Question about Acer Aspire 5100 Notebook
Acer orbicam on Aspire9301AWSM1
Orbicam has stopped working, have tried moving photos to an external drive but this does not sort the problem
I have an acer aspire 5100 and i need to kno whow to fix my acer obricam because it will not let me open the link on my desktop?
Try moving any photos you may have out of the "my Pictures" folder located in your documents.
The acer orbicam sometimes encounters an error when there are photos in the photo folder.
I know this may sound strange, but I have seen it happer
Jan 18, 2010 | Acer Aspire 5100 Notebook
Instructions for use acer aspire5050-5430 notebook orbicam
These are the text-only instructions:
Launching the Acer OrbiCam
To launch the Acer OrbiCam, double-click on the Acer OrbiCam logo in the
desktop.
OR
Click Start > All Programs > Acer > Acer OrbiCam. The Acer OrbiCam capture
window appears.
Changing the Acer OrbiCam settings
Resolution
To change the capture resolution, click the displayed resolution at the bottom
right corner of the capture window, then select the desired resolution.
Note: Setting the camera resolution to 640 x 480 or larger does
not change the capture window size.
33
English
Options
Click Options to display the Window, Preview, and Folder tabs. Use the options
to change the capture window size, preview settings, and the folder for
captured photos or videos.
Camera Settings
Basic settings
Click the Camera Settings icon on the bottom right corner of the capture
display, then select Camera Settings from the pop-up menu. You can adjust the
Video, Audio, and Zoom/Face tracking options from this window.
34
English
Capture settings
From the Camera Settings window, click the Driver Settings button. The
Properties window appears.
Device Settings allows you to change the camera brightness, contrast, hue,
saturation, sharpness, etc.
Advanced Settings allows you to activate gain control, implement image mirror,
select image enhancements and anti-flicker settings, and turn on/off the camera
indicator.
Zoom/Face Track Settings allows you to adjust the zoom level and turn the
face-tracking feature on or off.
Capturing photos/videos
To capture a photo or a video clip, rotate the Acer OrbiCam to get the desired
angle, then click the Take a Picture or Record a Video button. The Windows
Picture and Fax Viewer or the Windows Media Player automatically launches to
display/play a preview of the photo/video clip.
Note: By default, all photos and videos are saved in the My
Pictures and My Videos folder.
Using the Acer OrbiCam as webcam
The Acer OrbiCam is automatically selected as the capture device of any Instant
Messenger (IM) application. To use the Acer OrbiCam as a webcam, open the IM
service, then select the video/webcam feature. You can now broadcast from
your location to an IM partner anywhere in the world.
Jun 10, 2008 | Acer Aspire 5100 Notebook
My acer orbit cam has stopped working
try to re-install the orbicam application,
if it isnot working, try to reload the operating system.
Jun 01, 2008 | Acer Aspire 3680 Laptop
Aspire 5610-2762 Orbicam not working
Hi uninstall the Cam application software from add/remove programs and reinstall the same .
May 06, 2008 | Acer Aspire 5050-3242 Notebook
Acer OrbiCam is not recognized on my Acer Aspire 5610 series laptop
Sounds like the original program got corrupted. When was the last time you ran disc defrag? Anyway, to fix, for some odd reason, moving all your pictures to a new file, leaving your picture file empty, may fixya.. If that doesn't work, reinstall the original Orbicam program as follows: first go to control panel, then check out device manager to see if you have any nasty big checks. If "imaging devices: has a big check, try reinstalling the driver there. If that doesn't fixya, click on Start, then Acer Empowering Technology, then Acer E-Recovery, and choose Restore Apps and Drivers at the bottom of Restore tab. It will extract; then click Install for Vista or (XP) on the left - click Drivers - Camera or CCD - on the right side of the screen for your model which you saw in device manager. Please let me know if that doesnt do the trick.
Apr 17, 2008 | Acer Aspire 5610-4648 Notebook
Acer orbi cam
try to uninstalled the orbicam application and then restart
and installed it again.
FYI, if you don't have the application, you can download from acer website; www.acerpanam.com
There are 3 type of orbicam (bison, suyin and logitech).
i don't know which one is yours, you can try 1 by 1.
make sure you uninstalled when you want to installed another orbicam application.
Apr 03, 2008 | Acer Aspire 3680 Laptop
Acer orbicam
The Acer webcam (a Logitech) should work. You may have purchased el cheapo Acers (really reprehensible of Acer) loaded with Vista, but not 2 MB memory or even an M chip instead of a dual-core. If so, unfortunately, you are going to be plagued by problems of all sorts, as most agree that Vista's power-hungry maw demands this much power to run smoothly. however, you may be able to fix you webcam by moving all of your pictures to a new file---it usually works, heavens knows why. If that doesn't work, try reinstalling the webcam sofware as follows: (actually, first go to control panel, then check out device manager to see if you have any nasty big checks. If "imaging devices" has a big check, try reinstalling the driver there. If that doesn't fixya, click on Start, thten Acer Empowering Technology, then Acer E-Recovery, and choose Restore Apps and Drivers at the bottom of Restore tab. It will extract; then click Install for Vista or (XP) on the left - click Drivers - Camera or CCD - on the right side of the screen for your model which you saw in device manager. Please let me know if that doesnt do the trick.
Mar 27, 2008 | Acer Aspire 5610-4648 Notebook
Acer orbicam stp working
I am no computer expert. However I recently had a similiar problem. I removed all photos from my picture file to my documents, and it worked fine. May be worth a try.
Feb 04, 2008 | Acer Aspire 5100 Notebook
Acer Aspire 5100 Notebook Logo
22 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
