Question about Bosch 1199VSR 8.5 Amp 1/2 Inch Hammer Drill
Bosch VSR 1199 hammer drill keeps slipping in hammer mode
My 4 yr. old Bosch VSR 1199 hammer drill started slipping when I'm using it in hammer mode to drill 3/16" Tapcon holes in concrete. What part do you think I should look at when I disassemble it? I found the whole parts diagram online ( http://www.ereplacementparts.com/bosch-1199vsr-electric-drill-parts-c-128_1010_4165.html ) , and it looks like most parts are available. I am very handy at repairing my own tools. Just haven't had a chance to look at this one yet. Thanks, Marc P. Auburn,NY jakob0522@verizon.net
  • 2 more comments
  • Anonymous May 08, 2009
    mine started slipping in concrete after drilling ~ 6 1/2" holes, but also has it in normal mode. my cheapy battery roybi has more torque at this point. I can stop the chuck on the bosch with a firm grip now...
  • Corey McConnell
    Corey McConnell May 11, 2010
    Does it only slip in hammer mode?
  • David Ford
    David Ford May 11, 2010
    That is a loaded question, you should inspect all the parts but if it is slipping I would look at the gearing and drive assembly. Does the motor make a grinding sound that is louder in reverse or forward, if so the armature and the gear that it drives should be especially looked at. I would recommend cleaning all parts and a close inspection will show the problem. Let me know
  • Roger Camacho
    Roger Camacho Oct 12, 2013
    Shaun what is the part number my drill is doing the same exact thing.
    Sniper:
  • 79 Answers
Inside there is a little plastic shaft, where the selector hooks to. They have had problems over the years stripping. Replacement part is still plastic. Yay! You may need a bearing puller or find some way to get the clutch off the shaft. Lemme know. Please rate me
Posted on Jun 18, 2009
Need to replace the chuck on a Bosch 1194 VSR Model number 0 601 194 739
open the jaws of the chuck up all the way. There is a retaining screw at the bottom ( under where the drill bit would go). this screw is reverse thread. once the screw is out, get a 3/8 inch allen wrench. chuck the short end into the drill chuck. set the drill on a workbench with the chuck hanging off the edge a bit. Hit down on the allen wrench with a hammer ( counter clockwise) and the chuck will unscrew normal thread.
Oct 21, 2010 | Bosch 1194AVSR 1/2" Vsr Hammerdrill
Bosch 11241EVS combo hammer, spins slowly.
have you tried turning the speed dial up and down a few times, sometimes that works. I am not aware of any to bypass the electronic circuits in this tool.
May 23, 2010 | Bosch Drills
How do I replace the chuck on a bosch 1199vsr?
If there is a chuck bolt in the center (where the bit goes) remove it (left hand thread). The chuck is threaded onto the splindle(right hand thread). On some of those drills they have a small hole in the housing that lines up with a hole in the spindle. Put a pin punch in to lock the shaft so you can unthread the chuck. If you clamp a 3/8" allen wrench in the chuck it acts as a good handle. If there are no holes to lock the chuck, if you lay the drill on a bench and give the allen wrench a sharp blow with a rubber mallet it will unthread the chuck. If the chuck is damaged and will not hold an allen key you will have to cut the spindle off and replace the chuck and spindle.
Hope that helps
Jan 27, 2010 | Bosch 1199VSR 8.5 Amp 1/2 Inch Hammer...
I have the same problem. 1199VSR hammer drill. The tool is 18 months old (out of warranty) and has barely been used - I think I used it for for two jobs - all together about 12 1/2" diameter holes. It...
Check the motor brushes for breakage, badly worn, or weak springs (heat damage). Keep track of brush wear pattern when removing and reinstall in the same orientation.
Jul 26, 2009 | Bosch 1199VSR 8.5 Amp 1/2 Inch Hammer...
Hammer drill quit
If it is an 1199, forget it. Replace the brushes and do NOT use for hammering. It is a design problem. My unit was repaired 4 times and hammered about 5 holes each time before same failure.
Jul 02, 2009 | Bosch 1617014127 Brush Set For 11224vsr
Chuck on Bosch 1194 vsr drill is rusted... how to remove?
you are half right. The screw that you see is a chuck retaining screw (LH thread) to keep the chuck from loosening up when in reverse. What you need to do is if you have one remove it first and then find a bent handle allen wrench about the size of the chuck capacity, lock the shorter end in the jaws and then position the wrench at about a 30 deg angle and put the chuck on a block of wood or bench and take a hammer and hit it counter clockwise. If you have a wrench small enough to lock onto the spindle use it and brace it on the bench. If this tool has a high and low setting use the low and if clutch equipped the drill only. Let me know if you need more help
Jun 26, 2009 | Bosch 1194AVSR 1/2" Vsr Hammerdrill
Hi Seadog--can I download a manual for a Bosch 1194 svr hammer drill on your website?
Go to the BoschTools website and look under service and parts. You can download drawings there.
Jan 31, 2009 | Bosch 1194AVSR 1/2" Vsr Hammerdrill
Bosch 1199VSR 8.5 Amp 1/2 Inch Hammer Drill Logo
941 people viewed this question
Top Bosch Drills Experts
Matt Olenzek
Matt Olenzek
woodzowl307
Are you a Bosch Drill Expert? Answer questions, earn points and help others
