejet 5510xi Printer
Copier paper feed problems
Dear Sir; If you can buy one call"rubber rejuvenator" ( statioary store ) to clean paper pick up, feed, stop rollers may be it will work, otherwise have to replace parts ,let me know if you need it I can get it for you.
Jan 10, 2009 | Minolta Office Equipment & Supplies
HP LaserJet 4050 Printer Logo
348 people viewed this question
Ben Johnson
