Question about Ricoh FAX5000L Plain Paper Laser
Ricoh fax5000L-Can't find ethernet port?
This will sound silly but the machine was moved from our previous office to which we were able to network and use as a printer. Now, we're at new location and I can't find the ethernet connection anywhere??? It has to have one or else we wouldn't have been able to use as a printer previously? Correct? Only connections I see are two phone ports.
Thx,
George
    Genius:
  • 2,120 Answers
The small ones are for fax
The large one is for ethernet
Posted on Jan 26, 2009
Amber lights on a Cisco switch.
It sounds like you have loops in your topology. Loops will cause the LAN to crawl.
Amber, on a Cisco switch port means that a port has been blocked either as a security violation (if mac-address security is being used) or by spanning-tree protocol which shuts down ports involved in a network loop.
Check all your wiring carefully...especially the fiber-to-ethernet converters. If anybody has a hub or switch under their desk make sure they do not have two ports from that device patched into two ports in your cisco switch.
From Cisco catalyst 3500 user guide:
Solid amber
Port is not forwarding. Port was disabled by management or an address violation or blocked by Spanning-Tree Protocol (STP).
Note After a port is reconfigured, the port status LED can remain amber for up to 30 seconds as STP checks the switch for possible loops.
Nov 02, 2009 | Ortronics (MC62503)
Ricoh Aficio 1027 network connection problem with vista x86
It will not work to directly connect a network cable directly from the network port of the printer directly to your computer. You will have to use a cross-over cable and configure your TCP/IP settings manually. However, to utilize network printing and have internet access, you will want to get a router and connect your modem to the ethernet port of the router, then a network cable from pc to switch port on router, and a network cable from printer to a differnt switch port on router. Most consumer routers have a built in 4-port switch, so that should allow enough connections. You may want to consult a local IT company or Ricoh dealer for the rest of the setup. This will allow the framework for network printing and/or scanning.
Jul 28, 2009 | Ricoh Aficio 1027 All-In-One Laser Printer
Ricoh 5510L Network Setup
Go to user tools-key op tools-network-tcp ip- ip address put the appropiate info in.(including gateway address.) then type the ip address into the top portion of a web browser an you should be in web image monitor. you configure the printer there. User name is admin no password. -Carl
Jul 07, 2009 | Ricoh FAX5000L Plain Paper Laser
How do I connect a Ricoh Aficio 350 directly to personal computer
I believe the copier only has a tcp/ip port for connection, so you will still need to run it through a router, or if the PC is not on the internet, you can connect the machine directly to the ethernet port on your pc using a 'crossover' cable
You will need to download the Vista driver from Ricoh Here:
|http://www.ricoh-usa.com/downloads/downloads.asp?tsn=Ricoh-USA&path=http://support.ricoh.com/bb/html/dr_ut_e/rc2/model/x35_45/x35_45en.htm
Mar 23, 2009 | Ricoh Aficio 350e Printer
Savin 3030
"user tools"
"System settings"
"interface settings"
Press the "ip address" button and set.
The model cross references to a Ricoh MP C3000 (Ricoh builds all Savin machines). You can get all the manuals here:
http://www.ricoh-usa.com/downloads/downloads.asp?tsn=Ricoh-USA&path=http://support.ricoh.com/bb_v1oi/html/oi/rc2/model/mpc25/mpc25en.htm
Mar 12, 2009 | Ricoh Office Equipment & Supplies
Ricoh FAX5000L - Check: Network Error! [10-40]
Usually this means it was previous;y hooked up to a network, or the network settings have changed and they are mismatched. Do you use it as a printer? If not, in the user settings, (I'm not exactly sure where, but you can download a manual at ricoh.com) just set all the network settings to 0's - for example Ip address, gateway, etc. Otherwise set them correctly in order to print.
Feb 03, 2009 | Ricoh FAX5000L Plain Paper Laser
Service error 0544 on a Ricoh Fax 5510L
Hi there the error you have is that the fuser unit is lower than 130 degrees for 1 minute. Suggestion replace fuser unit turn power off the on. If problem still persists replace control board or power board.
Thanks Jason
Jun 26, 2008 | Ricoh FAX5000L Plain Paper Laser
Fax confirmation
check the settings in the paper tray. Do you have a manual? Should be info in it to change paper specs.
Aug 23, 2007 | Ricoh FAX5000L Plain Paper Laser
Ricoh FAX5000L Plain Paper Laser Logo
91 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
quennie732
fares
Level 1 Expert
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
