Rca r52wh74 shut off by it self
Unplug it for for a day works for about 45 min and shuts down again before i did it shut off about every 10min onetime it shut down and turned back on but my colors were all off
  • 3 more comments
  • coolduke68 Jan 27, 2009
    tv flikers
    no capacitors look ok
  • coolduke68 Jan 28, 2009
    is it something i can replace
    dont look or feel beveled
    how do you check to see if it the power supply
    Master:
  • 505 Answers
1. Check the power chord and the power source.
2. Disconnect all the cables and put the cables back.
As the TV is automatically shutting off, this means that you could be having problems with the deflection board, high screen current will cause the set to shut down very quickly.
You need to get the power supply replaced. Get in touch with some local tv repairman.
Thanks
Posted on Jan 28, 2009
  • Indrajit Roy
    Indrajit Roy Jan 28, 2009
    The power supply is inside the TV near the power supply board. However, you have already given Fixya to a different expert.
  • 86 Answers
 Remove the back panel from the television, you will see a board where the input jacks are located. To the left you will notice a red power wire. Just up and to the right approx 7" or so you will see a [_] shaped metal shield surrounding a capacitor in the middle of it. The part # on the board is CP150. It is a green/gold 16v 2200uF capacitor. More than likely this capacitor is faulty. Run your finger over the top of the capacitor, if it is beveled rather than smooth you have a definite solution to your problem. You may need to remove the plastic piece that covers the transformer to the left of the capacitor to gain easy access. Good luck!!
Posted on Jan 27, 2009
    Genius:
  • 1,847 Answers
This could help try replace 3 capacitors cp150 2200uf 16v If it is puffed up on top it is bad ,need to replace 2 more caps cp120 cp114 220uf 35v they are green with gold writing on them.
  • 10,594 Answers
Do you see any problem in picture when TV goes to shut off?
I need to know what kind of picture distortion comes when TV turned off.
Thanks.
  • Shahid Electronics
    Shahid Electronics Jan 27, 2009
    OK, TV Picture Flickers.
    Problem can be few weak capacitors in power supply and horizontal deflection section of TV.
    If you are familiar with TV repair and have knowledge of basic electronics then give a try to check any leaky or top bulged capacitors in TV boards and replace them with same rating capacitors.
    Top Expert:
  • Televison & ... Master
  • 63,661 Answers
This problem is caused by a shorted power supply, the heat of operation causes it to short, then when it cools the short goes away, when all is said and done u will spend around $600 to get it fixed and still have an old TV, the new LCD's are not much more money, save yourself the hassle and replace the set.
Is there a reset button on rca p52939
No there is no reset button . you would unplug the set for 5 min's and this will allow a reset . . with the symptoms you give id say you have a shut down issue . the set has detected a error and is putting it into a shut down sequence to protect it self from major damage .
Oct 15, 2014 | RCA P52939 52" Rear Projection Television
RCA R52WH74 that will shut itself off
Replace 3 capacitors on Deflection board its the bottom left hand side cp150 200uf 16v use 25v capacitor and cp114 cp120 in same circuit 220uf 35v. You will see cap cp150 if it is puffed up on top they are Bad. Call Mats Electronis 1-800-628-1118 Radio shack might have capacitors.
Dec 29, 2009 | RCA R52WH73 Projection Television
TV shut off after 10 min.
it souds like the cooling fans arent working correctly. if the tv is staying on long enough to warm up and then shutting down i would look at the cooling fans
Jan 29, 2009 | Mitsubishi WD-52525 52" Rear Projection...
HDTV R52WH74 PROJECTION POWER STAYING ON ISSUE
thats usually related to the flyback and or cp150 capacitor. You can get the replacement flyback number 259296 and the replacement CP150 at the following link with free instructions
http://servicemanuals.vstore.ca/
Sep 11, 2008 | RCA R52WH73 Projection Television
Please someone help me with my tv
ok i see alot of these at the shop( i have one in front of me right now) The rca itc22 chasis is bad about this.. If the processor finds any problems it will shut it down. THe big problem it can be one of about 20 different things. As the customer the first thing you can do is unplug the set and leave it of 30 min to an hour. then try it again. ( I have yet to see this work) There are some basic assumptions that you can make.. if you see the light flash then it wont be a fuse. the processor is getting power. This is where a technicain starts his troubleshooting. You said it would shut itself down every once in awile... could be a bad connection or a component that finally overheated then failed. The processor on this set records errors so a technician can read these with special computer interface equipment. repairs on the set generally run 150 to 500. These sets are about 800 new at walmart so you have to make the decision to repair
Mar 04, 2008 | Televison & Video
RCA Projection TV
ok lets begin... shut off? ...is the set staying off. NO POwer at all.. does the set try to come on. does the set have a blinking led on front. have you tried unpluging then waiting 30 min then trying to turn it on again.. this set has a processor and when it detectect any fault will shut the set down
Mar 03, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
Hitachi 51F500 Shuts down during summer months
I am finding out that these sets have almost the same problems mostly going back to middle power supply broad ck all connections,then try looking for leaky caps.
Nov 08, 2007 | Hitachi 51F500 51" Rear Projection...
Televison & Video Logo
49 people viewed this question
Top Televison & Video Experts
Electro Med Services...
