Question about InFocus TD30 30 in. HDTV-Ready LCD Television
Get the infocus td 30 remote control codes
I want to use my dish network remote control to power on/off and change volume, rather than use 2 remotes. I need the infocus remote contol code so that I can program my dish remote control.
  • 26 Answers
SOURCE: Unable to switch off projector with remote (Infocus SP4805)
A bit unusual for the projector to stop responding to the remote. Usually it follows when someone has opened the projector, they forgot to reconnect the controls from the case top which also includes the IR receiver. If it isn't that, it could be a broken IR pc board or bad connection. I've seen that.
The worst case is that the IR controller on the main board has failed and if that's the case, you'll have to live with it as the cost of a new board is very high.
Posted on Mar 13, 2008
SOURCE: controlling my Sylvania LC320SS8 with my Dish Network remote
I have a similar problem with the Comcast Box.
It wont turn it on or shut it off.
Posted on Jun 18, 2008
  • 2920 Answers
SOURCE: nFocus ScreenPlay 61md10 61 does not recognize remote
on the universale remotes it tells you on the back of the package what tvs it will and wont work with.
Posted on Nov 03, 2008
SOURCE: InFocus ScreenPlay Projection HDTV does not turn on
I have the same problem, has anyone fixed this issue yet? I have no way to access any menus because the screen doesnt turn on, I also cant hear the fan turn on
thanks
Posted on Nov 02, 2009
  • 23 Answers
SOURCE: my dell d630 laptop wont recognize my infocus
Here's what the User's Manual says:
Using the Remote Control
To advance PowerPoint slides with the projector's remote, you
must connect the USB cable on the projector's computer cable to
the computer. See page 8 for more information.
Point the remote control at the projection screen or at the front or
rear of the projector (not at the computer). The range for optimum
operation is about 30 feet. If you point the remote at the
projection screen, the distance to the screen and back to the projector
must be less than or equal to 30 feet. For best results, point
the remote directly at the projector.
If you are displaying presentations in Microsoft® PowerPoint®,
you can use the remote's Previous and Next buttons to navigate
through your presentation while in Slide Show mode.
Posted on Jan 26, 2011
Sanyo TV Code for Dish remote 21.0 IR/UHF PRO only operates TV Power and Volume Functions.
Hello Witt Thomas,
I can understand the concern and wanting the remote to work the TV Menus. It is possible with our remotes, however it depends on the TV itself. I've seen instances where there are 2 TV's in one house, and 1 will do it, while the other won't.
If you have tried all of the remote codes, and none work, the only other options we have available are to try a powr scan, or teach the remote. This link http://www.mydish.com/support/teach-learning-remote-20-21 can provide the steps on how to teach that model of remote control!
Let me know if you have any other questions.
Tommy Faust
DISH Social Media Representative
Jan 16, 2013 | DISH Network ES161256 21.0 IR / UHF Pro...
I have an AVol TV and need the Dish Network remote control codes
Hi, my name is Cheri Torres and I am with DISH Network Customer Service. I tried looking up all of our possible remote codes and I was not able to locate any codes for an AVol TV. Instead of using codes to address your DISH remote to your TV you will need to try a power scan. A power scan will normally find the code that works best for your TV for you. I will list here for you the instructions for performing a power scan. I hope you find this information useful. :)
Instructions for performing a power scan
  1. Turn the Television On.
  2. Press and hold the TV mode button until all mode lights light up red.
  3. Press and release the big red power button once.
  4. Press and release the channel Up Arrow on the remote until the television turns off.
  5. After the television turns off, press and release the pound(#) button once.
  6. Test functionality with the TV.
  7. Return to Step 2 if the remote is not able to turn the TV On/Off, change the volume and mute the television.
Sep 09, 2011 | DISH Network IR Remote Control
NEED A CODE TO PROGRAM DISH NETWORK 5.4IR REMOTE TO OPERATE PHILIPS HTS3565D
Hello! My name is Becki, with DISH Network. Programming the remote to the TV is a pretty easy process. I have given some codes that should work to program the remote. If not, please let me know!
1. Hold down the clear TV button until all lights light up at the top of the remote
2. Punch in a 3 digit code (provided below)
3. Press the # (POUND) button
4. Try powering the tv on/off, and the volume. If one or more of these functions do not work, start over from step 1 with a different code
566
828
824
Becki Barned
becki.barned@dishnetwork.com
Jul 13, 2011 | DISH Network IR Remote Control
I have a Sony Bravia TV, only a year old, had several power outages and suddenly RM-YD028 TV remote is not working at all. On the Dish network remote, the satellite controls are working, but not TV...
If neither the DISH Network remote or the TV remote is working for you most likely your remote sensor is going bad. If you'd like to try readdressing the remote follow the steps and procedures below. Codes: 500, 837, 125, 808, 798, 640, 796, 783, 795, 797, 865, 846, 842, 563, 501, 810, 841, 781, 807, 838, 690, 758, 843, 845, 591, 839, 806, 840, 844
To program the remote:
1.) Hold the clear "TV" mode button for four seconds or until all four buttons at the top of the remote are lit.
2.) Press one of the three digit codes listed above followed by pound (#)
3.) Check for functionality by trying the volume power and mute.
Be sure to press the "SAT" button to return to satellite mode if the code works.
Daniel Busa
DISH Network
Customer Service
May 31, 2011 | Sony RMYD028 Remote Control
I need a remote control code for tp 3730
tony_ballard
I could not find a code for that TV brand but I have provided instructions on performing a power scan to possibly find a code with your DISH remote that will work for your TV. I hope this helps.
Remote: Basic Remote (Television Only)
  2. Press and hold the TV Power button for three seconds until the LED flashes.
  3. Press and release the TV Power button.
  4. Press and release the Up or Down Arrow on the remote until the television turns off.
  5. After the television turns off, press and release the OK button.
Ray Calo
DISH Network
Mar 21, 2011 | DISH Network IR Remote Control
I have dish network setup, and vizio 42" HDTV. The Dish network remote is already able to control the TV power and sound options, however, I want to control the TV Setup options too (specifically the...
Hello, my name is Becki Barned, with Dish Network customer service. To get your tv to work those particular functions, you will need to reprogram the remote to the tv, finding a code that works all functions of the tv. Some codes will work the power and volume, but not the other functions. Try these steps:
1. Hold down the TV mode button until all lights at the top of the remote are lit up
2. Press the 3 digit code in
3. Press the pound button
4. Press the SAT button on the top left of the remote.
Here are the codes to try:
505
671
627
864
006
Hope this helps!
Jan 01, 2011 | DISH Network IR Remote Control
My dish network remote will turn the bose unit on and off, forward dvd and ect. It will not turn up the volume.
It may be that you are not using the correct code for yourparticular Bose component. I would recommend trying all of these codes: 761,664, 656, and 639. If you are still not able to use your DISH remote to controlthe volume of your Bose component, try doing a power scan. Press and hold theAUX button on the top of your DISH remote until all the mode buttons on the toplight up, then release. Press 2 then * on the number pad, press the powerbutton at the top of the remote, then keep pressing the up button on theremote. Continue doing this until your Bose unit turns off, once it has, stoppressing the up button and press the pound (#) button. Check that the code works by trying several differentfunctions on the remote to make sure it properly operates your Bose component.Keep in mind that some codes may not be compatible with your equipment.
Thank you for being a valued DISH Network Customer!
Phillip Chang
DISH Network Customer Support Representative
Nov 21, 2010 | Bose 35503 Remote Control
Having trouble getting my Dish Universal remote to connect to my Insignia 19" flats screen television. I think it is the silver (ES3189) model remote
traceroberso,
I came across your post. Are you still having problems with your DISH Network remote operating your Insignia TV? If you still are, I have 2 codes you can try to see if it will work on your TV. The codes are: 720, 539. The steps to program the remote to the TV are below.
Remotes: Basic (Television Only)
  2. Press and Hold the TV Power button for three seconds until the LED flashes
  3. Enter the three-digit code using the buttons on the number pad.
  4. Press OK. Note: The LED will flash three times.
  5. Test functionality with the TV
  6. Return to Step 2 if the remote is not able to turn the TV On/Off, change the volume and mute the television.
Ray Calo
DISH Network - Executive Offices
Nov 11, 2010 | DISH Network EZ Remote Remote Control
The Volume function on my remote doesnt work, you ...
Hello, my name is Michael Hurst with DISH Network. Sounds like the remote isn't programmed to your TV. You could use a remote code for your TV. To give you the correct remote code we would need to know the manufacture of your TV and the model of remote you have. You can also try a Power Scan and cycle through different codes that are available. Here are the steps for a Power Scan: Withthe desired equipment on, press and hold the correct Mode button until all modebutton backlights illuminate, then release. Press and release the Power button. AUX Mode: Before pressingand releasing the Power button. Press 0 for a TV, Press 1 for a VCR/DVD andPress 2 for any other device. Then Press STAR (*). Press the Up button once asecond while pointing the remote at the desired equipment. If the code for theequipment comes up, the equipment will power off. Press the POUND (#) button. Ifthe code entered is valid for the remote, the mode light flashes three times.
May 19, 2010 | DISH Network IR Remote Control
Cannot find code for dish network remote to control emerson 32 in
Phillip with DISH Network here. We would be happy to help with that.
Step 1:
Press and hold the TV Mode button until all mode button back lights come on, then release.
Step 2:
Use the number buttons to enter the device code corresponding to the equipment. In your case we are going to use the Emerson codes: 764, 632, 648, 670, 699, 194, 537, 537. Then press the pound (#) button.
You should be able to control the volume and turn the TV on and off, if not try another code. Although we try to facilitate you in controlling both devices with one remote we cannot guarantee that we have codes for all the different brands and models of TV's.
Phillip Chang
DISH Network Customer Service Representative
Dec 12, 2009 | DISH Network IR Remote Control
InFocus TD30 30 in. HDTV-Ready LCD Television Logo
71 people viewed this question
Top InFocus Televison & Video Experts
Donni Steen
rostit
Are you an InFocus Televison and Video Expert? Answer questions, earn points and help others
