Question about KitchenAid Architect KBFA20ERSS Stainless Steel French Door Refrigerator
Refrigerator stops cooling
Compressor locks and overheats. If I unplug and let it cool overnight, it starts and works for a while. I tried pulling it out and running a fan next to compressor, but it eventually heated up.
  • 410 Answers
You have a bad compressor. if the refig is under 5 years old then the repair should be in warranty to kitchenaid. Good luck Peyton
Posted on Jan 27, 2009
REFRIGERATOR WON'T COOL
Sound like the compressor is locked up. Sometimes you can get lucky by hitting the compressor with a rubber hammer to jolt it loose. This is an old trick that doesn't always work, but worth a try. Don't hit it so hard that it dents or bends the shell of the compressor.
Feb 01, 2014 | Samsung RM255LASH Side by Side...
Hotpoint Refrigerator constantly runs and doesn't shut off normally.
Sounds like the thermostat is not working that is what tells the compressor it is cold enough shut off.
May 17, 2012 | Hotpoint Refrigerators
Refrigerator stops cooling but lights are on. When I pull the AC plug and plug it in again the Refrigerator starts cooling again.
See the overload relay beside the body of the motor compressor where the wires are connected, full it out and have it check, this is act like a sensor, when it sense too much heat it will automatically cur the power to the compressor which wil stop cooling, and when you unplug it or cool it down then it will de-activate the sensor.
try other overload relay see if the porblem still there
Nov 05, 2009 | Refrigerators
Stopped cooling
Best to unplug the refrigerator now and let compressor cool. The internal overload will be damaged if power remains on and trying to start. We need to test the compressor and start components before you buy anything, Let me know Sea Breeze
Aug 18, 2009 | Frigidaire FRS26R4A Side by Side...
Refrigerator not cooling and freezer not freezing
The compressor start relay or start capacitor is defective and I will need to go through this in a step by step process until we locate the problem For now unplug the refrigerator to prevent compressor damage until we locate the problem. Let me know when you are ready. Sea Breeze
Jun 24, 2009 | Frigidaire FRT17G4B Top Freezer...
Does not cool. Compressor Hot
Sounds like the compressor starting relay. This should be available from from most appliance parts retailers that carry refrigeration parts. It is probably a plug-in relay which is easy to replace. PULL THE PLUG UNTIL YOU GET IT! Constant cycling on the thermal protector will damage the unit.
Ray
Oct 19, 2008 | GE PWR04FANBB Wine Cooler
I have an Amana bottom freezer fridge model ARB2517CSR the freezer stopped working I cleaned the coils and the fan was working and the fridge was making a buzzing sound. The sound stopped, so did the...
If the coils were really dirty, the compressor is probably just overheated. Let it cool down overnight then try again. If it still won't stay running it needs serviced. Could be the start relay or internal overload/overheat sensor in the compressor. If the coils were really dirty and it was used like this for a long time, the compressor could be damaged. It is almost never worth replacing a compressor in a home refrigerator.
Jul 03, 2008 | Stainless Cruise 49 Marine Refridgerator -...
Kirland Refrigerator
It sounds like your compressor has failed. The hum is the compressor trying to start and the click following is the over current protector opening.
Jun 16, 2008 | Refrigerators
Refrigerator not cooling.
compressor has failed. not a diy job
Apr 25, 2007 | Amana ASD2622HR Side by Side Refrigerator
KitchenAid Architect KBFA20ERSS Stainless Steel French Door Refrigerator Logo
255 people viewed this question
Top KitchenAid Refrigerators Experts
John Tripp
John Tripp
vince
mike cooper
Are you a KitchenAid Refrigerator Expert? Answer questions, earn points and help others
