Question about Radio Shack Cinego D-1000 Multimedia Projector
Not coming on
When I push the button on it start flashing like it is cooling down and then it cuts off ,no light come from the viewer at all
  • Anonymous Feb 25, 2009
    When I put a dvd in , It plays for the first 15 seconds and then it stops playing and theres no picture and a red light goes on in a circular motion around the power button.
  • diamonddream Feb 25, 2009
    When I put a dvd in it plays for the first 15 seconds and then it stops playing. Then a red light comes on in a circular motion around the power button.
  • 56 Answers
THE LIGHT BULB MAY BE BURNED OUT
OR
HEAT TRANSISTOR IS BAD
PHOTO TRANSISTOR IS BAD
FAN MAY HAVE INTERMITTING PROBLEMS NOT ALLOWING THE MONITOR TO COME ON
CANDYMANGANDY
Posted on Jan 27, 2009
Flashing light on my dash of a engine
hi patricia
FIAT engine light flashing means the ECU needs adaptation,
you can do it yourself just follow this procedure.
( remember not to accelerate unles is stated) start the engine
let it to warm and wait for the cooling fan to come ON then OFF 3 times, like ON,OFF,ON,OFF,ON,OFF. After the fan cuts off the third time accelerate fully down let the engine rev up to 4000 only then leave the accelerator let the engine goes down back to idle, do this 3 times.the engine light should go away.
good luck
Feb 08, 2014 | 2001 Fiat Punto
I am trying to start a cyle and everytime i push the cycle button it does not light up and the quick rinse button comes on and flashes nothing works at all if i push heavy wash it comes on and nothing...
You haven't told me how many times the light flashes, but I will take a guess that this is an error code associated with the water entering the machine being too cool. I believe the machine expects the water to enter at 110 degrees F (43 Degrees C).
To clear the error, press "Heated Dry" then release, then press "Normal Wash" then release and repeat this sequence until all the lights on the machine go solid green. Once this happens, hit ""Cancel" and the machine will reset.
The fix for the root of the problem is to increase the temperature of the incoming water in future (Turn up your water heater temperature a little)
Jul 05, 2011 | Kenmore Elite Stainless Steel 24" BuiltIn...
The washer cuts off midway through cycle and will not start again after pushing start button. It will, however start after a few minutes of wait time.
That is usually an indication of a thermo-switch reaching it upper level. Cuts off everything until things cool down.
Jun 07, 2011 | Dryers
Have a Frigidaire Gallery Series front loading dryer and it keeps giving me an error(?) code, E68. When I start the dryer, it runs for a couple of minutes and then It starts beeping and flashing this code...
Sorry to read about your problem. this should be your E68 problem
You have a defective button on the control board.
The best thing to do is go into the diagnostic mode.
Turn the dial to Normal. Press and hold the Select and Pause/Cancel keys for 6 seconds, or until the Drying/Cool Down/Press Saver/Clean Lint Filter lights come on.
Then press the Start and Pause/Cancel Buttons 4 seconds. This puts you into the diagnostic mode to check the keys. Now, turn the dial 4 O'clock position, or 75. This will allow you to check all your buttons. As you press each key, it will light all the lights above it. When you press a key and it does nothing or the lights above any certain key stays on without pushing it, this button is stuck. If you can't clear it, you probably have to replace the control board.
I tried to help you. Please help me and Vote/Rate this response. Thanks and good luck
Dec 21, 2010 | Frigidaire Dryers
Dishlex Global 300 starts to fill with water, then
ok this sounds like your water has stopped coming in or timed out b4 the pressure switch is activated. hold eco button down, u will hear a beep then a light will come up, keep pushing the button until u see the light.reply and tell me which light has come up, and i can help u fix the problem.
Apr 24, 2010 | Dishwashers
Kenmore Ultrawash dishwasher Model 665 15810000. Originally "water heating" light was flashing and no water in dishwasher. Replaced water inlet valve. Turned power back on, normal wash light goes on...
lock light is locking the panel push this child lock button for 3 sec and see if it un locks . then try it again .. may have a pannel out. mm
Dec 06, 2009 | Washing Machines
When I push the on button after the oven is in "Snooze" mode, the oven starts cooling down instead of heating up . Then when I push the on button again, the screen comes up and says oven ready.
Pushing the Back touch pad will give Snooze option, push it again and the Oven Off comes up. From there you can leave it off to cool down and clean, or push the bottom right pad to turn on,
Jul 16, 2009 | TurboChef TORNADO Electric Oven
My Hitichi tv will not turn on. When the power button is pushed, the lights come on as if it was going to turn on. Then, the lights begin to flash as if the tv was turned off. After the lights stop...
This is known to happen. You could let it cool down for an hour. If it still persists, then it will need to be fixed.
You can also try unplugging the tv set for at least 4 hours to do a "hard reset"
Feb 01, 2009 | Hitachi 50V500 50 in. HD-Ready LCD...
198 people viewed this question
Top Radio Shack Office Equipment & Supplies Experts
jasbo
jasbo
xxxxxx xxx
Pie-man
Level 1 Expert
Are you a Radio Shack Office Equipment and Supply Expert? Answer questions, earn points and help others
