Question about Plumbing
I need a wiring diagram for a 91 dodge b250 3.9 v6.
I need wiring diagram for a 91 dodge b250 van 3.9 v6. Unable to trace out problem do to incomplete information.
    Novelist:
  • 170 Answers
I still haven't got it. I don't have problems with any pumps.
Posted on Jan 27, 2009
1995 safari fuel pump will not work unless directy wired to battery.
you have an incomplete circuit on your wires connecting items mentioned, test light trace it, poor contact on connectors.
Feb 19, 2012 | 1995 GMC Safari
Firing order diagram for 96 dodge ramp 1500 van v6 3.8 engine
Note this information, about Dodge RAM 1500 have 3.9 engine... 1996 Dodge 1500 Pickup 3.9 liter V-6 VIN "X"
This is for one 3.8L V6 1996 Dodge 3.8 liter V-6 VIN "L"
Hope helps (remember rated this).
Jul 04, 2010 | 1996 Dodge Ram 1500 Club Cab
Where to find wiring diagram for 1991 Dodge Ram Van, free would be nice. I have a Haynes manual but its wiring schematics are incomplete, no tail/stop lights. I want to trace the door lock circuit and also...
Go to faxon auto literature.com. They carry original dealer service manuals and have the one you need. It will have complete wiring diagrams for your van. I have used them before and had excellent service. Hope this helps.
Jun 14, 2010 | 1991 Dodge Ram
Did dodge make a 429 ci engine? i ask because the sticker on the valve cover on my 1`990 ram van says 429. thank you
hmmm... Have never heard of Dodge having a 429.. Ford made a 429, Dodge has the 440 and the 426 hemi.... unless they changed the bore and stroke for some models... which I think unlikely...
hold on... rereading your post... the only motors ever available in the caravan:
  • 1984–1987 2.2 L K I4, 84 hp (63 kW)
  • 1984–1987 2.6 L Mitsubishi G54B I4, 114 hp (85 kW)
  • 1987½–1990 2.5 L K I4, 100 hp (75 kW)
  • 1987½–1989 3.0 L Mitsubishi 6G72 V6, 136 hp (101 kW)
  • 1989–1990 2.5 L Turbo I4150 horsepower (110 kW)
  • 1990 3.0 L Mitsubishi 6G72 V6, 141 hp (105 kW)
  • 1990 3.3 L EGA V6, 150 hp (110 kW)
  • if it happens to be a '91 they added the 3.8l
  • 1991–1995 2.5 L K I4, 100 hp (70 kW) and 135 lb·ft (183 N·m)
  • 1991–1995 3.0 L Mitsubishi 6G72 V6, 150 hp (112 kW) and 173 lb·ft (235 N·m)
  • 1991–1995 3.3 L EGA V6, 162 hp (121 kW) and 194 lb·ft (263 N·m).
  • 1994–1995 3.8 L EGH V6, 162 hp (121 kW) and 213 lb·ft (289 N·m).
  • Peace,
    Mar 06, 2010 | 1990 Dodge Grand Caravan
    Have 1996 dodge ram 2500 van. Installed 1983 360. Have done this same swap in a 1992 dodge250 van....no problem with wiring the old ignition system and charging systwem over 1992 harness. this time the bat...
    Here is the wiring diagram you asked for.
    Charging System
    If there are more that you need simply reply back and I can find it for you. Seems like a rather simple system so I am sure this will help.
    Jan 25, 2010 | 1996 Dodge Ram 2500 Club Cab
    Serpentine belt diagram for a 3,3l dodge dynasty with ac
    For the 1991 DODGE DYNASTY - V6 3.3L 201ci GAS FI N R , review this informacion:
    Belt Routing Diagram
    - Multiple Accessory, w/o A.C. (Mfg. After 2/27/91)
    - Multiple Accessory, w/A.C. (Mfg. After 2/27/91)
    - Multiple Accessory, w/o A.C. (Mfg. Before 2/27/91)
    - Multiple Accessory, w/A.C. (Mfg. Before 2/27/91)
    Remove the serpentine belt by using a breakover bar, rachet or serpentine belt removal tool with the correct size socket for the pulley mounting bolt. Rotate tensioner arm to release tension. Remove the belt.
    Hope helped with this (remember rated this help) Good luck.
    Nov 12, 2009 | 1991 Dodge Dynasty
    1987 dodge caravan headlight fuse location
    Headlamps are not fused directly.Wiring will have to be traced.I would first inspect the headlamp switch for signs of overheating.
    Jul 09, 2009 | Pro-Fit Pro.Fit Dg 91 01 Dodge/Plym/Chry...
    The oddometer works but the speedometer doesn't in my 1992 Dodge Ram pickup. The gear that sits inside the transmission is not stripped and engages fine. Can the problem be somewhere other than the...
    Could be a bad cluster. If one is cable driven, and the other electric. You could have a bad speed sensor in the transmission which will make the speedo not work.
    Jun 09, 2009 | 1992 Dodge Ram 250
    Need wireing diagram for 2002 dodge grand caravan
    ------>>>FRONT>>>>of Van >>>>
    ______________________________
    #5 cyl #6 cyl
    #3 cyl #4 cyl
    #1 cyl #2 cyl
    _________________
    I COIL BLOCK I
    I I
    I #3 #1 #5 I
    I I
    I I Firing Order Is
    I I 1 2 3 4 5 6
    I #6 #4 #2 I
    I _______________I_
    the Wires Go Accordingly to prospective Terminals, So Sorry Unable to Send Pics through FixYa, A Formating Problem Exists
    and they show on my end but not on your end this is TRUE and CORRECT To The BOOK other than the Lines from Coil to Spark Plug ENDS at CYLINDERS. Please dont Forget to RATE Me
    Thank You And Happy Motoring!!
    Mar 27, 2009 | 2002 Dodge Grand Caravan
    Need fuse box diagram for 91 dodge ram 150 van
    i have the diagram for dodge ram van 250. don't know if it's the same, but i have it. find me at jhiggz11@yahoo.com
    Mar 09, 2009 | 1991 Dodge Ram 150
    Plumbing Logo
    332 people viewed this question
    Top Plumbing Experts
    Tom Chichester
    Paul Carew
    Are you a Plumbing Expert? Answer questions, earn points and help others
