Question about HP Printer Cartridges (Complete List): , HP C9703A magenta toner cartridge
Minolta CMS magicolor printer 2300W
I need to replace the magenta cartridge When I click on replace cartridge, and select magenta in the dialogue box, a box comes up quickly, but never loads, then just goes away. If I click on the dialogue box that comes up (anywhere) it then says the toner replacement is not responding. I just changed the cyan and yellow. Now I can't get to the magenta to replace it, although I keep getting a message that it needs to be replaced. Any ideas.
  • 3 Answers
There should be a light flashing on the printer. try pressing the button nearest to it to see if that will move the print head out in order that you can replace the cartridge
Posted on Jul 21, 2007
Konica Minolta Magicolor 2300W firmware needed
firmware is located on secure web site try having a Konica Minolta tech come out and flash the firmware
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Apr 15, 2010 | Minolta magicolor 2300W Laser Printer
I have followed the instructions exactly for replacing the black toner cartridge on my Magicolor 2300 DL, but i still have the error message "Replace Toner Black." I tried taking out the cartridge and...
If you have changed the toner cartridge, the printer must complete a calibration cycle (up to 150 seconds). If you open the door before the Ready indicator on the control panel lights up and the Error indicator turns off, the printer stops and repeats the calibration cycle.
1. Open the Status Display (double-click on Status Display icon in the system tray on the lower right-hand portion of the task bar, OR click Start/Programs/KONICA MINOLTA magicolor 2300W Utilities/KONICA MINOLTA magicolor 2300W Status), and then check which toner color is empty.
2. From the Print menu choose Toner Replace...
3. In the Color list box, select the color of the toner cartridge to be replaced (CYAN, MAGENTA, YELLOW, or BLACK).
4. Select the capacity of the new toner cartridge (1500 or 4500).
5. Click OK.
6. When the toner indicator on the control panel starts flashing, open the printer's front door. The carousel is automatically repositioned so that the appropriate toner cartridge can be removed.
2300-0.gif 7. Insert your thumb and index finger into the two holes in the front of the toner cartridge, and then pull the cartridge straight out about 6" (15 cm).
2300-1.gif8. Support the middle of the cartridge with your left hand, and then pull out the cartridge.
2300-2.gif9. Remove the new toner cartridge from its shipping carton.
10. Remove the protective cover clearly marked 'Remove'.
Each toner cartridge has a colored end that corresponds to a color inside the cartridge slots. Always install the toner cartridge in the slot of the same color.
2300-4.gif11. Support the middle of the cartridge with your left hand, insert the thumb and index finger of your right hand into the two holes in the front of the toner cartridge, and then insert the cartridge so that the guides on the cartridge fit into the rails in the cartridge compartment in the carousel.
2300-5.gif12. Gently push the new toner cartridge into the printer.
13. Close the printer's front door.
The printer must complete a calibration cycle (up to 150 seconds) after any consumable has been replaced. If you open the door before the Ready indicator on the control panel lights up and the Error indicator turns off, the printer stops and repeats the calibration cycle.
Sep 01, 2009 | Konica Minolta magicolor 2300DL Laser...
Magicolor 5430 dl doesn't print magenta
Please check your magenta cartridge if they are properly installed.
Make sure that your magenta cartridge are not empty.
Make sure that you are using the original konika minolta cartridge and not just a refill one or replacement one.
Aug 20, 2009 | Konica Minolta magicolor 5440 DL Laser...
I just installed 4 new toner cartridges in my magicolor 2300 DL and I still can't print. It is still tellimg me to change the cartridges. Help!
You have to tell the printer that you have replaced the cartridges.
Here are step by step instructions:
http://www.laserquipt.com/support/idx/0/012/article/How-To-change-a-Konica-Minolta-2300W-cartridge.html
Also, check to make sure that you have removed all the tabs and plastic strips from the toner cartridge.
Aug 04, 2009 | Konica Minolta magicolor 2300DL Laser...
Not printing yellow (64% full)
Go to maintenance and purge ur cartridge.Cheeck regularly ur wiper maybe it will cause clog to ur cartridge.
May 20, 2009 | Konica Minolta MAGICOLOR 2300W LASER...
Konica Minolta 2300W ink smears
check the transfer belt..there is a reason why some used printers are sold on ebay!
be prepared for sticker shot.
Apr 08, 2009 | Konica Minolta magicolor 2300DL Laser...
Driver
Here is the link to download your driver.
Thanks
Mar 12, 2009 | Konica Minolta MAGICOLOR 2300W LASER...
Cant replace a toner cartridge
It's done via the printers internal menu system:
On your Menu Select button press the arrow down once, then press the right or left arrow until it displays Menu Engine, then press down arrow again, then arrow right or left until it displays Engine Replace Toner (not Engine change toner SZ), then arrow down again, then arrow right/left till it shows the toner color you need to change, then hit the Menu Select button in the middle. The cartridges rotate until the one you selected appears, open the door and voila!
Jun 05, 2008 | Konica Minolta magicolor 2300DL Laser...
Cartridge Removal 2300DL QMS Minolta
magicolor 2300 DL procedures
a)From the display, select the menu “Engine”.
b)Select “Replace Toner”.
c) Select each color toner cartridge from this
menu to remove it.
Nov 26, 2007 | Konica Minolta magicolor 2300DL Laser...
Help replaceing a toner
Here is what you do.... turn off the power, open the door to access the toner cartridges. You'll see the access port to pull the cartridge out. There will be a small picture to the top left showing to use your two fingers to pull it out. Between the pic and the opening there is a square hole with a round plastic tube in the center of it. Take a car or house key and stick it in the hole. When you do, you can now rotate the cartridges by sticking your finger in the individual cartridge holes. Rotate the cartridges until to can freely pull out the one that needs to be replaced. Put the new one in, close the door, turn on the printer... Ta-DA!!
Nov 07, 2007 | Konica Minolta MAGICOLOR 2300W LASER...
HP Printer Cartridges (Complete List): , HP C9703A magenta toner cartridge Logo
136 people viewed this question
Clive
Clive
