Question about Kenmore 55612 / 55614 / 5561 / 655619 Side by Side Refrigerator
Freezers in freezing temps
I just got a 4 cubic foot freezer, and we'd like to keep it in an out building, which isn't heated. Outside temps go down to vero around here sometimes. Will it hurt the freezer to keep it there? Will it operate properly?
  • 1 more comment
  • floyd234 Jan 27, 2009
    Thanks Billy. Your experience tells me that I can most likely keep my little freezer in freezing temps, which is a big improvement over what I knew before. I guess I'd feel better if someone told me that they repair freezers for a living, and haven't ever seen any that were damaged by the cold. Perhaps I worry too much...
  • floyd234 Feb 02, 2009
    Thankyou peyton. I got the unit used. No manual, no labels on it.
    Guess we'll make room in the kitchen!
  • floyd234 Feb 04, 2009
    Ok. Now I'm confused. Since nobody knows who anybody is here, I think it would be great if ya'all told us who you are, and from where you get the information you're posting. An appliance repairman? A refigeration engineer? Someone who owns a freezer? Tell us why we can trust what you say. Then, we can all truly benefit from this forum. Thanks in advance. floyd
    Problem Solver:
  • 10 Answers
Hi Floyd...your freezer will work ok in an out building, but a 'larder fridge', or fridge/freezer will not.
I've got three freezers in my garage working perfectly for years
Posted on Jan 26, 2009
  • william whittaker Feb 04, 2009
    I'm sorry Peyton, you are mistaken, any single freezer like Floyds will work better in lower temperatures.
    I'm a retired refrigeration engineer with over 30yrs experience in repairing domestic fridges and freezers.
  • 410 Answers
In an effort to help you avoid food loss I must disagree wiht the previous solution. your owners manual should tell you that using the unit in an area exposed to temps below 45f may and will cause long off cycles and improper operation.  thanks peyton
Posted on Jan 31, 2009
  • peyton thompson
    peyton thompson Feb 04, 2009
    I have 22 years expereince in strictly domestic refrigeration repair I am a direct manufaturer repair representative for frigidaire and whirlpool.
    I am not trying to get into a p****** match but wether the unit will operate in that cold of an ambeint area or not doesnt negate the fact that the manufacturer strictly states in the product manual that it must be operated in an area with temps above 45f. this prevents long off cycles and liquid slugging of the freezers compressor. ultimatley its up to the consumer which one to beleive but I'm just stating exactly what the owners manual says.
    Have a nice day and sorry for the confusion. peyton
Hi.. I have a defy upright freezer.. it is currently displaying an error "c2 !". Defy say this is because of the change in outside temp. Is this true, how long is it supposed to last? Many thanks.
If unit is not in a controlled environment yes temp will be confused and will take 24 hour to correct but if outside temp is changed it will do again and again all units designed for controlled temp room not outside in garage or out buildings with no heat or cooling controled room
Feb 28, 2017 | Freezers
Ice build up bottom of the freezer
You do not have enough air flow. make sure you do not block the vents inside the freezer and also around the outside of the freezer. It needs to extract the heat from inside to keep it cold. If you have no air flow, in and out, ice will build up.
Feb 19, 2016 | Samsung Refrigerators
Amana fridge model number Arb1914cw is not cooling. Freezer is working fine
Bottom freezer fridges are especially susceptible to
  1. Dust build up on the condenser coil that impedes heat transfer to the outside from inside the box
    • Remove the (bottom) footplate by grasping outside edges and pulling/levering out and popping it free.
    • Use vac crevice attachment and coil brush to clean away all dust from the coil and foot plate.
    • Replace plate and allow 24 hours for inside temp to stabilize.
    • Adjust top temp setting if needed to maintain safe temp level.
    • Repeat semianually or annually as scheduled maintenance--depending on the dustiness is fridge's location.
  2. Airflow blockage through the crispers and meat keepers.
    • Remove crispers and meat keeper as well as glass cover shelf.
    • Find cooling passages between crispers and at midline of meat keeper.
    • Remove any buildup of air blocking debris.
    • Wipe up fridge box floor beneath meat keeper.
    • Reinstall glass shelf, meat keeper, and crispers.
    • Check perodically for poor temperature/moisture keeping in crispers and for water pooling on fridge box floor as signs of blocked air flow through criispers and meat keepers.
Mar 16, 2015 | Amana Refrigerators
What is the comparison of heating 1500 cu. ft. to 1000 sq. ft.?
a cubic foot is a 12inch by 12inch square by 12inch depth its like stacking 1500 little sq. boxes in a room or two.a 12ft by12ft room with 8ft walls would hold 1152 cubic feet or little in comparison 1500cu ft is little more than one room,1000sqft is a small house.
Feb 03, 2015 | Leisure HOMEPRIDE Electric Fireplace...
Brought a 3 cubic foot freezer that will not run
call Danby or go back to where you brought will exchange
Sep 16, 2014 | Danby Freezers
Seeking normal temperture range for 10 cubic foot refrigerator
Refrigerator temperatures should be between 34 to 38 for good cooling. Freezer temps should be from 0-15 to keep ice cream fairly hard
Mar 25, 2014 | Jenn-Air JCD2290HES Side by Side...
My wife called me home to a thawing freezer.The outside stuff was thawed and the temp was 40 inside.The sides were hot on the freezer and it is a 20 cubic foot upright that is 12 years old. have not had...
Check the fan down by the compressor to see if it's working . If not , it needs to be replaced .Also check the coils to make sure they are clean of dust , lint , etc... Is the fan inside the freezer working ? The hot sides are good . This means the compressor is working ( the " freon " attracts the heat inside the freezer , pulling it out , to make the freezer cold . The air flow over the sides , help dissapate the heat ) . Without the model number , I cant look up to see how the freezer is made .
Aug 20, 2009 | GE 203 cu. ft. General Electric Upright...
My freezer also just jumped to 17° and won't go down to 0.
We need to check the evaporator fan and the condenser fan. The heat in the door frame is normal when the refrigerator runs normally. But when a control board or fan fails the heat may increase because they are heat strips behind the door or condenser lines placed there to prevent moisture around door seals. We also will need to unplug and have a look at the mother board on back behind a panel. Many times the board will show burn marks on the back or front. When you are ready let me know, Thanks, Sea Breeze
Jun 18, 2009 | GE Profile Arctica 25.4 Cubic Feet...
KitchenAid Side-by-side (ksrg25fkwh05) - Freezer not working
The odds are it is a circuit board problem...I had a huge Amana 27 cubic foot side by side and it did the same thing...I diagnosed the problem and replaced the circuit board ....which actually controls sure sign is to pull the unit out as the other person did and to access the back of the unit where the compressor is...(the comptressor should be on 85% of the tme....if it is not on and warm or hot to the touch then it is a circuit board problem....since compressors will continue to run if there is a defrost problem (most of them anyway), or an Ice build up, etc etc. I don't recommend a layperson trying to replace the circuit board (mine cost $115,) but if you do it is generally in the door mine was a long thin circuit board behind the fridge door handle. .P.S. the heat that the other person felt on the door and around the door seals is normal lots of people don't even know this heat strips exist until something haappens and they start feeling around...these heat strips are to prevent frost of ice build up where the door meets the fridge framd...which can happen due to the extreme temp difference between the two...(inside temp and outside temp).
I hope this has helped...good luck...Knowledge gives you a base from which to yield power over unscrupulous repairmen whop may try to take advantage of people.
Again ...good luck and let me know what happens.....Please rate me .....The Fang.
Mar 15, 2009 | KitchenAid Superba Architect KSCS25INSS...
Condensation on Outside of Freezer
hi thanks for the question .yes you will have to live with it warm & humid climate especially in the garage .A fan close by could help thanks the appliance doc
Sep 28, 2008 | Kenmore 5 cu. ft. / 142 liter Chest...
Kenmore 55612 / 55614 / 5561 / 655619 Side by Side Refrigerator Logo
88 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
Level 1 Expert
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
