Question about LG WM-2277HW Front Load Washer
Lg direct drive 8.5k WD14030D error O E then stopping
As above - is there a quick solution or do I need someone to come out . I have checked level on the machine and water is going into machine
3 Suggested Answers
  • 112 Answers
SOURCE: dE error in LG washing machine
are the taps turned on and is water pouring into the machine?
Posted on Jul 21, 2010
SOURCE: L.G DIRECT DRIVE 7 WASHER / DRYER U.E ERROR CODE
My machine is doing just the same! It is about the same age as yours. I cannot believe this is it working properly, but the manufacurers are no help.
I am seriously thinking of getting rid of it, and would be loathe to touch an LG again.
Linda
Posted on Oct 08, 2010
Error le on lg direct drive washer what can be done without a repairman
often that is a hall sensor-motor speed/position sensor. common issue. easy replacement. part under $20. check out youtube or repairclinic.com or appliancepartspros.com for how to video. part readily available at above sites or on eBay. just plug in your model number and the parts list will come up. takes about 30 mins tops
Oct 22, 2016 | LG Washing Machines
LG washing machine LE code comes up . WD14030D . What can I do to fix it? Claudia
LE code is an overload in motor. You might be washing too many items at one time. Towels are heavy when wet.
Dec 29, 2015 | LG Washing Machines
LG front loading washing machine Direct Drive 7 3.5KG Trouble shooting Error OE
go to lg.com, enter your model number and manual will show error codes and fixed for some including OE
Aug 29, 2015 | LG Washing Machines
HOW DO I STARTS MY WASHING MACHINE AGAIN CAUSE IT ALWAYS `IE` ERROR EVEN I ALREADY CLEAN THE FILTER,CHECK HOSE,THIS ERROR HAPPENS WHEN SOMEONE USE IT MANUAL WHEN NO WATER IN SERVICE,I MEAN HE MANUALLY
The IE or E1 error or fault code indicates that the washer is not filling with water. Check to be sure the water supply valves are open. Also, check to be sure the water supply hoses aren't kinked or clogged. Next, remove the hoses from the washing machine and run water into a bucket to test the pressure and flow of the water. If all of these check out and you have good water pressure and flow to the machine, you should replace the water inlet valve
If you are trying to use the machine manually, there needs to be enough water in the machine to tell the level sensor when to switch off the water inlet solenoid valve. Failing this, the machine will only show IE (Inlet Error) and refuse to work.
Feb 15, 2015 | LG WD-1070QDP 7 Kg Direct Drive Washer
LG dvd external drive not recognized by computer
ERROR 43? Check your SATA connection.
HERE'S HOW I FIXED MINE.
(IE. Computer tries to install driver for BD burner, but ultimately fails, and gives the message. "Unsuccessful" and/or "Microsoft Windows stopped device. Error 43") The SATA CONNECTION on my BD burner's EXTERNAL CASE had gone bad.
TO TEST IT. I used a SATA/IDE to USB Adapter Cable I bought for about $10 on amazon.
  • I unscrewed the external case to get at the internal drive, and plugged the SATA adapter cable directly into the internal BD burner drive (bypassing the case assembly), and plugged the other end into my computer USB port.
    • PS My BD burner POWER was working OK, so I left the big white 4pin power adapter connected to the original external case.
VOILA! Both my laptop and my desktop PC recognized the LG BD burner again and assigned it a drive letter (like it used to do).
  • Now I either need to (1) Buy a NEW EXTERNAL case ($10 - $30), (2) install it as an internal drive (could get problematic if "ANYDVD" is installed) or (3) just leave it connected via the cheap adapter cable.
It's super EASY (& inexpensive) to TEST this before spending $$$$ on a new equipment.
Hope this helps someone. It had me miffed for a while there.
Jan 02, 2014 | LG GSA-2166D DVD RW Dual Layer Burner
I have an lg direct drive 9kg washing machine and the water does not empty from the drum it flashes 03
03 error means drain pump is blocked or broken check the filter first before having someone out.
Jan 10, 2011 | LG Washing Machines
My lg 7KG 1405F model in does not complete the washing cycle stops at rising (oe) is the code
OE is drain error, which means that the machine has detected that the water level is not lowering quickly enough...Probable cause is a blocked pump filter...Check via small door at floor level..Unscrew pump cover and clear filter....Remember that all water will drain from this point, so drain machine first...Leaning the machine back can help...Good luck....Nomess
May 20, 2010 | LG WM-1480FHD Front Load Washer
What is the AE error code on LG steam direct drive washing machin
the AE code means that there is water in the base I found that the steam heater element in mine was leaking so after a quick repair using silicon and a good clean after drying the water out of the base it now works again
PS I used to be a washing machine repair engineer! I wouldn't suggest that you start opening up your washing machine!!!!
Dec 29, 2009 | LG Washing Machines
IE error message
Hi, had the same problem on a LG LD 12aw5. (No water entering). Check the inlet solonoid. There should be 220V over the solonoid. I replaced the solonoid, at first, just to have the same problem. The problem was a bit more serious, the Triac driving the solonoid burnt out, and the solder on the mainboard keeping the transformer were shot to. I replaced the Triac, soldered the Transformer - and wolla - working. If water enters - but you sill get the IE error it could be the float(checks the water level). This device tells the machine when there is enough water. If this is stuck, the machine will think no water is entering. conrad_dot_dewet@gmail.com - replace "_dot_" with "." to email me.
Apr 05, 2007 | LG 24 in. LDF 7811 Stainless Steel...
LG WM-2277HW Front Load Washer Logo
55 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
