Question about Whisker City Cat Scratch Prevention Tape WC CAT PROTECTION TAPE SHEETS
Can I put whisker city no scratch on my leather couch
How do I repair a chewed hole in leather?
My sister inlaw cut some excess leather from underneath the couch used some gorilla glue the patch glued from below the original fabric a patch on the bottom instead of over the top so not to have a raise seam that would peal off . It isn't new but it isn't that bad. hope Its not a big rip.
Jul 27, 2015 | Furniture
Leather couch seam tear
Don't work with some glue. You must fix it from interior side. Or you can sew with needle and thread black exterior, but a Chinese work. This solution will take time, the solder did not think so.
Jun 24, 2013 | Furniture
I want to repair my coaster bonded leather sofa ,the seat and back is peeling very very badly
Bonded leather is not very difficult to repair. Follow to directions in the following article. and you should be almost as good as new. Almost! How to Repair Bonded Leather ' EZ Fix 101.com
Aug 16, 2012 | Coaster Red Bonded Leather Sectional Sofa...
How do I repair cat scratches from my leather furniture.
Here is alink to a guide for repairing cat scratches on leather furniture. But it's agood idea to also invest in a scratching post, so your cat leaves yourfurniture alone in future.http://www.cozycatfurniture.com/gift_certificate.html
Jul 23, 2012 | Cats
Remove ink from leather safely
go to advanced discount auto parts and ask for blue magic capert cleaner, dont not spray on the sofa,spray on a rag and then clean the sofa, if by chance it starts to change the color Stop!!!
Jun 30, 2012 | Coaster Red Bonded Leather Sectional Sofa...
How to get pen off fake leather
Fake leather AKA Bonded leather markings is a fixable problem. First assumption is that the pen markations did not etch or scratch the leather. Leather color spray is available from the Mohawk Co http://www.mohawk-finishing.com/ for a variety of common leather colors. The goal is to mask the ink in this case. Should the leather be etched or scratched, there are flexible filling adhesives that fill marks in leathers and are heat cured. Following the fixing of a scratch the mark is then colored to match the furniture piece.
Jun 28, 2012 | Furniture
Dvd won't play
The following suggestion may or may not fix your DVD reader.
You can put a CD/DVD cleaner disk to put into your TV to clean the laser’s eye. The best cleaner disks have the “whisker” that protrudes from the disk and have a fluid you put on the whiskers to aid in the cleaning. Read the cleaner’s directions before using.
You will want to put this disk in your TV at least at three different times to maximize the cleaning.
After you have completed the cleaning, unplug the TV for about 3 minutes. Plug the TV back in and try a non scratched DVD in your TV to see if the cleaning has fixed your problem.
If the TV takes a long time to read the disks and or the TV is not able to read the disks, then the DVD assembly has failed. You could purchase a replacement DVD assembly and install it yourself if you think you are up to it. You just have to remove the stand, the back of the unit, and the old DVD assembly.
I hope this information has helped you.
Good Luck.
May 28, 2010 | Haier HLC26R1 26 in HDTVReady TVDVD Combo
Whisker City Cat Scratch Prevention Tape WC CAT PROTECTION TAPE SHEETS Logo
85 people viewed this question
Top Whisker City Cats Experts
Tom Chichester
Ruth summersides
RANDY POWERS
Level 1 Expert
Are you a Whisker City Cat Expert? Answer questions, earn points and help others
