Question about Intel Celeron D 331, 2.66 GHz (BX80547RE2667CN) Boxed Processor
Overclock on Celeron D331 2.66GHz 256K
Does any one have done over clock on this processor, and I am interested in the procedure for over clocking. Recently I was reading about over clock from forums, but steal I am not capable enough for doing that. I have a few question related to this topic. What do you prefer over clocking from BIOS or from the programs for doing over clock? Of normal working this CPU produce 50 Celsius degrees. Do I have to set first a better fen or a can do it with this one. How far I can go with a temperature and the part with adjusting the ram GHz with CPU GNz it’s not much clear to me. I am using 945GZT Motherboard and I have set 2x256MB DDR2 533MHz.
    New Friend:
  • 4 Answers
Intel celeron all driver
Posted on Dec 30, 2012
  • 259 Answers
I think there are too many problems with overclocking I would look at a programs to do this for you ONE is RED STORM and yes you do need to put extra fans in I had three Also I found the computer which has died does not last as long I would look at increasing your memory to at least 1Gb and you will notice a remarkable difference.
Posted on Jan 27, 2009
Over clock processor
The Dell Laptop overclock is done via the BIOS - accessed during boot.
Another method to overclock is by using software, (I don't have any to recommend due to not being familiar with which is better / worse / etc).
Sep 18, 2013 | Dell LATITUDE Computers & Internet
Can I turbo boost a Dell Inspiron 1525?
Some computers will work with overclocking. It is done in the BIOS causes quite a bit of heat in your processor and can destroy your processor.
Go into your BIOS and look for overclocking or clock velocity or speed. Keep in mind...if this can be are going to exponentially shorten your laptop life and if you extreme overclock it.... probably lock up or brick your machine.
Semper Fi,
Feb 01, 2018 | Dell Inspiron Computers & Internet
Is it possible to over clock amd phenom 8600b 2.30ghz triple core processor
Yes, every processor can be overclocked, but be very careful when overclocking processors. The increased heat can damage a processor and shorten it's life significantly. Ensure your processor does not get too hot during the oveclocking procedure. All overclocking should be done in small increments. The X3 8600 can be oveclocked to close to 2.7GHz safely with air cooling.
The best overclock is always through the motherboard. Depending on your BIOS you can raise the Front Side Bus (in small increments) in order to bump up the total frequency. If you have an unclocked processor, you can try to raise the multiplier. After every increase, you should stress test your computer using PRIME 95. If your computer locks up, drop down the clock speed and leave it there. Your computer should always be stable. You may have to raise the voltage of your processor to get to where you want. If you give the model of your motherboard, I can give you more detailed instructions.
Make sure you have CPU-Z ( - this will show you all the details of your processor. If you would like some more detail, check out this link: and feel free to message me. If you didn't understand some of the things in this post, I'd recommend not overclocking your PC - it can be dangerous and ruin your computer if you don't know what you are doing. Alex
Apr 09, 2011 | AMD HD860BWCJ3BGH Phenom X3 8600 OEM...
How to overclock my motherboard ?
there are 2 ways, overclocking using the bios to over clock the memory ( ram ) and also the processor ie changing the multipliers and other tweaks ( which should be in your motherboards manual ) that or using jumpers which are physically on the motherboard but later motherboards use the bios to tweak / over clock your computer.
Apr 13, 2009 | Computers & Internet
Hi there
The processor will become critical at around 49c - 54c, but that shouldn't matter.
If you are wanting to overclock it you should be looking at more cooling for the system, a bigger fan and heat sync for example.
also set a fail-safe in the bios for the system to shut down near critical temperature.
Good luck and thanks for using Fixya!!!
Feb 11, 2009 | Intel SL5PY - Mobile Celeron 900MHz...
How do I overclock a Celeron 733mHz PGA370?
You can only overclock your computer if it has ATAPI BIOS. So get into BIOS upon bootup and if you have ATAPI then it will say it across the top. It will also have a section for the CPU with the current speed and an option to change it.
Dec 22, 2008 | Intel Celeron, 600 MHz (SL46U) Processor
How do i overclock my machine?
there is alot more...and the risk/reward is what it is all about up and get a good monitoring program and go have fun ..........,1/CPU,1/
Nov 09, 2008 | Computers & Internet
CPU Over clocking
over clocking is when you cause your computer's CPU to work at a higher than it's normal capacity. It also causes your cpu to heat up beyond it's normal operating temp. It CAN cause the computer to run as though it has a larger cpu in it (this can also be done to a few other items as well), say a 1 GHz overclocked to a 4 ghz (which has been done). But you can also very well fry your CPU (or other components), in which case you have an expensive paperweight. It is NOT something to be tinkered with for those who are inexperienced, and I would not suggest it.
Jul 19, 2008 | Intel (RK80532PG0881M) Pentium 4, 3 GHz...
Overclock; Access clock multiplier settings?
Yes if the motherboard supports overclocking, but you should be very careful not to burn your processor.
Nov 03, 2007 | HP Media Center m7250n (ED842AA) PC...
Intel Celeron D 331, 2.66 GHz (BX80547RE2667CN) Boxed Processor Logo
832 people viewed this question
Top Intel Computers & Internet Experts
Alun Cox
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
