Question about Whirlpool Ovens
Electric plug install model R85305PD86
220 POWER CORD
Bought a prima superchef oven, when I plug it in the electricity trip switch cuts off the power.
or a wire is touching the casing. If it is new, call the retailer. If it is secondhand call an appliance technician.
If it is a UK or Australian cooker, and the wires a fixed into terminals behind a cover on the wall, you have it wired wrong.
Big volts and amps can kill.
http://www.askmediy.com/wiring-diagram-for-a-stove-plug/
wiring diagram for stove plug AskmeDIY
Aug 21, 2016 | Ovens
Flashing
switch off the oven..remove the power cord from mains..keep power button pressed for approx 15 seconds and then plug in the power cord and try using
Apr 06, 2008 | KitchenAid KEMC378 Electric Double Oven
I have a frigidaire electric stove,model # 316433603 there is power to the stove the only working is the clock
General answer for all electric stoves: Electric stoves are usually 220V in the USA. The clock is 120V. My first "guess" is that you have 120v to your clock and maybe light if the stove has one. You should have a separate 220v power cable ( see photo attached) that will power the range itself. The cord may be missing ( simple to unbolt), the cord my be unplugged, or the 220 circuit may be turned off at the fuse box or circuit breaker.
Mar 02, 2015 | Stoves Ovens
There s no power to my oven
Good Morning Friend,
I understand that you are not receiving power to your Frigidaire oven, model# FEB30T7FC, even though the power is on to your home and the breakers have not been tripped. Please try the following:
    1)Be sure the electrical cord is securely connected into the electrical junction box.
    2)There is a possibility that the service wiring is not complete.
    3)There is also a possibility that there is a short in the cord or plug. Replace the cord or plug.
    4)The house fuse has blown or the circuit breaker has tripped immediately following installation. The house fuse may not be fully engaged. Check the fuse and screw or engage circuit breaker securely.
    I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your appliances status has changed successfully. Hope this is helpful.
    -Best Regards-
    WP
Jun 21, 2014 | Frigidaire FEB30T7FC Stainless Steel...
Oven does not heat
Nothing Works, or the Oven / Range / Stovetop Works Only At Certain Times:
1.Home breaker flipped or the fuse blown?Possibly an electrical surge has flipped the breaker. Check your breaker or fuse box and replace or reset as necessary.
2.Power cord plugged in?Grab the plug and wiggle to determine a good connection.
3.Power cord damage?Damaged rubber with wires showing through or the wire is being pinched can cause issues. Electrical tape is acceptable for covering damaged wires.
4.Aclicking sound could be something wrong with a relay. Check for any loose connections around the main control board on your oven. The click you hear is a relay losing power and switching back on. If the clock resets then something is causing power interruptions to the board.
Apr 18, 2014 | Frigidaire Ovens
The terminal block that the power cord plugs into sparks
The part is called the terminal block and is part number 5304409888
It gets burned due to not being connected tight when the oven was installed or worked on last.
Replace the block and repair any burned wire ends. Make sure connections are tight and you will be good to go
May 07, 2010 | Frigidaire FEB27S5A Electric Single Oven
DOESN'T REACH OVEN TEMP
Hi...
  • Make sure the power cord is plugged in securely
  • Test the electric outlet for current
  • Inspect the connections to the terminal black
  • Test the power cord
  • Eliminate use of an extension cord, if any is being used
  • Check the outlet voltage
Regards
PCmania
Jul 08, 2009 | Ovens
Oven pilot glows when oven is turned on but the burner does not light up...is it plugged? or is it a part
Hi...
Try to do this
Good luck!!!
Regards
PCmania
Jul 08, 2009 | GE Ovens
Can I still light an oven even if the electric pilot doesnt work
Looks like your oven has a "glow" coil. That being the case, you will not be able to light the oven without power. It has to glow to open the valve, and there is no override for this. Sorry.
About the cord, you could install a plug on the cord, or simply replace the cord. (I realize you say you are trying to get one). Other than this, turkey on the grill is always good.
Mr Boo
Nov 20, 2008 | Tappan 30IN ELEC IGNa Oven
Electric power cord
good safety move to turn off gas
Apr 11, 2008 | Frigidaire FGB24S5A Gas Single Oven
Ovens Logo
Top Whirlpool Ovens Experts
Dan Webster
Dan Webster
 Fix Your Board
Fix Your Board
ashburton
Are you a Whirlpool Oven Expert? Answer questions, earn points and help others
