Question about Curtis International Curtis LEDVD1975A 19" Black 60Hz 720p LED TV/DVD Combo
Curtis ledvd1975a wont turn on
TV WILL NOT TURN ON UNLESS PLUGGED AND UNPLUGGED SEVERAL TIMES
Need help getting Insignia tv to turn on
Your TV has a failed circuit board, which one will require diagnostic testing. Unless you are skilled in TV repair yes I suggest you replace the TV.
Feb 09, 2017 | Insignia Televison & Video
Why wont my Tv turn back on after the electricity went off?
Did you have your television plugged into an outlet with a surge protector? Does it do anything when trying to turn it on? Might have fried it when power came back on or when elec. went off.
Feb 05, 2015 | Emerson Televison & Video
Curtis tv wont do anything but red light is on
The main board to your TV need attention, and repair. Contact any experienced service technician.
Aug 20, 2012 | Televison & Video
My Curtis ledvd1975a-2 flashes the light on it's
Your power supply board is dead, u know basic electronics' and soldering? Most of the times, the power supply board just have dead leakages gases capacitors.These capacitors always bulges up on it top,or puff up on it top.Replaced these gases leakages capacitors will get your TV power stable,and work again.Or tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish power supply board for the replacement.
I hope this will help to solve the problem.....
Sep 15, 2011 | Televison & Video
I purchased a Panasonic TC-P50s30 50" Plasma TV
You did a good thing; really!! Keep that TV aside you always.
Jul 11, 2017 | Panasonic 50 in. Plasma TV
We have a Curtis 19"
Curtis Mathes 0047, 0054, 0154, 0451, 0093, 0060,
0030, 0145, 0056, 0016, 0166, 0466,
0702
1. Turn on the TV .
NOTE: Please read steps 2 to 6 completely before proceeding.
Highlight or write down the codes and device you wish to
program before moving on to step 2.
2. On the remote control, press a device key once
(i.e., AUX or TV).
3. Press and holdSetup until the
selected mode key blinks twice,
then release
Setup.
4. Input each of the codes until you think you got it.
Manufacturer's Codes
5. Enter the first four-digit code for
your device. If you perform this
procedure correctly, the selected
mode key will blink twice.
NOTE: If you enter an invalid code, the
selected mode key will display one long
blink and exit the programming mode.
Repeat steps 2 to 5 with a valid code.
6. Aim the remote control at your
device and press
Power once.The
device should turn off. If it does
not respond, repeat steps 2 to 6,
trying each code listed for your
brand until you find one that
works. If it still does not work, try
Searching For Your Code
NOTE: If the device does not have a
Power
key, press the (Play) key.
7. For future reference,write your
device code in the appropriate
boxes below:
AUX Code:
Device Type:______________
TV Code:
8. Repeat steps 1 to 7 for another
device you want to control.
Patiently try all of these until it comes on and off.
Aug 29, 2011 | Televison & Video
Tv turns off doesn't come back on
it could be a power board problem but there are several causes for its shutdown. unless you have a background on electronic troubleshooting, you could try to fix it and find defective electronic component then replace them. if not you could just have it repaired by a reliable service area or person.
May 20, 2009 | Philips Magnavox 27MS343S 27" TV
I have a Curtis Mathis standard television. When I accidently unplugged it (while it was on) I plugged it back in and now have strange green tones and a circle shaped matting in the screen. Help before my...
I prayed to God and then I unplugged the tv and then turned it back on and off three times from across the room with the remote control and the regular color returned.
Apr 02, 2008 | Televison & Video
Wont turn on at all...
read info at ctechnicians.com email for questions
Dec 25, 2007 | Mitsubishi VS-50607 50" Rear Projection...
Troubleshooting
Is it plugged into the power ? A fuse could be blown. A power supply failed. Short happened in the load on the power supply. All of these will stop the set from coming on and several more. You need to have it checked out. Stargazer
Aug 12, 2007 | Curtis CM19102 19" TV
Curtis International Curtis LEDVD1975A 19" Black 60Hz 720p LED TV/DVD Combo Logo
Top Curtis International Computers & Internet Experts
David Payne
David Payne
Are you a Curtis International Computer and Internet Expert? Answer questions, earn points and help others
