Question about iPDA AutoScan Remote Car FM Talk Transmitter for Sprint Samsung M370
When charging, says charging error
Says charging error on phone and does not charge
Serius error do not charge, do not use the phone
Are you using a replacement charger or one that is not original? If yes, it's normal to have that error when charging. Remove it then plug it again so you can continue charging. It happened to me when I got a replacement charger and even though it gives me the error, I just unplug it then plug again until the phone is fully charged.
Mar 08, 2011 | Ericsson SCREEN PROTECTOR MEXXPROTECT...
"Charging error: Stop charging!"
sir please give to the sonyericsson service center to change the charging jack of the phone and they will check the battery status of the phone.for charging in a normal condition
Dec 23, 2010 | Sony Ericsson K618i Cellular Phone
Phone not charging,display says error stop charging
If your phone is not charging and the screen read error stop charging, you can look at the problem from angles, firstly, i suggest you try get a similar charger to charge the phone and see if it will charge it, if it does, it means the charger your charger is the problem and will need to be replace.
But, if after trying to charge with a similar charger and the screen of your phone still reads error stop charging, then, the problem is the charging port of your phone. In this case, you will need to replace the charging port of your phone, in order for your phone to charge.
Check either of the two stated above to solve the problem with your phone.
Take care.
Jul 17, 2010 | Sony Ericsson Z610i Cellular Phone
Phone off after the charging and coming error message "charging error stop charging"
Replace your phone battery. If problem persist, I suggest you bring your phone in cellphone repair center. It should be handle by qualified technician.
Dec 14, 2009 | Sony Ericsson V640i Cellular Phone
Charging error
Charging error means that the phone charger is sending an incorrect voltage to the phone, or that there had been a contact on phone charger connector.
You can temporarily restart charging by unplugging and plugging back the charger, but on the long run this can damage the phone.
To start check the connector at the base of the phone, where you hook up the charger.
If there is dirt or oxide in there remove it, you can clean it using cotton buds and isopropyl alcohol.
If that does not solve the problem, go to any phone shop and buy a replacement AC charger for $10 or less.
Nov 09, 2008 | Sony Ericsson K600i Cellular Phone
Charging Sagem my401c - error
Charging errors occur when the phone charger is sending an incorrect voltage to the phone, or that there had been a contact on phone charger connector.
Aug 05, 2008 | Sagem my401x Cellular Phone
Battery Charging Error - Disconnect Now error message
Most new phones allow charging with the USB cable. With some phones, you also have the option to select whether you want to allow USB charging. If you're trying to charge with USB, make sure that your phone supports USB charging and that the option is switched on. please check ur settings..All the best
Happy to help
Have a nice day!
tc
May 30, 2008 | Sony Ericsson W850i Cellular Phone
Error message when try to charge
I suspect that your charger has malfunctioned. You will need to get a new one.
Mar 06, 2008 | Sony Ericsson K510i Cellular Phone
iPDA AutoScan Remote Car FM Talk Transmitter for Sprint Samsung M370 Logo
70 people viewed this question
Top iPDA Computers & Internet Experts
David Payne
David Payne
Are you an iPDA Computer and Internet Expert? Answer questions, earn points and help others
