Question about KitchenAid KSF26C4Xyy Side by Side Refrigerator
Refrigeration cooling off
Message on panel
Code freezer demo
French Door: Why Does The Control Panel Display "OF OF" Instead Of The Temperature? If the control panel displays "OF OF" instead of the temperature, the refrigerator is in "Cooling Off" mode. In Cooling Off mode, the refrigerator appears to be running normally, but the compressor is off so the unit does not cool. Cooling Off mode is used by retailers to save energy when the refrigerator is on the showroom floor.
Note: Cooling Off mode is also called Demo mode or Exhibition mode.
Disable Cooling Off mode by performing the following:
  • Left Door: Simultaneously press and hold the top two buttons on the left side of the display panel until you hear a distinctively different chime sound when the display changes. This will either be a combination of "Energy Saver" and "Freezer", or "Energy Saver" and "Power Freeze/Freezer."
Source:
Why Does The Control Panel Display OF OF Instead Of The Temperature...
Oct 17, 2014 | Samsung RF4267HARS Stainless Steel French...
Fan and compressor running but fridge not cooling
Your defrozed cycle seems to be not working. Means there can be problem with heater , timer or defrzed board or defrozed thermostat. You have to open panel from coil to diagnosed this.
Mar 03, 2014 | GE GSH25JFR Side by Side Refrigerator
Black strip on front of refrigerator is red hot
Hello, If you remove the rear panel on the back of the machine it will give you access to the compressor as well as the compressor fan motor as well. The black strip in the front of your refrigerator is getting hot due to the compressor fan motor not working. First thing that you should do is unplug the refrigerator until the compressor cools. After the compressor cools then you can diagnose the fan not working. Note in some instances where a family did not have another place to store there food items until the compressor fan motor was replaced I have left the back panel off and used a box fan to blow air onto the compressor continuosly. This does help to cool the compressor and keeps the tempretures near to where they should be. If you do notice that black strip heating up again afterwards you would have no choice other than unplugging the machine. If you have any further questions message me back and please also remember when our chat has fully concluded to rank how this opinion has helped in your appliance situation it allows me to continue helping others in similar situations in the future. Thanks Rick
Sep 02, 2011 | Refrigerators
Fridgidaire refrigerator keeps beeping with an error message of "HI" for the fresh foods.
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
Aug 27, 2011 | Refrigerators
Freezer is working fine. but the refrigerator is not cooling. i opened the back panel of the freezer compartment. lot of ice is formed.
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
May 01, 2011 | Refrigerators
Danby ref Model no. DFF 1170brwy do seem freezer is ok but ref side is not cooling. thanks
most likely you have a defrost issue click this link to see why http://applianceoutletservice.com/appliance-care-tips/refrigerator-tips/refrigerator-defrost-system-information.htm you need to remove the rear panel inside the freezer to assure that you do not have an ice build up and also that the fan located above the condensor is working properly as well if you have any further questions message me back Thanks Rick
Mar 14, 2011 | Danby DFF1144W Top Freezer Refrigerator
Little cooling in refrigerater freezer is cold noticed ice build up on outer panel of freezer
Check out these tips...they can help you figure out what is going wrong with your refrigerator and why it is not cooling
heatman101
Feb 03, 2011 | Refrigerators
Freezer stays cold, refrigerator does not. icing under back panel in freezer
heatman101
Nov 01, 2010 | Hotpoint HSS25GFP Side by Side...
Why is the back panel freezing over.....thick ice crystals
heatman101
Oct 19, 2010 | GE GSH22JFT Side by Side Refrigerator
KitchenAid KSF26C4Xyy Side by Side Refrigerator Logo
88 people viewed this question
Top KitchenAid Refrigerators Experts
John Tripp
John Tripp
mike cooper
Todd Arndt
Todd Arndt
Are you a KitchenAid Refrigerator Expert? Answer questions, earn points and help others
