Question about Coleman Grilling
Have an old bernzomatic propane camp stove. Leeking at control valve.
Valve on the hose that connects the tank and the burner is leeking. Any way to fix or replace?
  • 3 Answers
SOURCE: coleman instastart propane stove regulator wanted
Check to see if Coleman has an attachment to replace the regulator, so that you can use a five gallon cylinder with your stove and your own regulator.
Posted on Jun 29, 2008
  • 89 Answers
SOURCE: Coleman propane stove problem
john about every coleman stove ive ever had is like that. the purpose of it is to keep the burner closest to fuel tank cooler to avoid heating up fuel tank.cook on one warm on the other hope this helps you out
Posted on Aug 23, 2008
tborn6
  • 700 Answers
SOURCE: Coleman Propane Stove 2 Burner 5430E700
Ho cold waas it out? remember that when its cold out the presswure of the propane tanks are real low and you have to warm them for the pressure to go up. if your by your car then you can place them inside with the heater going till they warm up ofr now worm them up inside first. good luck
Posted on Jan 11, 2009
SOURCE: Black soot on Coleman propane burner
Had same problem. Coleman tech support said, " clean with pipe cleaners". No directions....I would think they would provide a step by step protocol. So, I chose to take the knobs off and use the pipe cleaner where I could. I was able to take one of the two burner control knobs apart. After sticking the clean in every nook I could find, I put back together, and the flame on that burner is back to normal,
Good Luck--Daryl in Burnsville, MN
Posted on Oct 25, 2009
  • 11 Answers
SOURCE: Inefficient high pressure cast iron propane burner
Make sure you are using an adjustible high pressure regulator. Make sure there are no obstructions insde the burner tube or burner holes.
Posted on Nov 02, 2009
Why wont my old grill work with new propane tank
Turn off propane. Disconnect propane tank from barbecue. Open burner valves for about 20 seconds. Close valves. Reattach propane tank. Slowly open propane tank valve. Turn on burner and ignite
Jul 13, 2014 | Weber Q Grill
Can I buy a replacement grill?
You could try Coleman, they might be able to supply one.
The Coleman Company, Inc.
3600 North Hydraulic
Wichita, KS 67219
1-800-835-3278
TDD:316-832-8707
Jul 03, 2014 | Coleman Vintage Bernzomatic Deluxe Propane...
Need hose&tanks for model TX850
You could try Coleman directly.
Wichita, KS 67219
1-800-835-3278
Feb 23, 2014 | Coleman Vintage Bernzomatic Deluxe Propane...
413e coleman stove
Is there a reason or a need? I cannot imagine why you would want to, except as a point of interest for your camp kitchen. A new propane stove would work better and not cost all that much, relative to the work and cost of putting fittings, pipes and burners into the old stove box.
Jul 28, 2013 | Camping, Backpacking & Hiking
Need parts
If there is no nearby repair dept, try Colemn.
Wichita, KS 67219
1-800-835-3278
Mar 31, 2013 | Coleman Vintage Bernzomatic Deluxe Propane...
How do you convert a coleman 425e into a propane stove
Feb 07, 2013 | Coleman 425e 2 Burner Vintage Used Camping...
I connect the propane valve to the stove and it doesn't work, i just bought a new propane and still it doesn't work, my grandfater didn't use it for almos 4 years. what could happened?
Here's an easy solution. Turn the Tank Valve OFF, disconnect the hose from the tank and wait 5 minutes. Reconnect connect the hose to the tank and turn the Tank Valve ON VERY, VERY SLOWLY (Slow motion, slow). Once the tank valve is fully open, light the burner farthest from the grill first. Once it lights, turn it to it's highest setting and light the remaining burners the same way. Once all are lit, does the flame height look as it should? Is so, you solved the problem. If not, then you need to replace the grill hose/regulator assembly. You can purchase one from any home center or hardware store that sells gas grills and accessories. Take you old one with you for comparison purposes.
If what I suggested solved the problem, remember to always turn the tank valve ON Very, Very Slowly.
Hope this helped you solve the problem.
Apr 09, 2011 | Camp Chef TB-90LWG (NG) Grill
My coleman stove does not let the propane pass from the hose to the burner. I have determined that the hose is releasing the propane as I can depress the nozzle and get the gas to flow. The stove is clean...
This is a camp stove issue. I fixed it with my tire pump. I opened up all the valves, duck taped the hose to the stove valve and pumped air thru the system. No more blockage. Works like a charm.
Susann
Jun 16, 2009 | Kitchen Ranges
Grilling Logo
50 people viewed this question
Top Coleman Grilling Experts
Paul Carew
Charles T Nevin
Charles T Nevin
john h
Are you a Coleman Grilling Expert? Answer questions, earn points and help others
