Question about Reddy Heater-170,000 BTU Kerosene Deluxe
Fuel filter how do i replace a fuel filter on a 125t reddy heater
  • 92 Answers
Take the side cover of and you will see where the fuel line goes into the tank. typicall the cap turns clockwise to remove and the filter is hooked right to the cap.
Posted on Jan 27, 2009
Reddy heater 125t runs for a while then stops and the flame light flashes
take off the top cover, theres an optical eye that needs cleaning some times. while u r there clean or replace the spark plug . if that doesnt do it check for spark from the coil . these r the only things that go bad on them
Jan 09, 2015 | Reddy Heating & Cooling
Need to find pump pressure & nozzle part # for reddy heater 125T
Here are a couple of tips that I wrote that tell you how to troubleshoot aTorpedo or Reddy heater...
Reddy Heater - Troubleshooting Torpedo Heaters Torpedo Heater Pump Pressure Adjustment
heatman101
Feb 05, 2011 | Reddy Heater-170,000 BTU Kerosene Deluxe
IGNITER SWITCH
If you have one of these 125T Models- RH125AT, RHD125AT, RL125AT, RM125AT, RE125AT, M125AT, PKHD125T, TKU125T, UKU125T, RD125T
The web address is:
http://www.reddyparts.com/
There are 3 ways to order your part.
Dec 21, 2009 | Reddy Heater-170,000 BTU Kerosene Deluxe
I have a 125t and the igniter works,it is getting fuel and still won't lite. Can you help?
Nov 11, 2009 | Reddy Heater-170,000 BTU Kerosene Deluxe
Reddy Heater 125t won't restart on its own after first cycle.
Sounds like a bad thermostat! (A common problem with this model) replace and it should work again!
Jan 30, 2009 | Desa International RH125AT Utility Heater
I need a wiring diagram for a Reddy Kerosene Heater Series 125T
Here is a link to a owner's manual for a RL125T ... http://12.153.20.74/manuals/110429-01C.pdf. You can find a wiring diagram on page 19. I hope this helps you.
Dec 26, 2008 | Reddy Heater RH125T Kerosene Forced Air...
REDDY HEATER 125T WON'T INGNITE
  1. Does the ignitor glow for 5 seconds when the unit is started?
  2. What is the air pump pressure reading?
These are the starting points for troubleshooting a heater that has an ingntor.
Answer these questions and maybe someone can get you started.
Dec 16, 2008 | Desa International RH125AT Utility Heater
Won't light
Are the ignitors intact? In other words, does the element make a loop back to the ceramic portion. The purpose of the LED is to notify the user of a defective ignitor. The other possibility is a bad control board.
If the ignitor is intact, but no power coming from the board (ignitor only glows for 5 seconds), then the board is bad or the fuse is blown. You might want to test the photocell while you are at it.
You will need to locate the correct model numbers to order the correct parts. "170T" & "125T" are only part of the correct model designation.
Post back if you have further questions.
Oct 23, 2008 | Reddy Heater-170,000 BTU Kerosene Deluxe
Reddy Heater-170,000 BTU Kerosene Deluxe Logo
463 people viewed this question
Top Reddy Heating & Cooling Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
Mack Baxter
T bone 1963
Are you a Reddy Heating and Cooling Expert? Answer questions, earn points and help others
