Question about Hoover U8171-900 / U8172-900 / U8173-900 / U8174-900 Savvy Bagless Upright Vacuum
Hoover Savvy wand holder upper how to replace it
After I order the replacement part for the Hoover Savvy wand holder - upper, how do I remove the broken one and replace it?
  • 281 Answers
If you look at the bottom of the holder on the inside you will see a tab just take a small pocket screwdriver and pull out on the tab it should come off.the new one will just snap in
Posted on Apr 23, 2009
Need prefilter brush holder part 922001084, discontinued
Hello, this is Ava with Think Crucial.
You may order Hoover replacement parts directly to us. You may check our Hoover replacement parts by clicking this link: http://www.thinkcrucial.com/search?type=product&q=hoover
As a special offer here is an exclusive 10% coupon for Fixya.com readers, use code: FIXYA10
Ava B.
Think Crucial Customer Care
Oct 13, 2016 | Hoover Vacuums
Hoover Savvy Brush only runs when the vacuum is moved backwards
That is brobably a bad wiring, that lose contact when you move the hoover forward. The wirings should be checked, here is some schematic:
Wiring Schematic :
Oct 22, 2008 | Hoover U8185-900 Upright Vacuum
How do I replace the Hoover Upper cord Wrap?
Do you mean the holder? Contact Hoover with your make and model and see if they can send you a replacement. But I doubt it. Try glueing it back on if you still have it. Use a good epoxy glue.
Oct 12, 2014 | Hoover U6437-900 / U6439-900 Windtunnel...
How do i replace a valve assemblyon a hoover widepath f6020
You don't need a new hose. Remove the two Phillips head screws which hold down the wand cover. Be very careful when removing these parts. Pay close attention on how these parts are assembled. They are spring loaded and will fly out the end of the hose assembly when the cover is removed. The wand valve assembly or the nozzle valve assembly or usually the parts that break. Vac Parts Warehouse Here is a link of the parts breakdown.
Oct 12, 2014 | Hoover SteamVac Carpet/Upholstery Deep...
HOOVER VACUUM U8173-900
1) check the hose for blockage.
2) see the belt is slipin to due worn and replace .
3) check the bag/tank for full and need empty, and replace.
However go to the
http://hoover.com/support/video-instruction-guides/
and use the troubleshooting with common senses.
God bless you
Sep 06, 2012 | Hoover U8171-900 / U8172-900 / U8173-900 /...
Roller bars on bottom not rolling
The belt has probably broken. Hoover says that the belt on this model should last the life of the vacuum, but that is rarely the case. They do wear and break. Changing the belt is simple and the belts aren't to much. You can get a replacement here:
Savvy Replacement Belts
Oct 30, 2009 | Hoover U8145-900 Savvy Bagless Upright...
Hoover savvy upright, replaced belt, but brushes will not turn
One of the common problems with the Savvy models is the upper handle switch. However if it is newer, you may also have an issue with the lower cable. To test it, turn on switch in carpet mode, and at the bottom rear, wiggle thr exposed black cable. if the roller starts and stops then it is bad and needs replacement. the cost of the part is about $10 but labor intensive to replace.
Feb 26, 2009 | Hoover Vacuums
How do you replace the belt on a Hoover Savvy?
Take off the bottom plate, then remove the screws to remove the top cover, turn vac over, remove the hoover emblem, there is a screw there to remove. The top should come off, the easiest is to loosen the motor to give you some slack, then replace the belt and reasemble.
Sep 04, 2008 | Vacuums
Hoover U8171-900 / U8172-900 / U8173-900 / U8174-900 Savvy Bagless Upright Vacuum Logo
89 people viewed this question
Top Hoover Vacuums Experts
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
