Question about Frigidaire FGQ1442ES Gas Dryer
Conversion kit for Frigidaire dryer to propane
Where do I find a conversion kit for Frigidaire dryer from Nat. gas to propane. The model is FLSG72GCS9
Thanks
  • steve
    steve May 11, 2010
    Any appliance parts store will have it
  • Thomas Malailua
    Thomas Malailua May 11, 2010
    you can get one at any on line appliance parts store.or local part store.even sears.as a repairman i only cared whirlpool brand conversion kit and would use it on all brands
    Scholar:
  • 44 Answers
Instuctions on how to change a pitco fryer from nat gas to propane
Hi there!
You need to order a gas valve conversion kit (from nat to propane), propane pilot orifice and propane burner orifice,
Gas valve conversion kit consists of a replacement spring thicker than of natural gas valve spring, gas valve cap and a sticker.
Pilot orifice for propane has smaller bore than of natural.
Burner orifice for propane has also smaller bore than of natural burner orifice (one for each burner).
You will be able to find these parts on the list of Pitco Distributor when you visit http://www.pitco.com
Regards.
Jul 08, 2012 | Pitco Frialator E24 Deep Fryer
Is it safe to convert my propane gas dryer to natural gas? How much will it cost?
Al you need to get is a natural gas conversion kit for your dryer. Use your model number and look up a list of spares for your machine. Go down the list till you get to the conversion kits and get the one from LP to Nat of course, something like this one.
May 02, 2011 | Dryers
Maytag Dryer conversion From LP Gas to Natural Gas
Get a nat gas conversion kit using your model number. Now this link shows how to convert nat to LP you would do the opposite.
Basic Dryer conversion 101
Aug 21, 2010 | Maytag MDG2706A Gas Dryer
Can you covert convection ovens from propane
Determine the make and model of your dryer. You want to make sure you get the correct conversion kit for your dryer. Get one that is specifically for your dryer, not a universal kit.
Buy a conversion kit for your dryer. You will probably find one at a local hardware storemag-glass_10x10.gif .You can also find them online. It is probably advantageous to buy it locally because the dealer has experience installing these and can be a great asset. The kit will probably come in an envelope and will be marked something to the effect of “Conversion Kit Nat. Gas to L.P. Gas for XXXX series dryers”.
1)Shut off the gas supply to the dryer and make sure the power cord is unplugged.
2)Access the gas controls assembly in the dryer. This will be different for different brands of dryers. The instructions with the conversion kit should tell you exactly how to do this for your dryer.
3)Turn on the gas supply and check for leaks using a liquid soap solution and / or a leak tester.
4)Activate the dryer gas valve. Check to make sure the manifold pressure is correct and if not, adjust the regulator setting. Again, check for leaks.
5)Adjust the main burner flame as directed in the instructions with your gas conversion kit.
Aug 28, 2009 | Blodgett Ovens
Converting back to nat gas from propane
Typically, conversion from natural to propane and visa-versa is just a simple connection behind the appliance. Look in the box of the conversion kit (or on the back of the packaging,) and you should see the conversion instructions. Since you are dealing with gas, you need to make sure the shut-off valve is... shut off so no gas can leak while do the exchange. Also, make sure there are not open flames anywhere near the work area. Take your time and follow the directions...
May 25, 2009 | GE Profile Harmony DPGT750GC Gas Dryer
Need instructions for Natural Gas to LP Gas for GE Dryer
You can get the conversion kit. It will tell you how to convert the dryer. I recommend that you get a technician to do it though.
This gas dryer is equipped with a Valve & Burner Assembly
for use only with natural gas. Using conversion kit
WE25X0217, your local service organization can convert
this dryer for use with propane (LP) gas. ALL CONVERSIONS
MUST BE MADE BY PROPERLY TRAINED
AND QUALIFIED PERSONNEL AND IN ACCORDANCE
WITH LOCAL CODES AND ORDINANCE
REQUIREMENTS.
Good Luck and Please Rate FixYa!
Jan 19, 2009 | Dryers
Older Frigidare Elite Dryer conversion
You'll have to contact Frigidaire to see if a conversion kit is available. Normally, it's just an orifice replaced on the gas valve.
Feb 18, 2008 | Frigidaire GLGR341AS Gas Dryer
Frigidaire FGQ1442ES Gas Dryer Logo
761 people viewed this question
Top Frigidaire Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Frigidaire Dryer Expert? Answer questions, earn points and help others
