Question about Disney Interactive Disney's Toy Story 2 Action Game for Windows, Mac
"Cannot enumerate suitable device" - Disney Interactive Disney's Toy Story 2 Action Game for Windows, Mac
USB devices failed enumeration
If they are required, toshiba will have them on their web site.
Apr 17, 2014 | Toshiba Computers & Internet
Unknown device driver
go device manager. right click that driver. select properties. go to details. give the driver enumerator details
Nov 04, 2013 | Dell Inspiron One 2020 All-in-One Desktop
PC stops booting after USB devices are enumerated
Firstly when you restart your computer, does it dispay an error message reading, THE SYSTEM HAS RECOVERED FROM SERIOUS ERROR.
Apr 05, 2013 | EliteGroup GeForce6100PM-M2 (V3.0)...
Plag and Play Software Device Enumerator Search
Sounds more like plug and pray, what device is this? Perhaps the driver needs to be installed before it gets plugged in.
Feb 25, 2011 | Computers & Internet
My video stopped working on my Logitech QuickCam Pro 9000. No picture or video. I just used it last on Tuesday and now nothing. I even reinstalled the software..still nothing. Help!
Check if the device enumerated
click on Start
Computer > right click > manage > Device Manager, click on it
You should see in "Imaging devices" a "USB Video Device".
If not then device did not enumerate.
If you see a yellow circle in "oher devices" try to updated the driver by clicking on it.
Mar 22, 2010 | Logitech QuickCam Pro 9000 Web Cam
Messenger & logitech ultravision webcam connection issues
  1. uninstall all logitech software
  2. unplug the cam
  3. reboot the pc
  4. plug in the camera without the software
    will enumerate under microsoft drivers.
  5. open the software and see if the cam is populated now.
  6. if not check the device manager see if the camera is enumerated correctly
  7. uninstall from the device manager and reboot the pc
  8. the try the software again
  9. if no cam options
  10. turn off antivirus reinstall the messenger and try cam again without software.
  11. still not working contact messenger support.
Jul 25, 2009 | Computers & Internet
Bluetooth doesnt work
you need to put whatever device you are trying to join to it in discovery mode and then scan for it from your pc.
Jun 02, 2009 | Acer 4220-2346 Notebook
No audio device ....on my xp C-media ac97 audio device. This device can not start( code 10) What I need to do get back my sound.
It usually means that you don't have exact driver installed. But sometimes it's a problem with a Plug&Play Enumerator. I solved this problem several times. First try to install exact driver for your device from cd or website of your motherboard. If after installation of a new driver you have the same issue you may try this:
1. Chek if PnP SW Enumerator is installed on your machine (Device Manager / System devices) - should be listed there!
2. If it is not there then we will probably solve it!
3. Locate "machine.inf" on your OS, copy it somewhere and modify it (find "ExcludeFromSelect=*" and remove the line or simply exclude it from processing by adding a ";" at the beginning)
4. Check the "machine.inf" file for location where SWENUM should be located (mine was reading: SWENUM.CoInstallers.CopyFiles = 11 ; %windir%\System32)
5. Find "swenum.sys" file on your XP installation CD (mine was in DRIVER.CAB) and copy it to the proper location (I am not sure if it is necessary but worked for me)
6. Go to Control Panel /Ad HW and follow the wizard towards manual selection of device to be added
7. Select Add System device
8. Select Have disk
9. Navigate to changed machine.inf
10. from the list select standard devices (in the left list) and "Plug and Play Software Enumerator" in the right list
11. Finish the installation
If it stil does not work reinstall the audio adapters' drivers. It should work now.
And also if you have any Linux liveCd you can boot from it . Linux loads it's sound drivers and after when you boot Windows it usually solves your sound problem ( I resolved this with Mandriva One Live CD).
Mar 21, 2009 | Computers & Internet
Bluetooth
I'm almost certain you don't have a bluetooth installed in the computer only the Microsoft bluetooth enumerator. When you go to bluetooth devices you'll likely only see a bluetooth enumerator. You need to get a bluetooth dongle that will plug in your USB port and the enumerator will run it.
I have the Acer 5735 and it has the bluetooth button also, some computers come with the bluetooth device installed and others like mine have the enumerator only.
best of luck,
DC
Feb 09, 2009 | Acer Aspire 5735 Notebook
Ethernet Drivers (slow internet access)?
the fastest speed is the slowest path on the network.
right click on the my network place.
right click on the NIC local connection
click on configuration at the right of the connect using (NIC)
second tab, "advanced" check the speed & duplex- it should be auto, but you can change it. do not recommend it.
check resources- make sure it has no conflect with any other device.
if that doesn't help. uninstall the NIC driver and try to find a older driver. Sometime that works better, don't ask me, but it works.
Oct 30, 2008 | Gigabyte GA-M59SLI-S5 Motherboard
Disney Interactive Disney's Toy Story 2 Action Game for Windows, Mac Logo
126 people viewed this question
Top Disney Interactive Video Game Consoles & Games Experts
Michael Galve
Michael Galve
Josh Whitehead
Josh Whitehead
Joseph Hoffmann
Are you a Disney Interactive Video Game Console and Game Expert? Answer questions, earn points and help others
