My kenwood oil filled heater model EW6708EK is not giving out heat
When i plug the heater in, all controls seem to function. i can adjust the temp , clock etc., but its not producing any heat
SOURCE: my oil-filled Holmes heater HOH2520U
I had the same problem. this is what i did. unplug the heater. removed the plastic panel to expose the control panel where the blinking light is.  Removed all the dust and cobweb build up, then using rubbing alcohol, wiped the white residue that was on the green circuit board. I did this 10 days ago and the heater has been working fine since then. chaz
Posted on Apr 04, 2009
SOURCE: control panel blinking
my heater did the same, very frustrating. i have solved this problem.  i took off the plastic cover to expose the electronic circuit board and noticed that there was a white residue on the board. I wiped this clean with rubbing alcohol and put everything back. as of 3 weeks ago i have used the heater frequently as normal and not had any problems. chazdee
Posted on Apr 19, 2009
SOURCE: Need a Owners Manual for a Kenwood Oil filled
I don't want to pay for something that i bought from manufacture>:
Posted on Oct 10, 2009
  • 74 Answers
SOURCE: Honeywell HZ-709 oil filled radiator heater-all
There is a bottom element and a top element so the elements could be dead.
More likey, there could be no power coming from the wall - there are switches on the front that need to light up or the thermostat could be set to off.
Posted on Dec 07, 2009
SOURCE: Kenwood oil filled radiator heater - digital
My EW6708K stopped working after a power outage (was not on at the time, just plugged in). I couldn't find any info online. So I used my last option: I took it apart. Two screws on the bottom opens the unit's electronics. Two more screws inside to get tol the circuit board. I was looking for a reset button. There was a tiny white “thing” on the circuit board. I pressed it and reassembled the unit. That did the trick! Simple. Just be neat and put everything back the way it was.
Posted on Jan 25, 2010
Manual for garrison oil heater model #043-5863-4
You should be able to download a manual here:
garrison oil filled heater model 043 5863 4
Also please be advised, your model may be under recall due to fire hazard:
http://www.healthycanadians.gc.ca/recall-alert-rappel-avis/hc-sc/2013/36781r-eng.php
Nov 16, 2016 | Heating & Cooling
Kenwood oil filled heater timer starting making a ticking noise. Is there a way to fix it?
Most of these model are not repair able but seems like thermostat problem
Feb 03, 2015 | Kenwood Heating & Cooling
My heater is not heating I have set all the temps went through all the trouble shouting..it will turn on start to heat then heat shuts off but display remains on??
Your heater may be heading toward complete failure of the heating element but the temperature control thermostat could be faulty.
Nov 05, 2013 | Comfort Zone CZ9009 Oil Filled Electric...
I don't understand what the controls do pelonis oil filled radiator
I would try the thermostat one by turning it up to a higher heat. I feel the other one may heat on high but would not shut off. You would have to do it manually.
Sep 23, 2017 | Pelonis WM-HO202C Oil Filled Radiator...
Trying to find out how much oil the Triton V-10 takes when I do my oil change? I cant seem to find it or anyone who knows
It should be listed in the owners manual, but because of different oil cooler setups you may have to do the change yourself and add oil until the correct level is established..... for the first oil change.
Most likely 7 liters,but start with 5,run the engine to fill the oil filter,let it sit for 5 mins and recheck and fill to full.
Note the amount needed for next time.
Nov 08, 2009 | 2000 Ford F250 Super Duty Crew Cabs
Kenwood kdw8st2a dishwasher e3 fault
The readings appear ok to me. The circuit that controls the element and any fuse in that circuit have to be suspected now.
Jun 08, 2009 | Bosch 18 in. SRS45E02 / SRS45E08 Exxcel...
Need Instruction Manual, Kenwood Electronic Heater #EW6708K
I have an original Kenwood instruction Manual for the Model
EW6708EK oil filled electronic heater (eng. and spanish)
Nov 21, 2008 | Heating & Cooling
Rinnai 1004 heats to a temp 4 degrees higher than set temp, adjustment?
You can adjust the position of the room air sensor found on the back of the unit between the heater and the wall. It is a black rubber bulb with yellow wires. There is a few inches of extra wire you can extend higher to get a more accurate reading of room air. While you are back there, check for drafts that will give you false readings.
Sep 23, 2008 | Rinnai RHFE-1004FA 38,400 BTU Energy Saver...
Recall
I had the 5101 I just sent it back last week to manufacturer,most of oil filled heaters make a noise as the oil heats up. The 5101 had a black control panel &black wheels & foot rest. Hope i was of some help. If u have more ? let me know. slinger5@localnet.com
Jan 26, 2008 | Lakewood 2727 Heater
Heating & Cooling Logo
106 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
