Question about Biostar H55 HD Motherboard
Why i cant ditect my dvd rw in windows 8?
My processor is core i3. when i enter a bootable disk nd restart pc only then i can see the dvd rw.. how can i solve this problem?
  • Biostar Master
  • 3,606 Answers
Hello download the manual here:
http://www.biostar.com.tw/app/en/mb/introduction.php?S_ID=473#dl
You need adobe reader, to read content.
Look in the bios setup, for basic boot settings for the drives.
The dvd drive, must be the first boot device, so the pc can boot from the windows disk.
The harddrive, must be the second boot device.
Good luck
Posted on Jan 23, 2013
When go to power computer it wot turn on
Power supplies don't normally fail so soon but check your AC outlet with another device (light or similar) to make sure it isn't a tripped breaker or blown fuse in your home.
Since most everything we own is built as cheap as possible, infant mortality is surely possible.
Hope your warranty is still in effect.
Mar 15, 2015 | HP Pavilion Slimline s5-1414 Core i3-2130...
I put new in power supply and went power on my computer and it would not turn on
If the computer was working before you changed the power supply then likely you have not connected all the header wires properly. Check your wiring again. If you replaced the power supply because the computer was not working, then you may have an issue other than power supply, such as a bad motherboard.
Dvd rom not work
most of this slik dvd roms fail with time ,get yourself an external dvd/rw
Sep 17, 2013 | Acer Aspire Z3801 All-In-One Desktop Pc...
My laptop is showing the smart hdd error at startup. how can i disable that message? I am using hp pavilion 2000 laptop.
The SMART hard disk check has detected an imminent failure. To ensure not data loss, please backup the content immediately and run the Hard Disk Test in System Diagnostics.
Hard Disk 1 (301)
F2 System Diagnostics
ENTER - Continue Startup
For more information, please visit: www.hp.com\go\techcenter\startup
Sep 02, 2013 | HP 2000-2B89WM Intel Core i3-2328M...
Enable hyptreading
Hyper-threading is technology available on some Intel processors. If your process and motherboard are hyper-threading, you can enable to option in your Windows operating system. Hyper-threading allows your processor to perform multiple operations at once. Hyper-threading is used on multi-core processors and will share the workload among each core.
Restart your computer and repeatedly press the "Del" key or the F2 Key to enter BIOS this will vary depending on your computer and BIOS Press "Tab" to highlight "Main" then use the down arrow key to select "Hyper-Threading-Technology" then press "Enter". Select "Enabled" then press "F11" to exit and save changes. Your computer will now restart with hyper-threading enabled. Click "Start" then "Control Panel" and double-click "Device Manager". A window will appear showing your computer's hardware devices. Click the "Processors" drop-down menu. Right click one of your processor cores then click "Properties". Confirm hyper-threading is enabled. Hope this helps.
Jan 01, 2013 | Lenovo IdeaCentre B320 7760-2SU All-In-One...
Windows will not open
Try reseting your bios if reinstalling windows failed.
Jun 10, 2012 | Acer Aspire 5750 15.6 inch Laptop Intel...
How can i use oracle in win 7 platform of i3 processor?and which processor is best core 2 duo or core i3?
Windows 7 Release Candidate was publically released on May 5, 2009. This should be the final release before it goes live later this year. download it, install it in a VM inside of VirtualBox and try to install Oracle on it. There is no Oracle release for Windows 7, so instead grab the Windows 2008 one. The install is pretty straight forward. The only "gotcha" is that if you go to the command prompt, you need to run it as the Administrator, so that all of the Oracle commands will work (lsnrctl, dbca, netca etc...) Really there is not that much to it as it was pretty seemless. So, if you download Windows 7, then you can also download Oracle 11g and start playing with it today!
Here is the second answer
We live in the times where computing power, once available only at the level of super computers, has been made available to the common man. The forerunner in the race, who's probably miles ahead of its competitors is the computing giant Intel. According to the needs of computer users, Intel delivers chips with varying degrees of power and clocking speed. These include the entry level, mid level and high end processors. The latest entry level Intel chips to hit the market are the core i3 processors which are aimed at taking up the place previously held by the core 2 duo processors. The new hierarchy of Intel chips in ascending order of computing power are the core i3, core i5 and core i7 processors. Although core 2 duo processors are slowly being phased out of production, they are still available in the market. In this article, I present a core i3 vs core 2 duo review which may help you decide which one to go for.
Intel Core i3 Vs Core 2 Duo Comparison
A comparison between processors was simple some years ago with a single core processor. All you had to look at was the clocking frequency and the cache size. The entry of multiple core chips changed it all and life became complicated. With dual, quad and even six core processors hitting the market, there are many more factors to be considered than before. Intel's dual core and core 2 duo processors were the first ones to introduce the multicore processor computing power. The quad processors created later have given rise to the quad core vs dual core debate, as well as the core i5 vs core i7 comparison which is something that high end computing market consumers should think about. Prior to that, we only had the 32 bit vs 64 bit processors comparison.
Today, Intel has gone through a lot of designing and planning to introduce core i3 processors that are an improvement over the core 2 duo processors. The following Intel core i3 vs core 2 duo processor comparison will give you an idea about how the i3 processors are different from their dual core predecessors. The two points of comparison will be technical specifications and the only other factor which matters that is performance.
Core i3 Vs Core 2 Duo: Technical Specifications
Like the core 2 duo processors, the new core i3 line of processors, have two cores with many other technological enhancements including an integrated GPU (Graphic Processing Unit). The clocking frequency of the core i3 series of processors ranges from 2.26 GHz to 3.06 GHz. Each processor is endowed with the new line of advanced technologies including Intel developed hyperthreading, Intel virtualization and smart cache technology which makes these chips faster than core 2 duo processors. This is the most important point in the core i3 vs core 2 duo comparison.
The Intel codename for core i3 architecture is Clarkdale. They are based on the Westmere architecture with 32 nm fabrication and a direct media interface (DMI) bus. The socket type used for core i3 processors is LGA 1156 and the RAM type is DDR3. They support mother boards with the following types of chipsets- H55, P55, H57 and Q57.
Let us have a look at the latter processors in the core i3 vs core 2 duo comparison. Core 2 Duo processors come in three types of architectures, codenamed as Conroe, Wolfdale and Allendale. With 65 nm and 45 nm fabrications they are a tad slower and less power efficient than the 32 nm based core i3 processors. The socket used for core 2 duo processors is LGA 775 and they come with a FSB bus. The FSB bus is a lot slower in operation than the DMI bus in core i3 processors.
Coupled with the fact that the i3 processors have a L2 cache size of 2 x 256 kb and a L3 cache size of 4MB, with hyperthreading and smart cache enabled, core 2 duo processors are indeed slower. On top of that, DDR3 RAM compatibility in core i3 processors, compared to DDR2 compatibility of core 2 duo processors makes them even more faster. The price range of Intel core i3 is $100 to $133, which makes them top options in the entry level market.
Core i3 Vs Core 2 Duo: Performance
The technical specifications have made it clearly indicated that Intel core i3 beats its predecessor, core 2 duo in almost all departments. This is but natural as they were indeed designed to replace them. Be it processing speed, multitasking or graphic output, opting for core i3 processors is the logical choice to make!
Hope the core i3 vs core 2 duo processor comparison provided in this article has made it easier for you to choose the right processor for your personal desktop computer or laptop computer. Going for a more advanced line of processors is always beneficial in the long run. You should also check out the Intel core i5 and core i7 processors before going ahead as they offer far more computing power and speed, compared to the entry level core i3 or core 2 duo. Decide on the processor you want according to your usage requirements and of course giving due thought to your vitamin 'M' levels!
Dec 16, 2010 | Intel Core i3 540 306 GHz (BX80616I3540)...
I have an image file ''win 7'' downloadedit, i want to burn it in DVD bootable to install in my pc, i have tried with nero, magic iso, imgburn but when i restart my pc, it doesn't start from cd and i can...
Ignoring the suspicion that any "downloaded" image of Windows 7 probably is a "bootleg" copy of copyrighted software ......................
Restart your computer, and immediately press DEL to enter BIOS SETUP mode.
Reconfigure your "boot devices" to make the CD/DVD reader the *FIRST* bootable device.
Save the updated configuration, and reboot with the disk inserted into the reader.
Or, try the disk on another computer.
Jan 04, 2010 | Microsoft Windows Vista Home Premium with...
Wont boot
go to BIOS and enable the secondary drive auto detect.
if you manaully set the drive to primary, secondar. the system should be able to detect it as you have set it. if you select cable select or auto. the sytem will put the drive connected to the end of the IDE cable as primary.
Apr 02, 2009 | Intel Motherboard
Biostar H55 HD Motherboard Logo
55 people viewed this question
Top Biostar Computers & Internet Experts
Jayburt
David
David
Matthew Spark
Matthew Spark
Are you a Biostar Computer and Internet Expert? Answer questions, earn points and help others
